Old 12-15-2010, 02:31 AM   #1
stiferko
Member#: 261366
1997 STiR
Default JDM EJ20 V7 and V8
i am looking to do the swap in my 02 wrx, and i know all that is involved...
my question is, is the v8 as capatable as the v7?
whats the difference between the 2?
can i for the most part, plug and play it the same way?
thanks!
stiferko is offline   Reply With Quote
Old 12-15-2010, 05:46 AM   #2
KenSekiguchi
Member#: 175331
2002 WRX STi - WRB
JDM V7 EJ207/13' Felt Z85
Well, since you have an 02' WRX, the swap should be very straight forward with the exception of wiring the AVCS which isn't too difficult, for the most part it is all plug and play. The V7 EJ207 came with full forged internals where the V8 EJ207 came with hyperueritic internals. Both the V7 and V8 EJ207's are monsters when compared to our USDM counterparts in terms of absolute reliability, driveability, the amount of abuse taken, and the fun factor on both of the V7 and V8 is very high even when stock.
KenSekiguchi is offline   Reply With Quote
Old 12-15-2010, 07:07 AM   #3
stiferko
Member#: 261366
1997 STiR
so the v7 and v8 are the same as far as the wiring? both plug and play? + wiring of the avcs
Old 12-15-2010, 01:41 PM   #4
Britain
Member#: 247604
1974 Porsche 914
1700lb AX Car w/ Spec-C
Yes, both are the same. The V8 had a intake temp sensor so one extra wire. If you get the V8 Spec-C then you don't have to deal with the TGV's.
-Britain
Britain is offline   Reply With Quote
Old 12-16-2010, 11:02 AM   #5
stiferko
Member#: 261366
1997 STiR
where would the temp sensor run to?
Old 12-17-2010, 12:13 PM   #6
RiskySeven
Member#: 26782
WR Blue
AFAIK, your ECU won't know what to do w/ AVCS, you'll need a JDM ECU. If you are worried about emissions, some states can't read JDM ECUs...some apparently can.
http://www.iaperformance.com/product...oducts_id=2580
RiskySeven is offline   Reply With Quote
Old 12-17-2010, 02:55 PM   #7
chudlo
Member#: 15505
2002 JDMV8 STI Wagon
-Britain
Not sure what you mean here, but the regular JDM V8 motor doesn't have TGVs either.
To the OP:
The basic wiring is the same between the V7 and V8 motors as far as getting the AVCS working is concerned. IA Performance has an AVCS wiring kit to make the job easier.
chudlo is offline   Reply With Quote
Old 12-18-2010, 01:20 AM   #8
stiferko
Member#: 261366
1997 STiR
i know how to wire it up and everything, that isnt the problem at all... i was just originally looking into the V7 and have been finding alot of good deals on v8's so i was wondering if the v8 was the same as far as wiring and installation
Old 12-19-2010, 05:11 AM   #9
12.9$500rex
Member#: 78178
2004 LS1 WRX
So anyone know emissions info on the JDM v7 & v8? Who has passed with these swaps and in what states? Anyone pass in IL?
12.9$500rex is offline   Reply With Quote
Old 12-19-2010, 05:12 AM   #10
12.9$500rex
Member#: 78178
2004 LS1 WRX
Old 12-19-2010, 05:13 AM   #11
12.9$500rex
Member#: 78178
2004 LS1 WRX
delete
Old 12-19-2010, 11:15 AM   #12
02 Scoob-TN
Member#: 176010
2005 WRX sdn ver8'ed
Phat-Tuned RIP Bugeye
Lightbulb
I easily passed here in nashville,TN. Our test consists of scanning the ECU for trouble codes and readiness monitors, visual inspection of gas door inlet plug, etc. I have a version 8 longblock with the matching JDM ECU with AVCS hooked up and all.
02 Scoob-TN is offline   Reply With Quote
Old 12-19-2010, 12:32 PM   #13
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
-Britain
Any version 8 you dont have to deal with TGV`s. Alot of people think there is a big difference between the Version 8 Spec-C and Standard Version 8 STi like intake, header, blah blah but there really is not. Cams are different, ECU is a tad bit more agressive, and thats about it engine wise. Version 7 has TGV valves, Version 7 spec-c/ra-c do NOT since they recived the later V7/8 big port heads and matching tgvless intake
prokaw875 is offline   Reply With Quote
Old 12-19-2010, 12:41 PM   #14
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
Quick rundown of what you need for the swap...
