Old 12-16-2010, 03:25 PM   #1
qoncept
Member#: 44762
2013 BRZ
Default 2.5 hybrid stumbling, missfires
A guy in town just swapped a 2.5 block/2.0 head hybrid in to his WRX and it's having some problems now. A CEL is flashing with missfires on cyls 1, 2 and 4, it's stumbling at idle maybe every 15 seconds or so, and missfires and pops when you try to move it. Opening the throttle in neutral sounds alright.
There's a ticking noise that sounds like it's coming right from the middle. We thought it might be the idle air control valve until we realized it was missfiring under load, too. The ticking sounds like a solenoid actuating and it'll tick twice randomly, but maybe 5-10 seconds between on average.
Any ideas?
qoncept is offline   Reply With Quote
Old 06-28-2011, 01:41 PM   #2
speedyredneck
Member#: 258291
2004 Impreza WRX
Subaru World Rally Blue
Here is an update in case anyone else is having a problem like this:
Just got a chance to work on this again. Re-did the timing multiple times, finally started before we it back together and it idled just fine, got it put back together, and it ran like it was before. Shut car off...unpluged MAF sensor, and it runs pretty well, hoping that is the only problem. We will be finding out soon.
speedyredneck is offline   Reply With Quote
Old 06-28-2011, 02:30 PM   #3
neversummer489
Member#: 153729
PSM Bugeye
Missing rod bearing??
What cam gears did you use? I haven't found any info on if wrx/sti gears are the same, as well as gear spacing from ej20/ej25 deck to deck heights, which may throw timing off.
neversummer489 is offline   Reply With Quote
Old 06-28-2011, 02:58 PM   #4
speedyredneck
Member#: 258291
2004 Impreza WRX
I didn't build the motor. I bought from one of the guys in our club. But the only difference between the 2.0 and 2.5 is the bore, not stroke.
1999 2.5 4-cylinder missfire Tbird Man Normally Aspirated Powertrain 10 10-10-2010 12:08 PM
Any 2.0/2.5 Hybrids using SZ49 or FP Green joeyd02 Subaru Conversions 2 01-02-2006 05:15 AM
2.0/2.5 hybrids sube-trex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-08-2005 01:31 PM
Day 5, almost 200 miles on 2.5 Hybrid, all is going well :) Davenow Subaru Conversions 17 06-26-2005 08:59 PM
