Old 12-20-2010, 12:38 AM   #1
SubieLuvin
Member#: 248202
2013 WRX Sedan
Default How can i get brembo's to fit 17's?
This may seem like a dumb question but it is worth a shot. I have a chance to trade my 17 inch rims for some stock bbs off an sti straight up for mine, a great deal in my favor...problem being his brembo's are a bit too big for my wheel. Is it possible to get a spacer that will allow it to clear? or am i sol? id love to get these wheels if at all possible any help is appreciated
SubieLuvin is offline   Reply With Quote
Old 12-20-2010, 12:52 AM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
your wheel specs?
yes spacers will get you enough clearance for the brembo calipers, but how big a spacer he'll need none of us know...anything bigger than a 3mm spacer will require extended studs unless you go with spacers with built-in studs. only issue with built-in studs is if the spacer isn't thick enough, the oem studs will have to be trimmed so they don't hit the hub of the wheel.
still worth it to you?
Old 12-20-2010, 10:41 AM   #3
SubieLuvin
Member#: 248202
2013 WRX Sedan
Yeah it could work out even if studs need to be trimmed the guy trading is very savvy with working with metal does great welds and body work so it may not be too bad. Figuring out my wheels specs will be tough because they are generic I'll post pics to see if anyone can identify them
Old 12-20-2010, 11:00 AM   #4
neonglh
Member#: 127886
Installing wheel studs is easy, and can be done on all 4 corners in under an hour, with hand tools. Longer studs and wheel spacers are 100% as safe as stock wheels and stock studs too, so there are no worries there.
neonglh is offline   Reply With Quote
Old 12-20-2010, 02:33 PM   #5
nhat
Member#: 140163
03 STi
hellaflunctional
it's not the amount work, it's the amount of money required to get a set of wheels to fit...
Old 12-20-2010, 10:28 PM   #6
Y_I_K_E_S
Member#: 159449
2005 WRX STi
"Ali"
You'll probably sink $100 or so into longer studs plus another $40 for the spacers.
I'm basically just guessing on costs here but I'd say thats relatively close to what it'll cost you.
Y_I_K_E_S is offline   Reply With Quote
So how can I get girls to like me? rice h8r Off-Topic 100 07-14-2006 08:24 PM
Can not get intercooler to fit. Blue_dragon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-13-2005 08:36 AM
18" 245's and 255's.. How do you get them to fit?? SLKWrx Tire & Wheel 11 05-24-2004 11:34 AM
Now how the hell can I get these to fit.. Fitz New England Impreza Club Forum -- NESIC 9 12-15-2002 11:26 PM
