Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 12-15-2010, 08:43 AM   #1
Motion Lab Tuning
Member#: 228856
Default Just Tested! Motion Lab Hi-Flow Crossover Pipe...
What:
Motion Lab (MLT) Hi-flow Manifold Crossover Pipe
Manufacturer:
Motion Lab designed and manufactured in Charlotte, NC.
Why:
After seeing some of the other aftermarket crossover pipes crack at the flex bellow, we felt that there was surely a better design. Our aim was to create a stronger and better flowing pipe.
Test Vehicle:
We utilized a 2008 WRX to show the benefits of the newly designed MLT crossover pipe. This WRX was fitted with a FMIC, HTA68 turbo, MLT (soon to be released) EWG up-pipe with Tial 38mm v-band, MLT 880cc injectors, 3-port BCS, intake, FP upgrade, TB hose upgrade, and 3” cat-less exhaust.
How the test comparison was carried out:
To make this as fair as possible, we first tuned the WRX with all of the above mentioned parts, including the MLT crossover pipe. Once we felt that we had wrung out as much as we were going to get, we shut it down and let it cool off. I then had George remove the MLT crossover pipe so that we could replace it with the factory stock pipe. We felt that this was the best strategy so that both the factory stock pipe vs the MLT hi-flow pipe utilized the “same tune”. Otherwise, any further tuning would through off the results.
Conclusion:
The data speaks for itself. What you see is a dramatic improvement in turbo spool up and improved power and torque throughout the entire RPM range! This is a worthwhile mod on any EJ series Subaru motor.
***********NOTE: BLACK dyno lines = MLT Hi-flow Crossover pipe
Stock vs MLT Hi-Flow Crossover Pipe
Boost
Factory Stock Crossover Pipe
MLT Crossover Pipe Graph
Motion Lab Tuning is offline   Reply With Quote
Old 12-15-2010, 09:55 AM   #2
krauser2
Member#: 153751
2002 Mazda Miata
The Darkness
I finally see what all the fuss about during the meet. Looks good guys. Got me jones'n hard
krauser2 is offline   Reply With Quote
Old 12-15-2010, 10:06 AM   #3
Racerfab
Member#: 83936
2004 STi
Good Job! How hot was the MLT crossover pipe when George changed it after the tune? Do you think the ceramic makes a big difference?
Racerfab is offline   Reply With Quote
Old 12-15-2010, 10:42 AM   #4
bdkyzer
Member#: 265002
2008 WRX
Default Proud owner for the x-over pipe among other goodies
As the owner of this WRX, I'd like to speak candidly about this part. As mentioned in the write-up, the quality is top notch and fitment great. (It doesn't hurt to look around the engine bay and see more shiny parts either.)
As far as performance, the shift into the lower portion of the power band by about 500rpm makes for a tangible feel when cruising along and needing boost. Since this is my daily driver, I often find myself cruising around 2500 - 3000 rpm and having the ability to step on the gas and achieve peak boost sooner makes for more enjoyment. (Then I just let the HTA68 do the rest.)
Bottom Line in my case: good fit, good quality, +10hp, +25ft/lb, -500rpm to peak boost for under $200 bucks installed makes for a no-brainer.
Anyone want my stock part???
bdkyzer is offline   Reply With Quote
Old 12-15-2010, 10:52 AM   #5
stretchedk7
Member#: 170602
06 Wrx 6Spd TSBorg
Warner S400-Aem-2200s
^hold on to the stocker. You never know when you/a bud might need one. And they dont sell for much.
stretchedk7 is offline   Reply With Quote
Old 12-15-2010, 12:06 PM   #6
Motion Lab Tuning
Member#: 228856
Yeah, George said it cooled down faster than the stock crossover pipe during changing the pipes. Obviously it holds the heat in during operation quite well with the coating The ceramic coating is a "most do" on these. Otherwise there would be a loss of heat which you don't want.
Old 12-16-2010, 09:38 AM   #7
Motion Lab Tuning
Member#: 228856
bump!
Jordon @ Motion Lab
Old 12-16-2010, 10:39 AM   #8
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
Very nice. Good to see another quality xpipe on the market. Any chances of you guys building the 06-07 version? Has pricing been released yet?
kenliu84 is offline   Reply With Quote
Old 12-16-2010, 10:55 AM   #9
Motion Lab Tuning
Member#: 228856
Pricing is released contact us.
Jordon @ Motion Lab
Old 12-16-2010, 11:57 AM   #10
kenliu84
Member#: 107618
2006 OBP WRX Wagon
good price for coating included.
what about coming out with an 06-07 crosspipe?
will be looking forward to the reviews on this, as I will be shopping for a crosspipe for my spring upgrades. also concerned with the possibility of the ticking noise under load, as heard from other crosspipes.
