Old 05-02-2012, 09:03 PM   #51
USAFSTI
Member#: 224720
2005 Impreza WRX STI
Originally Posted by vision.dynamix
The Centric rebuild kit DID NOT work for me. I started with the front and could not get the pistons in, so I did not continue further and got OEM Brembo kits.
WiBal on the iPhone is way ****ed up. They are WAYYYYY more purple than the pic depicts.
Before:
I'm looking to do the same color. Where do people get the new stickers from?
USAFSTI is offline   Reply With Quote
Old 05-02-2012, 09:08 PM   #52
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
I produce them in house.
Old 05-02-2012, 09:33 PM   #53
USAFSTI
Member#: 224720
Would you be willing to make and sell some?
Old 05-03-2012, 09:39 PM   #54
25rsti
Member#: 166324
I got mine powder coated on.
Old 05-03-2012, 11:19 PM   #55
monkiboy
Member#: 202958
2008 wrx
me, too. my powdercoater used a stencil and did it with a couple layers of clear over.
monkiboy is offline   Reply With Quote
Old 02-23-2013, 12:27 AM   #56
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Well im almost sure that one of my pistons in the front has froze so i ordered the brembo kit and planning to overhaul my front brembos.
One question i have has to do with the part where you use a air gun to push out the pistons. Question is, can i keep the brembos still attached to the brake line and push them out by pushing the brake pedal and then disconnect them?
I don't have a air gun on hand.
BlackFighter is offline   Reply With Quote
Old 02-23-2013, 12:32 AM   #57
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
You could but it would be incredibly messy.
Old 02-23-2013, 12:50 AM   #58
BlackFighter
Member#: 193940
2004 WRX STI Black
Yaa i figured it would
Old 02-23-2013, 01:35 PM   #59
paulpat
Member#: 237145
02 WRX
12 FXT
Air compressors are 100 at any home improvement stores. Fyi
paulpat is online now   Reply With Quote
Old 02-23-2013, 01:36 PM   #60
paulpat
Member#: 237145
02 WRX
12 FXT
It's a great investment
Old 02-23-2013, 07:20 PM   #61
HuckFinn
Member#: 298502
I'm working on freshening up some STI Brembo calipers and some of the bleeder screws and dust caps could stand to be replaced. Has anyone had luck sourcing replacement bleeder screws and bleeder dust caps for 2008+ STI Brembos? I found speed bleeders that should fit, but I rather stick with the stock type bleeder screws. I've found some conflicting info on whether the black 2008+ STI Brembos use the same bleeder screw as the older goldies, so any info on that would be welcomed as well.
HuckFinn is offline   Reply With Quote
Old 03-19-2013, 10:55 PM   #62
BlackFighter
Member#: 193940
2004 WRX STI Black
Just finished the rebuild, and wow. I think i never had brakes so smooth before. Unfortunate, don't know how, maybe turned in to the hulk for a sec, but i pulled out the threads with the bolt. My passenger top bolt seized in the threads and i pulled and puled and after it was moving little by little it finally fell out. Looking at the bolt i realized the alum threads were melted in the bolt thread.
Got the helical coil kit and put a new thread in and whala.
P.S. The hardiest part of this rebuild is taking of the brambos off. The rebuild itself was very easy.
Old 07-17-2013, 05:21 PM   #63
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Just wanted to say thanks for this write up. I'll be having this tackled soon enough.
Old 08-27-2013, 07:24 AM   #64
Caebezl
Member#: 346357
2004 Subaru WRX STI
Burple
Would you mind putting the pictures back up please
Caebezl is offline   Reply With Quote
Old 12-08-2013, 01:49 PM   #65
SynME
Member#: 282245
2008 Impreza WRX
Graphite
@Tut4u2: Dude, thanks a ton for the walk-through. I had to rebuild my calipers as I found the inner-right pad had been grinding away at the rotor (DBA-5000) so bad the slots were no longer there. Waiting on the replacement rotors and pads, but the calipers are fully rebuilt with new seals.
A couple notes:
1. It was easiest for me to remove the pistons one at a time using blocks of wood to retain the other three. I gave the targeted piston enough room so that the air pressure would drive the piston far enough to push past the boot. It was easy to remove the piston, then I was able to just pull the boot out with my fingers. Takes a bit of constant force to break the seal loose, but it was WAY easier than trying to dig them out.
I then removed the inner seal with an o-ring pick (cheap, and designed to remove vacuum seals, so no chance of scaring the sealing surface.) Wiped the excess fluid and debris from the piston and cylinder and reinserted the piston. Without the seal and boot, it slides smooth by hand.
