Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 07-04-2002, 06:44 PM   #1
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Default Looking for 200+hp at the crank...
I'm thinking of trading my '01 Prelude for a '02 5-spd RS.
What mods will I need to get 200hp or more while keeping it N/A?
From researching, I've read that I/H/E don't do much for gains on their own, so what else is there -- cams, cam gears, u/d pulleys, balancing the crank, re-sleeving the cylinders, hi-comp pistons? What level Cobb would do it?
My budget is ~$3,000, and I'd like the car to stay as reliable as possible.
My wife won't let me touch her '00 RS sedan, so I'm gonna have to buy my own to play around with. Darn.
Spenk is offline   Reply With Quote
Old 07-04-2002, 06:54 PM   #2
wistful
Member#: 745
2004 STi
Java Black Pearl
Naws
Don
wistful is offline   Reply With Quote
Old 07-04-2002, 07:08 PM   #3
Jayson_K
Member#: 11663
02 RS
platinum silver
intake
header back exhaust
high flow cat
pullies
cobb cams
and you will be a little over 200hp is the general concensus, and ya thats do-able for under $3000 usd.
edit: oops that's 200+ at the fly
Jayson_K is offline   Reply With Quote
Old 07-04-2002, 07:43 PM   #4
Julian
Member#: 1182
MY00 RS
BRP
Julian is offline   Reply With Quote
Old 07-05-2002, 12:54 PM   #5
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
Originally posted by Jayson_K
intake
header back exhaust
high flow cat
pullies
cobb cams
crank and flywheel power should be the same...
I think you will need a bit more than those mods to pull it off. That will be close, but not quite...
DanzBorin is offline   Reply With Quote
Old 07-05-2002, 05:24 PM   #6
imprezey
Member#: 17178
2001 2.5RS Coupe
Silverthorn Metallic
what would that be at the wheels?
imprezey is offline   Reply With Quote
Old 07-05-2002, 05:47 PM   #7
stiguy555
Member#: 11190
1992 Lexus SC400
1998 Forester - Green :D
About 145 whp.
stiguy555 is offline   Reply With Quote
Old 07-07-2002, 12:17 PM   #8
Shag-e
Member#: 8168
2013 WRX Limited
I know a guy in Rochester that can make your car 200+ or can do all the work on the engine and what not.
He only charges $30 an hour.
If you are interested let me know.
Shag-e is offline   Reply With Quote
Which injectors needed for 500 hp at the crank. AntonioS Normally Aspirated with bolt-on Forced Induction Powertrain 4 11-02-2003 02:59 PM
STi: APS got 311 hp at the crank stock! bigb_9_99 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 46 09-25-2003 07:52 PM
70 hp at the crank! mcu81 Proven Power Bragging 7 07-01-2002 08:53 AM
Goal of 200 HP at the wheels is realistic ? Mr. Rogers Normally Aspirated with bolt-on Forced Induction Powertrain 16 05-15-2002 07:15 AM
correction - its 390 hp at the crank ! alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 68 10-31-2001 11:54 AM
