Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Exterior/Styling
Old 12-21-2010, 03:19 PM   #1
Evasive Motorsports
Vendor Sales Rating: (83)
Member#: 127427
Default APR Performance Super Sale
Formula 3 Carbon Fiber Mirror/Black Subaru/WRX 2002-2007 $231
Carbon Fiber Construction
Wide Range of Adjustment
Aerodynamic Shape to Reduce Drag
Billet Aluminum Bases for Easy Installation
5.5" Wide Angle Convex Mirror Lens
Mounting Hardware Included
Front Bumper Canard Set Subaru/WRX 2002-2003 $130
APR Front Bumper Canards are the perfect answer to aerodynamically tune the handling for the front of a car. Made of lightweight and durable carbon graphite composites, APR Front Bumper Canards help increase front downforce at high speeds. The added downforce stabilizes the cars chassis during hard cornering and increases traction for faster lap times.
Carbon Fiber Radiator Cooling Shroud Subaru/WRX 2002-2005 $105
The flow of air is not only limited to the outside of a car. To maximize cooling capabilities, a radiator needs a direct flow of air to allow an engine to maintain consistent temperatures on the race track. Because of structural gaps above the radiator, the flow of air could escape making the radiator not as efficient as it could be.
To help improve the flow of air into the radiator, APR Carbon Fiber Radiator Cooling Plates can be utilized to channel the flow of air directly to the radiator. This will improve the efficiency of the radiator while adding a high-tech, race inspired look to your engine bay.
Brake Cooling Ducts Subaru Sti 2008-2010 $265
The APR Brake Cooling Ducts are aerodynamically-optimized to "funnel in" massive amounts of air. Also known as the venturi effect, when the vehicle speed increases, this funneled-in air increases in both pressure and velocity as it passes from the larger frontal area into the smaller pipe section of the brake duct. When matched with appropriate high-temperature air duct hoses (not included - purchase hoses from your favorite racing-supply shop), the APR Brake Cooling Ducts will help to channel in large volumes of fresh air to help cool down red-hot brake rotors lap after lap on the track.
Carbon Fiber Rear Diffuser Subaru/WRX/STI 2004-2007 $567
Fiber Glass Rear Diffuser Subaru/WRX/STI 2004-2007 $400
To help channel the high speed air flow coming from underneath the car, diffusers redirects the high speed air flow to transition smoothly transition into the low pressure vacuum in the rear. This encourages a smoother flowing air flow underneath the car and allows better performance from other aerodynamic components such as aerodynamic wings.
Carbon Fiber Front Lip Subaru/WRX/STI 2006-2007 $473
Carbon Fiber Front Lip Subaru STI 2008-2010 $513
This Front Air Dam also utilizes a built-in aerodynamic splitter design that creates a high-pressure region of air atop the protruding surface, further reducing lift and increasing net downforce.
Carbon Fiber Wind Splitter With Rods Subaru/WRX 2002-2003 $281
Carbon Fiber Wind Splitter With Rods Subaru/WRX 2004-2005 $281
Carbon Fiber Wind Splitter With Rods Subaru/WRX 2006-2007 $296
Carbon Fiber Wind Splitter With Rods Subaru/WRX 2008 Up $296
Carbon Fiber Wind Splitter With Rods Subaru/STI 2008 Up $296
A Front Wind Splitter is a protruding flat surface in the front of a car that is designed to decrease front end lift and exert downforce. By creating a high pressure area on top of the wind splitter, high pressure air flow is restricted to flow underneath a car. With low pressure below the car, the effect of lift is reduced and a driver can gain from the extra traction and control.
8mm Wind Splitter Support Rods Universal $30
10mm Wind Splitter Support Rods Universal $49
New 10mm Wind Splitter Support Rods (longer Length) Universal $65
10mm Wind Splitter Support Rods With quick release Universal $49
Splitter Hardware (Bolts and Nuts) Universal $11
CF GTC-500 WRX/STI SPEC Subaru/WRX/STI 2002-2007 $1,161
CF GTC-300 67" Airfoil WRX/STI SPEC Subaru/WRX/STI 2002-2007 $1,080
FRP GTC-300 67" Airfoil WRX/STI SPEC Subaru/WRX/STI 2002-2007 $740
CF GTC-300 61" Airfoil WRX/STI SPEC Subaru/WRX/STI 2002-2008 $1,080
GTC-300 Carbon Fiber Gurney Flap 61" $73
GTC-300 Carbon Fiber Gurney Flap 67" $73
GTC-500 Carbon Fiber Gurney Flap $81
GTC-300/GTC-500 2" Riser $54
GTC-300/GTC-500 3" Riser $54
When it comes to racing, every second counts. APR Performance Adjustable Wings can give you that edge to achieve faster lap times. By reducing lift and increasing downforce, you can gain extra traction during high speed cornering.
Although adjustable wings arenít specifically a suspension component, they play a crucial role to the handling characteristics of a car. By adjusting the angle of attack on an adjustable wing, you can dial in the amount of downforce for better car control. This allows your car to have more or less oversteer characteristics, giving you additional control to tune the rear traction of your car.