I then reconfigured the blocks to target anouther piston 'till all four were removed.
2. This was a great opportunity to fully clean the caliper and pistons with detergent and water using a plastic bristle brush. Except for a few choice corners, the caliper is build-up-free and had no chance of getting debris falling inside the fluid channels during the rebuild. After fully rinsing with water, I used compressed air to dry the parts. You could even put the parts in the oven at 250 F to bake out the water if you so chose, but the parts are designed to be exposed to water, and any trace water inside the channels will be disolved into the brake fluid and purged out when the brakes are bled.
SynME is offline   Reply With Quote
Old 04-09-2014, 04:32 PM   #66
tcho
Member#: 287412
2009 WRX
Dont waste your money on mach v's rebuild kit. Rockauto.com sells them for $6ish For each side. They use the exact same centric part numbers and I bought both mach v and rockautos rebuilds and are identical down to the mesurments and quality
tcho is offline   Reply With Quote
Old 07-28-2014, 02:17 PM   #67
goleee33
Member#: 301701
2012 WRX 5-Door
So I have seen mixed reviews on Centric Kits. These are confirmed to work with no issues? Would rather not spend an additional 80 for fronts and rears each. . . if i dont have to. Thanks!
goleee33 is offline   Reply With Quote
Old 07-28-2014, 03:06 PM   #68
SubieEngineer
Member#: 208152
2007 STI LTD #576
UGM, FOR SALE!!!
I did it once, and would not use the Centric kit again. With the Brembo seals, they go in very easily. I had to essentially beat the piston back into the bore with the Centric seals. I had a friend that had to do the same for his Brembos, too. :marcus: Fast forward a few months and the Centric seals started leaking, just to add insult to injury.
SubieEngineer is offline   Reply With Quote
Old 07-28-2014, 06:29 PM   #69
goleee33
Member#: 301701
2012 WRX 5-Door
Thanks for letting me know! Ill see if any of my friends that work at a subaru dealer can get me connected with some rebuild kits. Thanks!
Old 07-28-2014, 08:17 PM   #70
chanomatik
Member#: 159474
SNOSLO
Over a year later and I STILL have not had this tackled. The calipers have been waiting to get painted since about late December of 2013. They were finally painted in April or so, but painted incorrectly. Now I've just been waiting for a repaint. I'll probably have a shop rebuild these. I have the genuine Brembo rebuild kit.
Just saying thanks again for this thread.
Old 07-28-2014, 08:23 PM   #71
Tut4u2
Member#: 40424
05 STi
I'm glad people got some use out of this :-)
Sent from my 831C using NASIOC mobile app
Tut4u2 is offline   Reply With Quote
Old 12-23-2014, 02:45 AM   #72
bunz559
Member#: 388585
2015 wrx base
ISM
Hope to do this soon. Still need to find a rear caliper then send em off for powder coating.
bunz559 is offline   Reply With Quote
Old 12-23-2014, 08:24 AM   #73
jam007
Member#: 174706
2008 LGT-B
Default DIY Brembo Front and Rear caliper rebuild
Sent from FaceSpace
jam007 is offline   Reply With Quote
Old 07-17-2015, 05:02 PM   #74
rallyracersti
Member#: 147522
2015 wrx
Wrb
Fantastic write up, thank you
rallyracersti is offline   Reply With Quote
Old 01-28-2016, 01:04 AM   #75
tgalla106
Member#: 439139
2004 Subaru STI
Default DIY Brembo Rebuild
Great pictures! I have never done any sort of caliper rebuild in my life but I got the dreaded information my Brembo calipers on my 2004 STI have seized. I am going to use this write up as my guide.
It sounds like most users would recommend to buy the Genuine Subaru Brembo Rebuild kit?
The Centric kit sounds like its harder to do and less reliable?
Thanks,
Tom
tgalla106 is offline   Reply With Quote
FS or FT: 04 sti brembo Front and Rear calipers and rotors. jbark1018 Suspension/Brakes/Handling 18 06-11-2011 03:18 PM
FS : Brembo front and rear calipers and rotors 5x114; excellent condition never tracked syoung0298 Suspension/Brakes/Handling 28 06-20-2010 10:30 AM
06 STI Brembo Front and Rear Calipers, Rotors, and Pads akito Suspension/Brakes/Handling 2 06-19-2010 05:19 PM
WTB: Your STi brembo front and rear calipers eclip5e NESIC Private Classifieds 19 04-29-2006 02:28 AM
FS: 04 STi Brembo Front and Rear Calipers netzr0 Private 'For Sale' Classifieds 3 08-06-2004 03:01 AM