Complete EJ207 $4000-5000 complete w/ecu and harness
IA Performance AVCS Harness $200?
Stock downpipe
or
Ia performance twin scroll flange $90
Ebay downpipe bellmouth $150
Custom made twin scroll downpipe $150
Walbro 255 $100
Drivetrain swap or ACT HDSS clutch $400-4000
thats about it for putting a 207 in a wrx
Old 12-19-2010, 02:39 PM   #15
stiferko
Member#: 261366
1997 STiR
i was leaning more towards the v8 lately because of the twin scroll...
i dont know which one to go with
Old 12-19-2010, 04:56 PM   #16
Ryan23
Member#: 15116
2000 Ver6 STi Type-R
EJ257/GT35R
None of the JDM Motors have TGV valves. Regular STi have the empty TGV housings. Spec-C have the full length runners (TGV-housing-less). All JDM heads are also "big-port".
OP: Main difference: Ver 7 is single scroll, VF30/34 with AVCS.
Ver 8 is twin scroll, VF36/37 with AVCS. If you are going to run the original turbo/header, go with the twin scroll setup provided the cost between the two are close. There are some differences between the two engines but nothing you would probably ever notice.
Ryan
Ryan23 is offline   Reply With Quote
Old 12-19-2010, 05:14 PM   #17
12.9$500rex
Member#: 78178
2004 LS1 WRX
So anyone have IL emissions experience with this swap?
Old 12-19-2010, 06:34 PM   #18
stiferko
Member#: 261366
1997 STiR
im looking to make about 350awhp.... will the OEM twin scroll meet these needs?
im not looking to build a motor, so not sure which would be my best bet
Old 12-19-2010, 07:47 PM   #19
Ryan23
Member#: 15116
EJ257/GT35R
Pretty close on race gas. Close enough that I go with the stock setup for OEM reliability and spool. When you get bored with that, than think about upgrading.
Ryan
Old 12-19-2010, 07:55 PM   #20
stiferko
Member#: 261366
1997 STiR
would the v8 be as capable? being that it doesnt have as good built bottom end as the v7?
i figure with a good tune, fuel system, and the right bolt ons... it shouldnt be a too outrageous of a target to hit...
Old 12-20-2010, 01:50 AM   #21
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
why do you all make it seem to hard to put in a AVCS motor?
Stick that longblock in and don't run AVCS. Ver7 STi not big port, Ver7 Spec C is big port.
FuJi K is offline   Reply With Quote
Old 12-20-2010, 03:30 AM   #22
Ryan23
Member#: 15116
EJ257/GT35R
I've got a set of heads sitting on an engine here in my living room that beg to differ I have yet to see a set of small port heads here in Japan. Incidentally, the Subaru FAST CD lists the same P/N for the heads, Spec C or otherwise.
Ryan
Old 12-20-2010, 04:41 AM   #23
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Ryan
what trim did that head come off of? if thats the case then bugeye ver7 "EJ207" motors that have been sold back in the day must have been AUS/EDM motors listed as "JDM." Forester STi EJ255 has small ports. Tomei has R&D on that head, which isn't an EJ207 head BUT is there in Japan.
Old 12-20-2010, 07:39 PM   #24
Ryan23
Member#: 15116
EJ257/GT35R
I haven't looked at any Forester EJ255s up close, so you got me there Every once in awhile they pop up for sale but nowhere near the frequency of GDB engines.
My heads came off a EJ207DW3CJ in a Ver 7 RA (non-Spec C). They have the deep splitter. Granted, they have been ported
Ryan
Old 12-20-2010, 08:41 PM   #25
Ryan23
Member#: 15116
EJ257/GT35R
Was thinking about this post in the shower Just to clear up any potential misconception, that pic was not insinuating the port entry is any larger. Just using the calipers as a point of reference vice the obscure "large socket"
Ryan
does the jdm v7 and v8 block stamped EJ20? ejcivicdee General Community 15 09-22-2009 03:02 PM
JDM V7 and V8 injectors? Mohammadov Newbies & FAQs 2 03-11-2008 02:59 AM
FS VA: JDM v7 and v8 Gauge Clusters quadzilla Interior/Dressup/Audio & Security 10 01-15-2008 12:12 PM
Back to STX sale begins! V7 JDM TMIC/V7 Splitter/V8 Sprayer thrdeye Private 'For Sale' Classifieds 34 08-09-2005 08:54 AM
Any difference between STi JDM V7 and V8 seats? projectrally Interior & Exterior Modification 4 08-31-2004 10:50 AM
