Old 12-13-2010, 01:57 PM   #1
brianglawson
Member#: 229468
2004 Impreza WRX STI
Default 17x9 +42 Grids with 245/45/17 at stock height?? (2004 Sti)
So will it work without rolling? I'm thinking that it will. My car is on stock springs/Feal struts and Whiteline sways. I may move to Swift progressive springs sometime soon, which then, I feel i will probably have to roll the rear a bit.
What do you guys think?
Anyone have pics of a similar setup?
(plz no comments on how crappy it will look) Tuckage isn't necessary to run flush wheels
brianglawson is offline   Reply With Quote
Old 12-13-2010, 02:11 PM   #2
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
that tire is too tall i would suggest a 245/40/17 it will cut gearing a little, and i would not expect you to have rubbing problems.
jdmboy is offline   Reply With Quote
Old 12-13-2010, 02:46 PM   #3
brianglawson
Member#: 229468
The tire height is a plus to me actually. I was wanting a 235/45/17 (25.4 inches tall) but i really want 17x9's for some wide/meaty summer tires. So i need a 245 tire and I want ground clearence(diff clearence, not fender gap) 245/40 are 24.7 inches tall while a 245/45/17 is 25.7 inches tall. An extra 1/2 of ground clearence while also having less fender gap would be nice!!
As for gearing. I was under the imporession that a 235/45 is the stock size in overseas markets. Hence, why american cars have such short gears with the shorter tires. I think I would like taller gears. I have tons of power and NO time to enjoy it!! I only wish i could hit 60mph without a 3rd gear change
Old 12-13-2010, 02:47 PM   #4
brianglawson
Member#: 229468
i basically just need to know if it will fit. Im hearing mixed opinions on this when I search. some say yes, others no... some have different offsets, some dont... etc..
Old 12-13-2010, 03:04 PM   #5
DrDanimalSize
Member#: 254097
2010 2014 Impreza
Not all tires are made the same (some tires 'run wide'), and manufacturing tolerances can vary by a couple mm (inner fender lip that may need a roll), so you won't know until you bolt 'em on and go driving around. You will also notice a difference with how much weight you have in the back and how droopy your stock springs have become after a few years of use.
All that to say a roll in the rear may be necessary, but otherwise everything should fit just fine.
DrDanimalSize is offline   Reply With Quote
Old 12-13-2010, 03:05 PM   #6
jdmboy
Member#: 240161
87 bmw e30
with a 245/45/17 your going to be a little more likely to rub because of the height of the tire, a can say certainly if it will rub or not it will be close, you may have to roll the rear fenders.
Old 12-13-2010, 03:24 PM   #7
brianglawson
Member#: 229468
Thanks!!!
Old 12-13-2010, 03:31 PM   #8
sc00by4life
Member#: 97135
this.
i understand you want "ground clearance", but its going to be tall and will very likely rub.
245/40/18 on Stock Height 2004 Sti? brianglawson Tire & Wheel 5 11-03-2010 12:05 PM
Testing Waters!WTT 5x100 Rota Torque R 17X9 +30 Bronze w/ 245/45/17 Yoko S-Drives Tecate Wheels/Tires 29 04-21-2010 03:53 AM
17x9" +38mm offset with 245/45/17 xrocket21 Tire & Wheel 20 04-18-2006 08:58 AM
245/45/17 on stock 2004 sti ? rapidus Tire & Wheel 16 03-30-2006 01:10 PM
17"x8" Rota's with 245/45-17 on a Forester XT SnowMann Forester Forum 22 03-23-2005 10:37 AM
