View Poll Results: Use Forester ECU w/Piggy or WRX ECU
Forester ECU with Piggy Back 0 0%
WRX ECU tapped into forester Harness 2 66.67%
OTHER 1 33.33%
Voters: 3. You may not vote on this poll
Old 12-15-2010, 11:21 AM   #1
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
Default Stock Forester ECU or WRX ECU? POLL
Should I keep the ecu from my forester in my car and use a piggy back or should I tap everything in to run off of the WRX ecu? Or if you have another answer choose other and post your option.
99 US Forester L and putting in a 97 JDM WRX wagon motor. I will have to source another turbo as it was missing from the swap, but have engine harness and ecu which has a prova eiffel chip in it. So since I will probably not be getting a factory turbo I will need to have a tune anyway. Forester ECU seems to have a lot more control coming from the ecu then what the WRX ecu has. Hope this clears up some information for a more definite decision. Let me know if you need any more details. Don't have the motor yet so can't check to see motor code or ecu code, but assume 97 wrx wagon which means can't tune it with factory ecu.
KOJAK-02-WRX is offline   Reply With Quote
Old 12-15-2010, 10:06 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
more info needed
harness merger all the way
piggy back is just a waste of time plus the you need to tune it
Old 12-16-2010, 05:53 AM   #3
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
When You say harness merger are you talking, merge the engine harness into the factory ecu? Which I know has to be done, its a matter of which ecu I should use. Both have to have a piggyback if used or replace both with a standalone which I'm guessing would have to be for the 97 wrx.
Also getting mixed info on what version the engine is for ecu pinout. Is it a V3 EJ20k or a V4, or is there no difference. I posted another thread which has the ecu pinouts, which you replied to also jaxx.
More info added, bump
Old 12-16-2010, 08:00 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
v3,v4,97-98wrx and the 97-98 wagon (ej20g) are all the same
but no not the engine harness
subarus don't have a engine harness the whole thing under the dash
Old 12-18-2010, 03:23 PM   #5
69subaru360
Member#: 159682
1995 WRX
2015 F150
You don't have a choice you would have to merge the harnesses. Your 99 forester ecu is phase 2. It will not run a 97 wrx engine. The cam triggers on the back of the cam gears are different.
If you have emissions in your state you are screwed, the 97 wrx egnine isn't obd2. Also don't even think of running a prova chipped ecu on 93.
Old 12-18-2010, 10:48 PM   #6
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
Isn't there a way to switch the triggers on the cams our no? That is the one good thing, I don't have to deal with emissions. And I def won't run the prova chip, will replace J1 jumper to make it run stock map. Will that be good enough? Will also be using a front mount which I have heard will help my case on 93. Also have a smt8 piggy back in order to tune. Do you happen to know what turbo came on 97 wagon? Didn't chine with one.
Old 12-19-2010, 12:40 AM   #7
69subaru360
Member#: 159682
1995 WRX
2015 F150
No, there is no way to run it with a 99 usdm forester ecu
Stock EJ20G ecu tune is fine on 93. Front mount will help.
97 wrx wagon came with TD04.
Old 12-19-2010, 05:57 PM   #8
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
32 bit sti ecu is the only stock ecu worth swapping in
nvm i dont know **** about backward compatibility maybe its megasquirt time
feint05 is offline   Reply With Quote
WTB : Looking for a stock Forester xt or sti catalytic converter boomee MAIC Private Classifieds 5 08-26-2010 01:07 AM
FS: Stock '02 5 speed WRX ECU OedipusWRX Private 'For Sale' Classifieds 2 12-08-2004 08:02 PM
Forester XT or WRX Wagon... wesy Bay Area Impreza Club Forum -- BAIC 4 12-30-2003 05:01 PM
Which is faster in the top end, Forester XT or WRX? BrysImpreza General Community 8 10-16-2003 02:22 AM
ECU or Access ECU bdel-WRX Private 'Wanted' Classifieds 1 08-18-2003 01:05 AM
