Old 12-16-2010, 11:15 AM   #1
flyguyeddy
Member#: 236695
1995 impreza outback
dark green/greyish
Default turbo selection advice needed.
ok heres what i would like to do.
my engine will be a ej22 phase 1 with wiseco turbo leggy pistons (with probably less dish than stock) and ej251 heads with sti rods, and wrx exhaust manifolds/m2 uppipe.
i have a garrett center section from a saab thats water cooled and i would like to build a t3/t4 hybrid for this car. the turbo will be rotated with an adapter i plan to make to bolt to the uppipe, similar to what general did with his rotated holset build. i will be using an auxiliary water pump from a volkswagen instead of a waterbox.
what i want to know is, what should i use for a compressor wheel/housing and turbine wheel/housing if i would like to run 15-20psi and not go over 6500rpm or so and make moderate horsepower with it?
i dont want to buy a turbo, id like to piece one together and send it somewhere to get balanced, such as gpopshop.
perhaps i should buy a cheap ebay t3/t04e turbo and have it rebuilt?
flyguyeddy is offline   Reply With Quote
Old 12-20-2010, 10:06 AM   #2
flyguyeddy
Member#: 236695
dark green/greyish
awesome.
turbo question/advice needed. jerbull88 Factory 2.5L Turbo Powertrain 1 07-01-2010 11:56 PM
EZ30 sequential turbo build. Advice needed. Rs30 Subaru Conversions 3 03-19-2010 03:25 AM
Building a frankenstein with some scooby parts. Turbo selection help needed ugabuga Factory 2.5L Turbo Powertrain 2 09-21-2007 02:29 PM
More turbo troubleshooting...advice needed. edo2000 Alaskan Impreza Club Forum -- AKIC 11 10-25-2006 11:01 PM
Flawed turbo logic? Adviced needed. JayZ28 Factory 2.5L Turbo Powertrain 19 08-15-2005 08:57 PM
Message Board Statistics All times are GMT -4. The time now is 09:17 AM.