Old 12-17-2010, 08:02 AM   #11
spec_bg
Member#: 226517
04 FXT dom1.5xtr
psm
same here, curious about the sound of this pipe
spec_bg is offline   Reply With Quote
Old 12-17-2010, 12:03 PM   #12
Motion Lab Tuning
Member#: 228856
The cross pipes work on all 2002-2011 WRX/STi/Legacy GT (Except 06-07 WRX), Stay posted for a 06-07 cross pipe.
Our MLT cross pipe has no sound difference over the stock cross pipe.
Jordon @ Motion Lab
Old 12-17-2010, 06:02 PM   #13
fastwrx25
Member#: 126441
03 bugeye
props to you guys for following the oem style flex section.
should be alot stronger than the braided flex style pipes.
and these pipes are made in the usa also? if so much win.
I wish you guys got this out years ago.....
fastwrx25 is offline   Reply With Quote
Old 12-18-2010, 12:11 PM   #14
Motion Lab Tuning
Member#: 228856
We make these in house!
Jordon @ Motion Lab
Old 12-18-2010, 08:51 PM   #15
Dragon Wagon
Member#: 101095
1997 leggy gt
Reo Red
Are the bellows your using sleeved and rated for exhaust mani use ?
Dragon Wagon is offline   Reply With Quote
Old 12-19-2010, 01:06 PM   #16
seattle944t
Member#: 18308
2005 WRX STi
<cough>Group buy</cough>
seattle944t is offline   Reply With Quote
Old 12-20-2010, 10:10 AM   #17
krauser2
Member#: 153751
2002 Mazda Miata
The Darkness
Put me down for one Jordan!!!!
lets add it to my list
Old 12-20-2010, 10:39 AM   #18
KurtP
Member#: 44836
1999 Fozzy
after having seen another brand's cross over pipe net 0 tq, 0 hp, and 0 change in spool, im having a hard time seeing how this one is making the same difference as a down pipe......
Am I missing something?
KurtP is offline   Reply With Quote
Old 12-20-2010, 11:41 AM   #19
RabidSTi
Member#: 60576
07 STi
UGM
pipe diameter? (or did I miss it?)
RabidSTi is offline   Reply With Quote
Old 12-20-2010, 11:56 AM   #20
kenliu84
Member#: 107618
2006 OBP WRX Wagon
I'm curious, what brand?
Old 12-20-2010, 12:07 PM   #21
KurtP
Member#: 44836
1999 Fozzy
grimmspeed
Old 12-20-2010, 12:31 PM   #22
SeeeeeYa
Member#: 129681
2014 FXT Touring
^^ This, although I don't really remember all the specifics over the years, nor think I have to.
No hating here whatsoever, but gimme a break.
SeeeeeYa is offline   Reply With Quote
Old 12-20-2010, 01:35 PM   #23
Boxer112
Member#: 78751
2006 WRX STi
I wanted to go this route because I don't have faith in a lot aftermarket headers. I want to port n polish my headers and I am considering this crosspipe. are these able to withstand the coating process that swaintech does? I have my mind made up that they will coat my entire exhaust with their white coating since I believe they are the best in the game with coatings..
Boxer112 is offline   Reply With Quote
Old 12-20-2010, 01:50 PM   #24
kenliu84
Member#: 107618
2006 OBP WRX Wagon
I think the gains might have a lot to do with other complimentary mods as well. In regards to Grimmspeed's crosspipe, yeah I definitely don't find much gain at all from other people who have used it and even according to their website, it's a much smaller gain and the dyno graphs definitely don't look this good.
Old 12-20-2010, 02:59 PM   #25
Motion Lab Tuning
Member#: 228856
Yes they are OEM comparable quality.
PM'ed
You have one with your name on it.
Nope, nothing missing here. It makes proven power.
2"
Thanks for the words. We were all impressed how good the graphs looked afterwords.
Jordon @ Motion Lab
FS in PA: Grimmspeed high flow crossover pipe 04.SPT.WRX MAIC Private Classifieds 2 05-01-2010 11:40 AM
FS in PA: Grimmspeed high flow crossover pipe 04.SPT.WRX Engine/Power/Exhaust 5 05-01-2010 11:37 AM
GrimmSpeed high-flow Crossover pipe garagedefeat Engine/Power/Exhaust 9 07-03-2008 01:12 PM
FS:PA Grimmspeed V1 Hi Flow Crossover Pipe 1cugoblak Engine/Power/Exhaust 2 04-06-2008 12:10 PM
Brand New Grimmspeed Hi Flow Crossover pogomonkey Engine/Power/Exhaust 28 10-14-2007 10:53 AM
Message Board Statistics All times are GMT -4. The time now is 06:56 AM.
