Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Old 12-18-2010, 10:26 PM   #1
tksautos
Member#: 267527
04 wrx sti
Default Phase 2 2.5L into an STI swap!
Hey guys, I am a newbie to the forums and was hoping that a few of you could give me some advice and input. I own a car lot and recently purchased an sti at auction that does not have an engine and is also missing the ecu and turbo parts.
Over the years i have compiled a few engines here and there and happen to have a 2.5L engine thats a phase 2 from either a 99 legacy gt or a 2.5 RS. The engine is built, with arias pistons, manly arms, etc. good for 8:1 compression. My hopes were that i could throw this into the STI and get to keep it for myself instead of having to part it out and make some money.
So my question is, will this 2.5 fit into the 2005 sti that i recently purchased? Will it line up right with the stock transmission? Any of the engine accessories need drastic alterations? Any advice would be great.
Im debating on whether or not this is a likely possibilty or am i better off buying an actual sti motor. Hopefully i can use this engine and then buy the turbo components seperately and save myself about 2-2.5 grand and have a built engine in it .
I am guessing the engine will fit, as ive read of people putting sti motors into other subarus, but im just trying to get a feel for what i am getting myself into.
Thanks in advance for any suggestions and advice!
tksautos is offline   Reply With Quote
Old 12-19-2010, 12:44 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
From what I've gathered, issues you will run into are the up pipe clearing the corner of the passenger cylinder head and the lack of AVCS function on that phase II SOHC EJ25. Ideally, you'd source a set of STi heads to bolt onto the block and cure those 2 issues in one step.
Mechanically, everything bolts up, use the STi flywheel and clutch. Use the STi intake manifold and engine harness, add a 2nd block vent and drop it in.
Jay
Old 12-19-2010, 06:06 PM   #3
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
its more work to make it run poorly, than to make money selling it all
feint05 is offline   Reply With Quote
Old 12-20-2010, 09:21 AM   #4
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
quick list of why not:
no holes to mount coil on plug
no oil return
different pick up pattern on the cam trigger
who gas swapped a 2.5L into an L or OBS? OSUBeaver Subaru Conversions 33 08-26-2010 06:37 PM
Planning an STI swap into 06 2.5i SubiFTW Subaru Conversions 5 09-30-2007 02:49 PM
Impreza 2.5 into an STi? hatch'd06 Subaru Conversions 13 11-27-2006 09:27 PM
dropping in a 2.2 or a 2.5 ltr into an older impreza with a 1.8 BeAn Normally Aspirated Powertrain 2 03-22-2001 12:18 AM
