Old 12-18-2010, 01:25 AM   #1
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Default '11 WRX hard shifting into 4th gear?
Ok so I noticed that when I'm driving normally and shifting slowly, I can get into 4th gear very easily. However I noticed that both today and yesterday, if I am running my WRX a little hard and shifting around 3.5-4k, it will be very hard to get into 4th. I may have even misshifted into 2nd because of this but I'm sure the rpms only jumped to 5-6k. Anyhow, does shifting feel change depending on how fast you are going? I'm going to be taking my WRX into the dealer due to my passenger side door speaker buzzing and I might as well tell them about this problem too (probably going to skip the part about me misshifting it). I just wanted to know if this is my cars fault or just because I suck at shifting T.T Because I swear, it is impossible to get my car into 4th until my RPM drops down. So strange x.x
xabre1200 is offline   Reply With Quote
Old 12-18-2010, 08:17 AM   #2
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
tell the dealer. it should shift smoothly in every gear.
424wrx is offline   Reply With Quote
Old 12-18-2010, 08:23 AM   #3
iRazor
Member#: 257035
2017 WRX/STi
Pure Red
same with my 08 :/ it feels like it gets snagged while shifting from 3rd to 4th and really have to slam it (even under normal driving) only happens once in a while tho
iRazor is offline   Reply With Quote
Old 12-18-2010, 10:20 AM   #4
pluton
Member#: 248216
2009 impreza wrx
dark metallic gray
1-2 requires some effort.
3-4 is smooth as butter.
but before you go to the dealer I suggest you examine closely how you shift from 3rd to 4th. I'm more likely to believe there is driver error than a problem with the tranny. maybe you are getting snagged on a gate or you're not pulling back straight etc.
pluton is offline   Reply With Quote
Old 12-18-2010, 03:07 PM   #5
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Yeah it feels like it's getting snagged by something. But its strange because I don't feel it do that when I'm driving slowly. I'll try to examine how I shift from 3-4 under harder driving.
Old 12-28-2011, 01:43 PM   #6
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
Sorry to bump an old thread, but I searched and this is what I found.
OP, did you ever figure out what the issue was? I just noticed this today--my second day with the car. Car has 90 miles on it and it is doing exactly as you described. Not a newb to stick, but not used to this car either.
I'm afraid I am going to end up in 2nd.
bicycle_wreck is offline   Reply With Quote
Old 12-28-2011, 09:51 PM   #7
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
No problem. Yeah the problem has gone away by itself. I was having the issue even after I swapped in a kartboy short shifter, front/rear shifter bushings but I guess after time the problem went away. Just let it break in for a few weeks first. If you still have the problem take it into your dealer.
Old 12-28-2011, 09:53 PM   #8
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
Will do. Thank you for the reply!
Old 12-29-2011, 09:49 AM   #9
invaderzim
Member#: 201991
2011 wrx dom3'd
satin white pearl
it was around 22F this morning and my '11 shifts into all gears very smoothly. when I first got the car it was hard to get it in reverse sometimes but it's broken in now so no problems.
invaderzim is offline   Reply With Quote
Old 12-29-2011, 09:58 AM   #10
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
Reverse has been an issue in every MT car I've ever driven, especially my old CJ-7. My new WRX is no exception, but I just pop it in first and then back to reverse and it always goes in, just like all my previous vehicles.
However, the fourth gear problem feels totally different, it's just like I hit a brick wall and there is no slot to go in until the revs come down. I'm just going to keep an eye on it as the OP suggested. My dealership is legit, so I am in capable hands should I decide take it in. I'm still getting used to the car, so that may be a factor in my case.
Old 12-29-2011, 10:14 AM   #11
shamrocker
Member#: 258219
2011 WRX Limited
WR Blue Pearl
I'm still experiencing the same problem, too. I've got about 11,000 miles. I haven't mentioned it to the dealer yet, because it doesn't happen very often. It is a little scary because it's usually at high revs and it will go into 2nd instead...
shamrocker is offline   Reply With Quote
Old 12-29-2011, 02:28 PM   #12
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
I can't get into reverse sometimes as well. Just put it in 2nd and then try reverse. Usually works.
Old 01-01-2012, 12:03 AM   #13
AJS DAD
Member#: 280062
2011 WRX Base
Dark Gray Metallic
Getting into reverse can be done by "double clutching". I have the same issue. Yes going into first and then reverse matches the syncros, but so does clutching into Neutral, then clutching and going into Reverse.
AJS DAD is offline   Reply With Quote
Old 01-01-2012, 02:50 AM   #14
Xtream
Member#: 299267
2013 BRZ
My 05 STi does this. It doesn't go into fourth no matter how fast I'm going unless I kind of slam it into fourth. Once I get it in it has no problems until I stop driving for an hour or so then I have to do it again.
Xtream is offline   Reply With Quote
Old 01-13-2012, 10:18 AM   #15
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
I called my dealership, and I'm taking the car in for this on Monday. It did it again this morning under very gentle driving conditions, very cold out. I've never had this problem on any other M/T car, so while it could be me, I'm beginning to think not. Car has 503 miles.
