Old 07-04-2002, 05:19 PM   #1
NickSTi
Member#: 626
2001 Impreza 2.5 RS
Black Diamond Pearl
Question Greddy Profec B not controlling boost
I am figuring there is something wrong with my vacuum line to my wastegate, I have to find a lift to look at it, but i hit 1 bar
First question is, who are the selectors in the back supposed to be set? On their website it says there are actuator and external settings. Right now I have it set as
- _ _ -
1 2 3 4
(for those who have a profec... u understand)
It still didnt work. I have the balance at 12 o clock. and the low selected and all the way to min.
Any ideas?
NickSTi is offline   Reply With Quote
Old 07-04-2002, 05:54 PM   #2
zaidallas
Member#: 4106
IIRC , you're supposed to have to have a vuccum line going to the back of the unit . also if you have boost spikes , the pdf file on their site tells you which of those settings in the back to change . Do you think you have the installation correct ? if it doesn't hold boost at all then it could be that something isn't hooked up correctly.
zaidoun
zaidallas is offline   Reply With Quote
Old 07-04-2002, 07:09 PM   #3
NickSTi
Member#: 626
2001 Impreza 2.5 RS
Black Diamond Pearl
i think those 600 horses are going to your brain z
that was more or less what i knew, that the vacuum line to the wastegate is prob not right. But i checked and saw nothing wrong. I looked on the site and that was where i saw the settings on the back. The funnie thing is i have it on min and i am seeing too much boost.
I will do some hose checking now. but i dunno.
Thanx tho.
Old 07-04-2002, 07:26 PM   #4
8Complex
Member#: 922
04 FXT
Red
Nick - Check your PM... I was wondering what the rate of the spring is in your wastegate. Also, if you hook it up straight from manifold to wastegate with no disruption, what kind of boost do you run?
Greddy Profec B Spec II boost controller T_REX02 Private 'For Sale' Classifieds 2 10-11-2004 05:52 PM
Greddy Profec-B Spec Electrict boost controller Brewmaster Private 'For Sale' Classifieds 2 09-29-2004 12:45 PM
can i use a greddy profec b spec 2 boost controller with utech blue02scoobie Factory 2.0L Turbo Powertrain 4 09-17-2004 10:43 AM
Greddy Profec B Spec II Boost Controller Help mcgehman Electrical & Lighting 1 09-14-2004 08:50 PM
FS: Greddy profec B spec 2 boost controller krazy Private 'For Sale' Classifieds 0 05-30-2004 03:21 AM
Message Board Statistics All times are GMT -4. The time now is 09:27 PM.
