Old 12-20-2010, 04:50 AM   #1
Wunder
Member#: 260232
2005 FXT
Default stock rims, which tires?
Should I go up one/two sizes on tires if I'm sticking with stock 16" rims? It's okay as long as I have the same width, correct?
Wunder is offline   Reply With Quote
Old 12-20-2010, 06:20 AM   #2
stidoc
Member#: 147579
It's okay as your total outside diameter is the same as stock. This keeps your speedometer calibrated.
If you go to Tire Rack's site and put in your vehicle, it will give you the OE tire. Click on "specs" of the OE tire and you can find the outside diameter then just pick a tire with the same or very close outside diameter, like within 0.2".
stidoc is offline   Reply With Quote
Old 12-20-2010, 03:48 PM   #3
Mr.Sparkle
Member#: 83725
2015 WRX
you can use this site to find the closest diameter to stock while also increasing width.
I had 225/50 16 on my stock wheels which is only .1% difference in diameter.
Mr.Sparkle is offline   Reply With Quote
Old 12-20-2010, 04:20 PM   #4
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
what are your goals for your car? street car or some off-road stuff? I ask because you mentioned going up in size and keeping the same width; most people go "up" in size to increase the width of the tire and thus more contact patch and more grip. If this is the case, going up one or two sizes (from 215 to 225 or 235 width) with same ratio number (XX in 215/XX-16) should be fine. I definitely recommend you do the calculations to figure out the diameters and their increase/decrease compared to OEM size. Then go with the one that is closer to the OEM diameter.
kenliu84 is offline   Reply With Quote
Old 12-21-2010, 06:25 PM   #5
Wunder
Member#: 260232
2005 FXT
Thanks for all the help guys! My plans are to start hitting the dirt a little so I'm just trying to figure out what I should go with.
WTT: stock rims and tires for snow tires and steelies SickREX NESIC Private Classifieds 6 10-28-2008 04:45 PM
WTT: stock rims/new tires for 17" aftermarket rims/tires + cash sovietjet Private 'Wanted' Classifieds 0 01-20-2006 02:32 PM
WTB 05 16" WRX stock rims & tires or 06 17" WRX stock rims & tires facs Vancouver Impreza Club Forum -- VIC 3 11-29-2005 01:41 AM
So.Cal..stock rims & tires/stock bov/ stock 6 changer/ sony clie peg-ux50 for sale swift2fly Private 'For Sale' Classifieds 5 09-20-2004 05:41 PM
17 x 7 rim - which tire size for track? fastwrx Motorsports 4 12-15-2002 10:53 PM