Old 01-17-2012, 07:41 AM   #16
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
Took the car in yesterday. Couldn't replicate the problem, but the service manager was very receptive and made a record of the complaint. We shall see how it goes.
Old 01-17-2012, 12:14 PM   #17
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
man, would people just **** about reverse already. EVERYBODY knows it's hard to get into.
op, 3-4 is and always was easy for me. since the dealer brushed you off, try some kartboy bushings. also, i don't know if you have a short shifter already, but if you do make sure you tighten the linkage bushing to spec. if you overtighten, it makes it significantly more difficult to shift through gears.
edit: wow, nasioc bleeps ****
edit edit: could also be your synchro's "breaking in". my second gear was hard to downshift into for a turn but it became smooth as silk after a while
edit edit edit: this should be in the transmission section.
Nimbus09 is offline   Reply With Quote
Old 02-29-2012, 03:28 PM   #18
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
Well, unfortunately the difficult 4th shift is back. It was gone for about 1,200 miles. Car now has ~1,800 miles on it.
I can replicate it, somewhat, when the car is sitting still, idling, with my foot on the clutch. I've noticed that if I just go from neutral to 3rd to 4th, it goes right in no problems. However, if I put the car in 2nd and then to 3rd to 4th, it snags almost every time.
That seems like a synchro issue.
Old 06-07-2012, 07:12 PM   #19
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
Just as an update, I haven't experienced this problem in quite awhile. Thinking it may have been the synchros breaking in. Not really sure, don't really care as long as it stays gone. Car now has ~4,500 miles.
Old 06-07-2012, 09:50 PM   #20
McKenzie83
Member#: 207896
11 STi limited
Default Be weary...
The Tranny takes some time to break in, cocktails can be dangerous, cold ambient temps especially below freezing keep the tranny from heating up to a good operating temp for a bit. Ditto on the comment about guys who hulk on the linkage bushing when they replace it, don't do that! If you're having shifting issues when you're driving rowdy then slow it down and learn your timing. Also, no mention of rev matching in this thread that I saw but always rev match when down shifting...it's a very cost reducing art.
McKenzie83 is offline   Reply With Quote
Old 06-07-2012, 10:50 PM   #21
pleiades276
Member#: 320403
The only gears on a 2011 that require effort are 1st, when downshifting from a rel high speed (20-30mph) and reverse (bc of the square cut gears). One misshift isnt going to hurt your transmission, unless it was very bad and you have chunks of metal flying around in your tranny but from what you've said it might just be something with the synchro on 4th. Def have the dealer look at it and don't let them talk you into paying anything if your still under powertrain 36k.
pleiades276 is offline   Reply With Quote
Old 06-07-2012, 10:54 PM   #22
sweetsatin
Member#: 304578
2012 WRX Limited
Satin White Pearl
Why would you ever downshift to first at 20-30 mph
sweetsatin is offline   Reply With Quote
Old 06-08-2012, 03:05 PM   #23
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
I rev match every time I downshift. However, the problem the OP and I were having was on the upshift into 4th from 3rd. The shifting issue I was experiencing was not from being hamfisted or getting too excited--it just wouldn't go into 4th under certain conditions.
What are you on about? Don't downshift into 1st at 20-30mph unless you really just hate your shift fork.
And I really wish people would stop talking about reverse. The thread is about the specific problem of getting into 4th from 3rd when the drivetrain is under load.
Third, the powertrain warranty is 5 years or 60K miles, whichever comes first--not 36K miles.
I have no idea. SMH.
Old 06-08-2012, 10:58 PM   #24
VisBits
Member#: 300773
08 STI
Black Pearl
I have 29k miles on my 08 and I feel a double click going from 3rd to 4th sometimes.. it fools me thinking I'm in 4th but I'm not.
I had my trans changed over to motul gear 300 a few months ago.. can't tell if it made it worse or better.
I've learned to just tug into 4th a little more firm.. its a pretty big transmission, requires a little more effort than the flimsy low hp stuff.
VisBits is offline   Reply With Quote
Old 06-08-2012, 11:04 PM   #25
20wrx09
Member#: 207417
2009 WRX
td06sl2-20gtx 413/423
ive had this same problem with mine. when i get on the car hard and its the only time it will do it. its weird, sometimes it will go in fine even beating on it, and sometimes it "locks" me out of 4th
20wrx09 is offline   Reply With Quote
Grinding noise when shifting into 4th gear? Help cvalianos02 Newbies & FAQs 24 10-05-2010 04:20 PM
shifting into 4th gear issues WheelieMonster Transmission (AT/MT) & Driveline 21 08-17-2009 03:52 PM
High Pitch Grinding Sound When Shifting Into 4th Gear mcrawford Newbies & FAQs 3 10-09-2007 01:10 PM
Hard shifting into 4th. tunedlevin Transmission (AT/MT) & Driveline 0 10-20-2005 10:10 PM
Hard time shifting into 4th and 5th jsmithjr732 Transmission (AT/MT) & Driveline 4 01-08-2003 05:05 PM
