Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 07-05-2002, 02:58 AM   #1
KillerRex
Member#: 15675
'92 R32 Skyline GTR
Default Max power potential from stock turbo.
What's the max HP you can obtain with the stock turbo with every bolt on/mod imaginable? I'm talkin about a BPU+++ WRX.
KillerRex is offline   Reply With Quote
Old 07-05-2002, 09:45 AM   #2
z&cobb
Member#: 12344
2002 2JC
blue
Default Re: Max power potential from stock turbo.
Is dinitrogen monoxide part of the imagining?
z&cobb is offline   Reply With Quote
Old 07-05-2002, 09:53 AM   #3
z&cobb
Member#: 12344
2002 2JC
blue
Default Re: Re: Max power potential from stock turbo.
Whops! I see you are already into the stuff.
So how about a TXS stage 3 plus N2O. Stage 3 keeps the stock turbo. This uses the cast uppipe and the TXS intercooler. Should be a natural for making use of N20. Perhaps some dyno data will be available soon.
Old 07-05-2002, 11:21 AM   #4
mrtrex
Member#: 12223
2005 WRX
If you want to blow up your motor being stage 3 is running 99% duty cycle with out nos. Plus it is a FP turbo.
mrtrex is offline   Reply With Quote
Old 07-05-2002, 11:38 AM   #5
Ijustwannagohome
Member#: 20902
2002 REX
99% duty cycle on the injecotrs? If so, who is toos ay he cant upgrade the fuel side. He just said stock turbo.
Ijustwannagohome is offline   Reply With Quote
Old 07-05-2002, 12:26 PM   #6
S-1
Member#: 10842
07 2.5i Wagon
i haven't seen anybody making more than 235-245 whp with the STOCK turbo (not including the FP upgrade) I'd say that these numbers would be just about it with the td04 on the rex.
S-1 is offline   Reply With Quote
Old 07-05-2002, 01:08 PM   #7
smacksube
Member#: 4067
01 2.5 rs
from my understanding the wrx turbo is the stock mitsu turbo on the newer gs-t's. If that's the case then I do believe that the DSM guys top at about 330 - 350 hp with that turbo....however, I've heard the injectors and ecu's on subarus are weak and won't handle that. But you're prolly looking at somewhere in the field of low to mid 300's at the crank.
smacksube is offline   Reply With Quote
Old 07-05-2002, 03:15 PM   #8
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
Post dsm
The turbo eclipses have garrett t25's, and i hear they top out in the low 300's, if they do as much as is reasonably possible.
I'm pretty sure the wrx has a different turbo, dont know what kind though. I would like to know, so, little help? How much bigger is it than the smallish t25?
edit: thats 300 flywheel hp
AndyRoo is offline   Reply With Quote
Old 07-05-2002, 03:35 PM   #9
JenisonWRX
Member#: 6049
02 WRX & 99 RS
I thought they had TD05's
JenisonWRX is offline   Reply With Quote
Old 07-05-2002, 04:32 PM   #10
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Nope. 1G has a TD05-14B, 2nd gen has a T25.
The US WRX has the Mitsubishi (ironically ) TD04-13G. Totally different turbos.
TypeC is offline   Reply With Quote
Old 07-05-2002, 08:42 PM   #11
z&cobb
Member#: 12344
2002 2JC
blue
Check the txs page. There is a new concept for Stage 3. You haven't been keeping current It is the entry that has the TBD next to it. Plus wet nitrous takes fuel from the pump, which has enough to serve the 5th injector.
Old 07-07-2002, 06:05 PM   #12
Z1 Performance
Member#: 9327
About 275-300 is all you can realistically expect and still keep a safe power level - that should translate into solid low 13's (13.0-13.25) on a mtoro without NOS, and other essentils (hoses, race gas, fuel pump and some form of fuel control).
The WRX uses the same turbo as 1 unit from the 3000 GT VR4 (TD04, 13G wheel). The WRX uses "L" version (TD04L), but I am not sure what this designates.
1G DSM's use TD05 turbos, 14 B wheels (in the US at least, some JDM cars used small 16G wheel). Auts use a slightly smaller turbo to give comparable spool and similar performance to the 5 speed models
2G cars use a turbo that is so small it is not even worth mentioning (T25's)..again, 5 speeds and autos use a slightly different spec to keep performance closer to one another.
The WRX uses a Mitsubishi made turbo (Mitsu is a HUGE OEM supplier of parts such as turbos), but the flange bolt spacing on teh intake and exhaust sides is 100% unique to Suabru..no otehr car uses it.
adam
Z-1 Performance
Z1 Performance is offline   Reply With Quote
Old 07-07-2002, 09:07 PM   #13
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
adam
Z-1 Performance
Actually, the 3000GT uses the TD04-9B
Conduit is offline   Reply With Quote
Old 07-08-2002, 12:07 AM   #14
NotoriousWRX
Member#: 9026
I would guess ~ 260-270 AWHP after seeing the numbers from my car. I still have a few more parts that can be bolted on and I'm also on the stock, untuned ECU.
I will have a better idea, as I have made some changes and will be tweaking the AF mixture with a S-AFC by next weekend, and I'll have new dyno numbers also.
NotoriousWRX is offline   Reply With Quote
Old 07-13-2002, 07:20 PM   #15
NotoriousWRX
Member#: 9026
Just wanted to post an updated figure of power for this thread. I just dynoed 243.6 AWHP.
I Need More Power From Stock Turbo Sti sexysti05 Newbies & FAQs 20 10-10-2008 09:06 PM
Power remaining in stock turbo? verruckt32 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 06-08-2006 03:39 PM
Power difference from stock 3rd cat to high-flow/catless - VF22? shoooter_j Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-08-2005 05:17 PM
does the sti intake manifold make any power with the stock turbo? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-06-2003 01:33 AM
Top End Power mods W/stock turbo FuZZyLoGiC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-17-2002 09:41 PM
