Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Closed Thread
Old 03-04-2011, 03:32 PM   #151
jdblock
Member Sales Rating: (8)
Member#: 235211
2004 STi
Looks like you might be working on the plumbing too. Or next. Looks good.
jdblock is offline
Old 03-04-2011, 04:54 PM   #152
KillerBMotorsport
Vendor Sales Rating: (43)
Member#: 198281
2005 WRX/STi
WRB of course
^ That's true. I've got all the oil/water lines ready to go too, but likely won't plumb them until the turbo is fixed to the manifold/DP. The passenger side AVCS line will be completely replaced and the 'T' for the turbo oil feed will be off the front. Coolant will still be coming from the rear supply unless someone can convince me of doing it another way.
__________________
- Highly Advanced and Full of Awesomeness - Patent Pending
vs.
V2 High Performance Aluminum
Brushed & Polished Delrin Shift knobs!
KillerBMotorsport is offline
Old 03-04-2011, 05:20 PM   #153
jdblock
Member#: 235211
2004 STi
The coolant tube that feeds the water/oil heat exchanger. It comes out from behind the coolant thermostat and runs under the crank pully. Seems like it would be simple enough to plumb the turbo into there. Benifit is not having a long soft line that isn't easily reached (one of the last things you need at a race track).
jdblock is offline
Old 03-04-2011, 06:22 PM   #154
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I'll look into that routing. My only concern is that supply line would be going over the header. I might not matter.
I've not seen anyone plumb coolant to the WG, on a street car. Anyone seen or heard of any data that makes this worthwhile?
__________________
vs.
Old 03-04-2011, 09:33 PM   #155
jdblock
Member#: 235211
2004 STi
The rear supply comes out next to where the stock up pipe is, so I don't think it would matter either.
I've heard and discussed the reasons behind TiAL's watercooled ewg, and I think you should (need to) hook them into the cooling system when running big power over a longer time, like circuit tracks. I've heard of horror stories of blowing engines due to super heated exhaust gas, and the diagphram inside (the ewg) expanding and not being able to open when it needed to. For a street car it wouldn't hurt for some prevention especially if you see the track now and again. How many people drive around with oil-coolers everyday? I'm not sure what people do for drag cars since I don't really rock the 1320.
ahm, got any more pics?
jdblock is offline
Old 03-07-2011, 12:08 PM   #156
OrbitalEllipses
Member Sales Rating: (19)
Member#: 178811
2011 White Corolla
Over 400hp
Originally Posted by KillerBMotorsport View Post
Nothing too exciting, just laid in the I/C piping...
[\IMG]http://x.co/S2gx[/IMG]
[\IMG]http://x.co/S2gs[/IMG]
Will this kit require your oil-fill tube relocation kit? Looks like it from the pictures.
OrbitalEllipses is offline
Old 03-07-2011, 12:52 PM   #157
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I think I'm going to route the Tial off the OEM cooler loop and the turbo off the OEM turbo supply. Routing them both off one line, while easier, just feels wrong.
Good questions. I'll put the OEM one on there and see how that works out.
__________________
vs.
Old 03-07-2011, 02:03 PM   #158
jdblock
Member#: 235211
2004 STi
Sounds like a solid plan man.
jdblock is offline
Old 03-12-2011, 02:23 PM   #159
Big-Sexy907
Member Sales Rating: (26)
Member#: 59057
2004 Impreza, STi.
Updates? I can't wait to see what's next.
Big-Sexy907 is offline
Old 03-13-2011, 01:35 PM   #160
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks!
Here's a pic of the DP (tacked up) leading to the cat-back. As you can see I've got a cat in there. I'm considering breaking the tacks at the bottom and installing a v-band. This would make swapping a cat in/out extremely easy if you wanted a cleaner daily driver and a max flow weekend racer. Testing should show what kind of gains could be had.
__________________
vs.
Old 03-14-2011, 10:12 AM   #161
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks for all the PMs guys!
__________________
vs.
Old 03-14-2011, 11:57 AM   #162
juanmedina
Member Sales Rating: (32)
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
Best project currently on NASIOC right beside the testing of the BW EFR turbos
keep up the good work
juanmedina is offline
Old 03-14-2011, 12:40 PM   #163
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks!
