Old 04-19-2011, 04:09 PM   #26
murphy660
Member#: 255857
04 35r sti
Originally Posted by DutchOven View Post
So FastWRX's Rebuild kit is actually a centric kit but marked up because its for brembos.
Part number is 143.46018
If you google it, it's not $25 each.
very true!
i just got mine in the mail actually from partsgeek
figured i'd give it a try since i saw no cross-reference anywhere on the internet
murphy660 is offline   Reply With Quote
Old 06-29-2011, 03:35 PM   #27
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
lol affording it isn't the problem.. its just the fact that you're paying that much for rubber or whatever these things are made of
So, bump..but in case anyone was wondering: the piston boots (at least in the front, don't remember the rear) actually have a ring of metal inside the rubber for the large side (piston bore, small side is piston lip). I'm sure that ups the cost just a wee bit in comparison to run of the mill rubber boots you commonly find on sliding calipers.
OrbitalEllipses is online now   Reply With Quote
Old 06-30-2011, 11:42 PM   #28
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Angry
Bump for problems.
I'm in the middle of rebuilding my Brembos and ran into an issue. The 4th piston in my one of my fronts simply would not go back in, and neither would 3 of the 4 in the other front caliper. I've cleaned and recleaned the pistons and bores, soaked the seals, and lubed bores/pistons. The bleeders are off and there's no residual fluid to keep them pressurized.
What the hell am I doing wrong? I was feeling the bores with the seals in place and it seems like there's a slight lip at the top (inboard?) of the seal. If I had to guess I think the pistons are catching on the top of the seal but I have no idea why.
The two leading pistons are the same size right? And the two trailing pistons are identical as well? I'm at wits end and about to grab a c-clamp to get this done. I feel stupid.
Old 07-01-2011, 04:49 AM   #29
darmon225
Member#: 287148
When i can buy mines this information is very important for me..........i try to do the same........very good post..............
Regards.
darmon225 is offline   Reply With Quote
Old 08-05-2011, 10:09 PM   #30
the thing 314
Member#: 271194
2004 wrx sti
Does anyone by chance no what size the bleeders are on the front caliper? The bleeder is stripped out and the local auto parts store does not have the correct size bleeder. I called summit but they dont know if the one they have is for the brembo kit or if its just for the wrx brakes. I guess it might b helpful i have a 2004 sti. Calipers look exactly like the ones being rebuilt in this post.
the thing 314 is offline   Reply With Quote
Old 08-16-2011, 12:40 AM   #31
monsta121
Member#: 261534
Originally Posted by OrbitalEllipses View Post
Bump for problems.
I am pretty much running into the same problem. I bought the centric rebuild kit. I was able to get all the smaller pistons back in easily by just pushing them in with my hands but none of the bigger pistons go back in with the new seals. When I put the old seals back in the pistons went in easily but when I use the new seals they refuse to go in. Has anyone else had a problem with the centric kit? I bought another kit from oriely auto parts dont remember who the manufacturer of the kit is but i had the same exact problem. I think I will have to order the OEM kit from the dealer but was hoping to get some input before I spend $80 for a few pieces of rubber.
monsta121 is offline   Reply With Quote
Old 08-16-2011, 09:52 AM   #32
BlueSTI4Me
Member#: 34361
04.7 STI
Good info, subscribed.
BlueSTI4Me is offline   Reply With Quote
Old 09-13-2011, 07:49 PM   #33
Tut4u2
Member#: 40424
05 STi
Bleeder for the calipers is M10x1.0x30
If the seals aren't going in, make sure they are flush with the piston, use a good amount of brake fluid and apply equal force as you are pushing them in and they will go in; you are just pushing crocked on it (not trying to be insulting but I ran into the same issue).
Tut4u2 is offline   Reply With Quote
Old 11-16-2011, 01:45 PM   #34
avylyn
Member#: 178282
2004 Aspen White FXT
313awhp 349tq DB Super16g
Anyone tried ordering the kits from rockauto.com
CENTRIC Part # 14346018 Services One Caliper Front $9.34
CENTRIC Part # 14347008 Services One Caliper Rear $18.34
Let me know, really need these kits soon
avylyn is offline   Reply With Quote
Old 11-16-2011, 03:13 PM   #35
monsta121
Member#: 261534
The centric kit for the fronts does not work. the seal for the small piston fits fine but the seal for the larger piston is too big and they will not go in. I ordered the centric kit and no matter what I did I could not get the piston to go back in. Gave up and bought the OEM brembo rebuild kit from the dealer and they went right in on the first try.
Old 11-16-2011, 06:03 PM   #36
Tut4u2
Member#: 40424
05 STi
I didn't have any issue fitting the larger seal with the Centrics...shrug...maybe they made a bad batch.
Old 11-17-2011, 04:23 AM   #37
avylyn
Member#: 178282
Ok, I'll keep that in mind, but the rear is not a problem??
