#1 |
Member#: 26782
Vehicle:2002 WRX WR Blue |
I'm struggling to wrap my head around a 2.5 swap for my bugeye.
Will this work if I get it tuned or am I missing something? USDM MY02.....has stock EJ205 Cosworth EUDM/JDM EJ257 long block...it's DBC JDM EJ207 ECU/motor harness IA Performance AVCS wiring kit If it does work and is tuned, would it have a chance in hell of passing emissions? Yes I know the motor is expensive. So is a new car. ![]() Thanks!
#2 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
work yes
pass emissions nope depending on the state the jdm ecu will never pass |
#3 |
Member#: 26782
Thanks Jaxx. Been doing some research on that....wonder if Missouri can read JDM ECU? Odd it's state to state.
Also been talking w/ Cosworth sales support. They pretty much agree. "The engine can run properly assuming the wiring and sensors are connected with the ecu properly. You may a few check engine lights but most issues should be manageable." .....need KK3920 cams..."The cam sensor reads differently so this camshaft has the correct triggers to match". Something like COS-20007707 (EUDM/JDM, DBC, single AVCS, 2.5 w/ KK3920 cams) Now to continue w/ the plans..... MUAHAHAHAHA! ![]() |
| Thread Tools | |
| Display Modes | |
| WTB: ECU and harness for 99 2.5 | 95GCimpreza | RMIC Private Classifieds | 4 | 01-05-2010 03:07 PM |
| 02 2.0 WRX flywheel in an 03 2.5 Legacy, will it work? | meandean | Transmission (AT/MT) & Driveline | 3 | 11-15-2006 11:45 PM |
| Ver 6 STI engine/USDM 2.5 bottom end, WILL IT WORK | SOO00B | Subaru Conversions | 7 | 04-16-2006 11:20 PM |
| WRX clutch on 2.5 RS trans? (i.e., push-type to pull-type ... will it work?) | Necromancer | Transmission (AT/MT) & Driveline | 14 | 06-07-2004 02:49 PM |
| JDM STI Intercooler on USDM STI...Will it work? | Nivek-CA | Factory 2.5L Turbo Powertrain | 45 | 12-05-2003 12:05 PM |
