Old 12-15-2010, 10:57 PM   #1
Flynlow151
Member#: 77870
2004 Subaru STI
TheBoostCreep Stage II
Default Cusco Underpanel - Custom
Instead of buying one from Cusco, I have decided to make my own in class. Made from 1/8" 5052 Aluminium and tig welded together after the center section was bent. Not completed as I still have to finish the welds on the center side gaps and get the holes drilled to mount. Not bad for first attempt at welding aluminium
Flynlow151 is offline   Reply With Quote
Old 12-15-2010, 11:00 PM   #2
Flynlow151
Member#: 77870
2004 Subaru STI
Going onto this
Old 12-15-2010, 11:21 PM   #3
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
Looks good!
ZeroDrift is offline   Reply With Quote
Old 12-16-2010, 10:04 AM   #4
downest
Member#: 194343
1991 CRX B18C5 turbo
'88 4Runner daily
What's up with the box section in the middle?
downest is offline   Reply With Quote
Old 12-16-2010, 10:15 AM   #5
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
Looks like it will become an intake scoop of some sort. I'm curious as to the ground clearance with that scoop.
Old 12-16-2010, 01:08 PM   #6
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
looks great.... ot question: where or to what did you mount your Hella's? I like them wide like that... painted is a bonus...
love the car... clean, smooth, simple, subtle... nicely done.
Rob
TXwrxWagon is offline   Reply With Quote
Old 12-16-2010, 04:29 PM   #7
loafman
Member#: 256373
2003 WRX, 2011 STI
Nice work
Definitely post pics when its done.
loafman is offline   Reply With Quote
Old 12-16-2010, 05:02 PM   #8
wantsti
Member#: 134764
04 sti
java black pearl
It creates a low pressure spot so when the air goes under the car it pulls down on the front of the car.
wantsti is offline   Reply With Quote
Old 12-16-2010, 09:35 PM   #9
Flynlow151
Member#: 77870
2004 Subaru STI
Ground clearance will be the same as current with the bumper, plus 1/8" for the underpanel.
Old 12-16-2010, 09:37 PM   #10
Flynlow151
Member#: 77870
2004 Subaru STI
Rob
I fabricated two small brackets that hang from the radiator support. Basically two small strips of aluminium and drilled holes at each end to mount to the horns and the radiator support.
Old 12-16-2010, 09:38 PM   #11
Flynlow151
Member#: 77870
2004 Subaru STI
Exactly. My hole is smaller in length than the cusco but also a bit deeper. Hopefully it works similar.
Old 12-17-2010, 03:30 PM   #12
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
That's legit! do you have any pics from underneath the car?
how good does it feel to make something saving hundreds of $$$$ hahaha
breaksOFTEN is offline   Reply With Quote
Old 12-17-2010, 07:56 PM   #13
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
If that is the case I am assuming it's mounted so the box goes down creating a neck down affect between it and the ground.
If that is the case look at the ramp angle on the backside so you don't get detachment of flow or your ruin the affect of the aero.
Old 12-18-2010, 12:15 AM   #14
wantsti
Member#: 134764
04 sti
java black pearl
The box goes up from the ones ive seen. I have no idea if it actually works thats just what I have read.
Old 12-19-2010, 08:10 PM   #15
Flynlow151
Member#: 77870
2004 Subaru STI
Did a 70 mile run on a country hiway, speeds up to 80 mph, seems to actually pull the front end down, steering felt stiffer. Want to figure out a better way to mount the front of the lip to the bumper, right now its sturdy, but I need it to be solid if I am going to go over 100 mph.
Old 12-19-2010, 08:47 PM   #16
Flynlow151
Member#: 77870
2004 Subaru STI
Old 12-20-2010, 07:14 PM   #17
wantsti
Member#: 134764
04 sti
java black pearl
you should of made it poke out the front so it could be a splitter also. looks good though.
Old 12-20-2010, 09:05 PM   #18
Flynlow151
Member#: 77870
2004 Subaru STI
Thought about that but since it is now only held on by subaru plastic clips, I wasn't sure how much force it could handle before coming off below the car
Old 12-21-2010, 01:18 AM   #19
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Be careful to make sure you are getting enough cooling with that undertray on. I have a splittler/undertray that starts 6" in front of the bumper and ends just ahead of the wheel center line that caused a significant increase in engine bay temperatures.
I ended up having to duct the radiator to the bumper to get enough air flow to keep it cool.
speedyHAM is offline   Reply With Quote
New GRB 08 + STI Underpanel, Beatrush tow hooks, GC8 Underpanel In stock Ready To GO! Kami Speed Exterior/Styling 106 03-07-2011 06:01 PM
Cusco Urethane Front Lip and Cusco Underpanels Z1 Performance Exterior/Styling 51 03-03-2009 05:34 PM
Question about Cusco GT engine underpanel KB21 Interior & Exterior Modification 3 11-06-2008 12:27 PM
HKS Kansai Diffusers, Cusco Front Lip/Underpanels, S203 Spoilers, Zerosports, INGS ++ Z1 Performance Exterior/Styling 24 11-30-2007 03:08 PM
Tons of Exterior Toys - S203, Roof Spoilers, Heatshields, Cusco front lip/underpanel Z1 Performance Exterior/Styling 0 07-22-2006 05:28 PM