__________________
vs.
Old 03-14-2011, 03:05 PM   #164
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Hmm, with a large turbo setup I'm surprised to see a cat in the exhaust, but a good idea anyway. Either way I know I'll stay catless.
Old 03-14-2011, 03:28 PM   #165
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Like I said, we'll be putting v-bands before/after the cat.
This leaves many options available: catted, non-catted or V-bands so you can swap whenever you wanted.
__________________
vs.
Old 03-14-2011, 06:08 PM   #166
jdblock
Member#: 235211
2004 STi
This leaves many options available: catted, non-catted or resonator, so you can swap whetever you wanted.
Fixed for ya buddy.
How are those pictures developing? I like what I see so far. Keep em coming.
jdblock is offline
Old 03-14-2011, 06:20 PM   #167
ValleyRallySTi
Member Sales Rating: (1)
Member#: 212561
Crazy setup. I'm always impressed with your products. Keep it up! (as a cdn. I also like products built in the USA, helps us with duty costs!)
ValleyRallySTi is offline
Old 03-15-2011, 06:41 AM   #168
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
I would just offer it with the cat. If you're keeping A/C for the road-going car, they [the consumer] are likely going to need cats to pass emissions. As much as having the cat code disabled works....one look under your car and you'll fail visual and not even get to the emissions.
I completely understand wanting the functionality of v-bands, race pipes, and test pipes, but be real. How many people ACTUALLY swap between race and test pips?
Keep up the good work!
Old 03-15-2011, 07:21 AM   #169
jdblock
Member#: 235211
2004 STi
Cats add money to the cost of the kit. KB is designing the kit to be flexible, and not everyone will want a cat.
I like the idea. I swap my exhaust all the time when I go to the track, a JIC Ti. But I hate trying to stay quiet on the street, so I put my stock exhaust for dd. With the way KB is doing it, it will allow people to change the cat/test-pipe out, and they can make the car a little quieter or perform better in a short time.
The reason you don't see people swap the stock location cat, out, might be because where the stock location cat is. It sure isn't as easy as this KB looks like it will be. Looks like it would take 5 minutes, not 2hrs.
jdblock is offline
Old 03-15-2011, 02:04 PM   #170
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Well said John!
There will be options to choose from so the customer gets exactly what they want
__________________
vs.
Old 03-17-2011, 05:59 PM   #171
loudninja
Member#: 256665
2011 WRX 4dr
i may have missed it but any chance this might work on the gr chassis?
loudninja is offline
Old 03-17-2011, 06:03 PM   #172
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
As soon as we get some results on the GD we'll go to work on the GR. It shouldn't take nearly as long since some parts can already be used and the GR has more room to play with up front.
__________________
vs.
Old 03-19-2011, 06:51 PM   #173
mtcs
Member Sales Rating: (29)
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Keep those pics coming...
Great progress!
mtcs is offline
Old 03-19-2011, 11:35 PM   #174
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Here's some more...
Bumper Beam: solid 1" steel bar with steel end plates. Bumper mount holes too.
Welding is complete on the FMIC finally... Well almost. Just have to tie in the bottom to the crossmember.
__________________
vs.
Old 03-20-2011, 12:01 AM   #175
fl4tsc
Member Sales Rating: (51)
Member#: 177247
2005 WRX 16G-XT+EWG
1980 Porsche 911SC 3.6L
for the love of god that's one hell of a thick intercooler.
just curious but any thoughts on making a standalone fmic kit? if you could get the price below kits like APS and Perrin and keep the usual KillerB quality you could have a winner.
fl4tsc is offline
Closed Thread
New winter... new project. JRach North West Impreza Club Forum -- NWIC 140 09-10-2010 12:34 AM
Finnally got my new rims on the GC and a pic of my new project Car for next year bstoehr83 Member's Car Gallery 25 04-13-2010 08:57 PM
*NEW* Project KIC Leggdura Racing lug nuts *ALL NEW COLORS* Fizz Autosports MWSOC Vendor Classifieds 0 11-12-2009 02:03 PM
('93-'01) Prodrive's new Project JaMa Impreza Forum 4 06-05-2001 08:41 AM
('93-'01) Pictures of our new project... Yellow_turbo Impreza Forum 20 05-22-2001 12:38 PM
