Old 07-04-2002, 06:24 PM   #1
kotaro
Member#: 8256
Question Question about boost controllers
If you increase a car's boost (if it makes any difference let's suppose it's a BF turbo legacy 2.0 1994/1993, the ones with intercooler) with a boost controller, I suppose more air enters the cylinders right? So does the car (or the boost controller or whatever, I don't know) adjust the fuel injection to keep the mixture from getting lean? Do you need to install anything extra if you get a boost controller?
thanks,
Kotaro
kotaro is offline   Reply With Quote
Old 07-06-2002, 03:22 PM   #2
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
When you increase the boost, the engine, via the O2 sensor, sees that there is a different air-fuel mixture, and increases the amount of fuel going in.
There's no need to get an air-fuel computer if you're just increasing boost slightly, but it could be used to lean out the mixture and make more power.
Dave
DLC is offline   Reply With Quote
Old 07-06-2002, 06:45 PM   #3
kotaro
Member#: 8256
Thumbs up
Thanks a lot for the answer
Kotaro
question about boost controllers speedyshifter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-01-2005 03:00 PM
Question about boost controller N.C.REX Newbies & FAQs 9 06-17-2004 02:28 PM
question about boost controller placement (in cabin) spankaveli Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-24-2003 10:59 AM
question about boost controler ? BlueWrx2004 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-21-2003 11:43 PM
Question about boost controler OatesBoats Newbies & FAQs 7 08-23-2002 03:00 PM