Old 11-17-2011, 08:23 AM   #38
monsta121
Member#: 261534
Yeah that may be what happened. The centric kit only costs like $15 so someone else should try and verify.
Never tried the rears. Maybe someone else can chime in on that.
Old 11-17-2011, 09:42 AM   #39
AspenScoob255
Member#: 217405
2006 WRX
Edit: I should have read the thread first...the info I gave was already in here...
AspenScoob255 is offline   Reply With Quote
Old 02-06-2012, 06:43 PM   #40
edmorl
Member#: 303042
I'm unable to fit 1 of the small piston's dust boot on each caliper. The piston is all the way in but the dust boot won't just pop in. Something I'm doing wrong ?
edmorl is offline   Reply With Quote
Old 02-06-2012, 11:47 PM   #41
Tut4u2
Member#: 40424
05 STi
Try fitting the dust boot over the piston first, then push the piston in so that its slightly still out of the caliper, fit boot into the caliper, then push the piston all the way in. Careful as you can easily rip the boot.
Old 03-12-2012, 10:47 AM   #42
sooblover
Member#: 132551
04 FXT
glad this thread is here! I have a leaky rear pass. side Brembo caliper. Seems like it is coming from the seals. I'm going to try the rear re-build.
sooblover is offline   Reply With Quote
Old 03-12-2012, 11:02 AM   #43
sooblover
Member#: 132551
04 FXT
Question on the leak I have goin on:
-These were rear calipers I got that were powder-coated then rebuilt with new seals.
-Had them stored carefully in a box for quite some time (9-ish months) with no fluid in them. (maybe the seals dried up during this time?)
-Then installed them and they ran great for ~4 months great braking performance NO leaks.
-Then I noticed my rear pass. wheel was "wet" inside during a dry week with NO puddles. Looked like brake fluid.
-Took the wheel off, cleaned everything with bio-degreaser, rinsed, and re-installed wheel and let it sit over night.
-In the morning I found that brake fluid seemed to be slowly leaking from behind the outer brake pad.
-Not coming from the bleeders.
-Not coming from the brake line.
Is this clearly indicative of bad seals? Could the piston crack? I really hope its not from inside the caliper body...
I have not raced the car or heated the brakes up significantly.
Anybody ever have anything similar?
Any input/ideas would be great.
Thanks guys!
Old 03-13-2012, 11:44 AM   #44
sooblover
Member#: 132551
04 FXT
Anybody?
Old 03-13-2012, 05:41 PM   #45
DutchOven
Member#: 220629
2010 White WRX Hatch
2015 White WRX Limited
If it's not coming from the banjo bolt nor the bleeder, then most likely its coming from one or both of the piston seals. This could be due to a misalignment or improper seating of the seal. You should take it apart again, inspect, and rebuild with new seals.
DutchOven is offline   Reply With Quote
Old 03-14-2012, 08:54 AM   #46
sooblover
Member#: 132551
04 FXT
arrite cool thats what i'm doing. Wish me luck! Thanks!
Old 03-24-2012, 03:02 PM   #47
edmorl
Member#: 303042
I took the piston out, and tried to put the seal in by itself, but the seal won't even "clip" in like the otheres, seems like it's too big for the hole ? I have 2 of these like that. All the other fit fine.
wrong size dust boot ?
Old 03-24-2012, 09:15 PM   #48
sooblover
Member#: 132551
04 FXT
Thanks guys!
Put a new seal set into this caliper and all seems to be fixed so far. Just figured i'd update since i asked...
Old 03-25-2012, 08:09 AM   #49
25rsti
Member#: 166324
I broke down my front and rear Brembos thanks to this thread. Sent them out for powder coat and will be ordering a new re-seal kit this week. Can't wait to get everything back and put them together. Thanks Tut4u2!
Old 05-02-2012, 06:49 PM   #50
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
The Centric rebuild kit DID NOT work for me. I started with the front and could not get the pistons in, so I did not continue further and got OEM Brembo kits.
WiBal on the iPhone is way ****ed up. They are WAYYYYY more purple than the pic depicts.
Before:
FS or FT: 04 sti brembo Front and Rear calipers and rotors. jbark1018 Suspension/Brakes/Handling 18 06-11-2011 03:18 PM
FS : Brembo front and rear calipers and rotors 5x114; excellent condition never tracked syoung0298 Suspension/Brakes/Handling 28 06-20-2010 10:30 AM
06 STI Brembo Front and Rear Calipers, Rotors, and Pads akito Suspension/Brakes/Handling 2 06-19-2010 05:19 PM
WTB: Your STi brembo front and rear calipers eclip5e NESIC Private Classifieds 19 04-29-2006 02:28 AM
FS: 04 STi Brembo Front and Rear Calipers netzr0 Private 'For Sale' Classifieds 3 08-06-2004 03:01 AM