SS/GT Kit Subaru/WRX/STI 2004-2005 $2,808
SS/GT Kit Subaru/WRX/STI 2006-2007 $2,808
Prices are plus shipping
CA residents must add 9.75% CA sales tax
Contact: Justin
Phone: 626-336-3400
Web: www.evasivemotorsports.com
__________________
[U]
[/U]
[COLOR=Black][B]Evasive [COLOR=Red]Motorsports[/COLOR]
218 S. 5th Ave
City of Industry, CA 91746
Phone: 626 336 3400
Official Whiteline Peformance Center
We do alignments and corner balancing!
[/B]
[/COLOR]
Evasive Motorsports is offline   Reply With Quote
Old 12-23-2010, 05:34 PM   #2
Evasive Motorsports
Member#: 127427
__________________
[U]
[/U]
218 S. 5th Ave
Phone: 626 336 3400
[/B]
[/COLOR]
Old 01-04-2011, 08:05 PM   #3
Evasive Motorsports
Member#: 127427
__________________
[U]
[/U]
218 S. 5th Ave
Phone: 626 336 3400
[/B]
[/COLOR]
Old 01-05-2011, 05:43 AM   #4
Carbon_73
Member#: 208191
2006 STI
Hello. In the delivery to Russia, carried out? Which company?
Carbon_73 is offline   Reply With Quote
Old 01-05-2011, 12:41 PM   #5
Evasive Motorsports
Member#: 127427
Depends on the item. Smaller items are sent via USPS. Contact us via email to get a international shipping quote. www.evasivemotorsports.com
__________________
[U]
[/U]
218 S. 5th Ave
Phone: 626 336 3400
[/B]
[/COLOR]
Old 01-14-2011, 12:59 PM   #6
Evasive Motorsports
Member#: 127427
Will meet or beat pricing!
__________________
[U]
[/U]
218 S. 5th Ave
Phone: 626 336 3400
[/B]
[/COLOR]
Old 01-17-2011, 02:14 PM   #7
Evasive Motorsports
Member#: 127427
__________________
[U]
[/U]
218 S. 5th Ave
Phone: 626 336 3400
[/B]
[/COLOR]
Old 01-24-2011, 01:11 PM   #8
Evasive Motorsports
Member#: 127427
__________________
[U]
[/U]
218 S. 5th Ave
Phone: 626 336 3400
[/B]
[/COLOR]
Old 01-31-2011, 01:59 PM   #9
Evasive Motorsports
Member#: 127427
__________________
[U]
[/U]
218 S. 5th Ave
Phone: 626 336 3400
[/B]
[/COLOR]
Old 01-31-2011, 10:05 PM   #10
CrazyPolo95
Member Sales Rating: (2)
Member#: 130742
2011 sti
red
Would the front splitter fit an 2011 sedan? Or anything other parts?
CrazyPolo95 is offline   Reply With Quote
Old 02-14-2011, 04:18 PM   #11
anthony06TR
Member Sales Rating: (3)
Member#: 192806
2006 wrx tr
steel gray metallic
pm me price for apr cf rear diffuser for 06 wrx shipped to 19709 plz..
anthony06TR is offline   Reply With Quote
Old 02-15-2011, 10:21 PM   #12
puertorck2
Member Sales Rating: (8)
Member#: 165760
06 STI
wr blue
pm a price on the apr Carbon Fiber Front Lip for a 2006 sti
puertorck2 is offline   Reply With Quote
Old 04-01-2011, 05:32 PM   #13
bschork
Member Sales Rating: (4)
Member#: 99812
05 WRX
pm'd you.
bschork is offline   Reply With Quote
Old 04-29-2011, 02:35 PM   #14
phatfil
Member Sales Rating: (30)
Member#: 15956
13 XV Crosstrek
13 FR-S Asphalt
Price for brake ducts shipped to 46628
phatfil is offline   Reply With Quote
Old 04-30-2011, 12:07 AM   #15
yo14jman
Member Sales Rating: (29)
Member#: 138229
2006 STI
apr fiberglass rear diffuser, how much shipped to 18020?
yo14jman is offline   Reply With Quote
Old 05-02-2011, 05:41 PM   #16
yo14jman
Member#: 138229
2006 STI
bump?
Old 05-03-2011, 01:06 AM   #17
LiGnSoCaL
Member Sales Rating: (1)
Member#: 117514
09 WRX
Drk Metallic Gray
Are these still available?
LiGnSoCaL is offline   Reply With Quote
APR, Chargespeed, Ings, Bottomline, VIS, Seibon - Super Sale Evasive Motorsports Exterior/Styling 112 12-20-2010 12:52 PM
APR Performance Sale Evasive Motorsports Exterior/Styling 160 01-04-2010 05:14 PM
DriveLine Motoring /// APR Performance ON SALE Aero Kits, Diffusers, Mirrors & More! DriveLineSales Exterior/Styling 27 04-28-2009 03:02 PM
APR Performance Brand-wide Sale -- Check here for a great summer deal! GNV Motorsports Exterior/Styling 156 10-23-2007 11:22 AM
