Old 12-21-2010, 03:48 PM   #1
d0ugch0i
Member#: 198861
2004 WRX
Default 17x9 +42 Wheels on S-Techs
i need help on which tire size i should get. ive asked plenty of times on multiple threads and yet ive only gotten about 2 replys and no solid answer yet.
Wheel size is 17x9 +42 with Tein S-Techs 245/45/17. i keep rubbing over bumps and dips and i cant take any corners. any suggestions on what i should be doing? i was thinking about rolling the fenders a bit and different tire size.
d0ugch0i is offline   Reply With Quote
Old 12-21-2010, 04:08 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
first thing i'd do is get rid of the s-techs and buy some rce springs.
but if that isn't an option, roll the rear fenders flat. if that doesn't fix the rubbing, go to a 245/40/17. if you still rub after that, add camber bolts and dial in some negative camber. if you still rub after that, go back to what i'd do.
Old 12-21-2010, 04:33 PM   #3
tora
Member#: 5851
09 Forester XT
+ NA Miata
Tires are definitely too big....225/45 maybe 235/45 or 245/40
tora is offline   Reply With Quote
Old 12-21-2010, 04:41 PM   #4
cccya
Member#: 70160
2004 Forester xt
JBP
the order i would go:
roll fenders, camber bolts, new springs, 245/40 tires..
just doing from my exp cheapest to most expensive
cccya is offline   Reply With Quote
Old 12-21-2010, 06:07 PM   #5
d0ugch0i
Member#: 198861
2004 WRX
yea i want to get new springs but im on a budget right now so ill have to deal with those springs for now. im planning to go for coils later on in the future.
Old 12-22-2010, 12:18 AM   #6
DrDanimalSize
Member#: 254097
2010 2014 Impreza
ROLL FENDERS, camber bolts, new springs, 245/40 tires..
There, much better
DrDanimalSize is offline   Reply With Quote
Old 12-22-2010, 12:26 AM   #7
sc00by4life
Member#: 97135
no seriously, you need new tires. those tires are WAY too big.
there are several cars running these same wheels with 255's and no fender mods.
sc00by4life is online now   Reply With Quote
Old 12-22-2010, 11:12 AM   #8
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
Originally Posted by nhat View Post
go to a 245/40/17.
/thread
jdmboy is offline   Reply With Quote
Old 12-22-2010, 12:02 PM   #9
DutchOven
Member#: 220629
2010 White WRX Hatch
2015 White WRX Limited
for the 10th time, its the tires.
DutchOven is offline   Reply With Quote
Old 12-22-2010, 12:18 PM   #10
d0ugch0i
Member#: 198861
2004 WRX
ok so im going to roll my fenders soon after all this rain stops and go with 245/40/17.
Old 12-24-2010, 03:23 AM   #11
FilthyFlushWRX
Member#: 259798
2001 Ridin Dirty
I would personally go with 235s for a little more strech and little less fender work. I ran 225s on 9" but only cause I got new Falkens for pretty much free, they were streched to where 235s would be perfect.
Your bumps causing your tires to hit your wheel wells won't stop untill you get rid of those spring just a fyi, coilovers would suit you better if you want to be lower, take corners and the ability to adjust your height at any given time.
FilthyFlushWRX is offline   Reply With Quote
Old 12-24-2010, 05:32 AM   #12
d0ugch0i
Member#: 198861
2004 WRX
so its either between 245/40/17 and 235/45/17....
Old 12-24-2010, 11:26 AM   #13
sc00by4life
Member#: 97135
235/45 is too tall.
Old 12-24-2010, 03:29 PM   #14
nhat
Member#: 140163
03 STi
hellaflunctional
terribad advice...
Old 12-25-2010, 12:45 AM   #15
FilthyFlushWRX
Member#: 259798
2001 Ridin Dirty
terribad advice...
Hmmmm so why do people use coilovers in the 1st place? What's their intentions of even having them on the market then? If I remember right they are more for a track/race setup to lower, fine tune for cornering/handleing and height adjustment.
Old 12-27-2010, 03:08 PM   #16
jdmboy
Member#: 240161
87 bmw e30
wrong did you see my post? where i quoted like 8 people that said it was the ****ing tires...well guess what its the ****ing tires. yes his springs suck because they are too soft for how low they are. and as far as your other post (dont feel like double quoting) different people go with coilovers for different reasons some are good reasons some are bad reasons this would be one of those bad ones because he will still need different tires!!!
Old 12-28-2010, 01:28 AM   #17
d0ugch0i
Member#: 198861
2004 WRX
so 245/40/17? would i still need to roll my fenders then?
Old 12-28-2010, 01:31 AM   #18
DutchOven
Member#: 220629
most likely not. depends how low you are
Old 12-29-2010, 08:11 PM   #19
d0ugch0i
Member#: 198861
2004 WRX
ok they still rub with 245/40/17. what should i do now? stretch the tires more? roll fenders?
Old 12-29-2010, 08:39 PM   #20
nhat
Member#: 140163
03 STi
hellaflunctional
roll fenders
do you know where they're rubbing? front? rear?
Old 12-29-2010, 08:50 PM   #21
d0ugch0i
Member#: 198861
2004 WRX
just the rears.
Old 12-29-2010, 10:55 PM   #22
jdmboy
Member#: 240161
87 bmw e30
what is your camber set at?
Old 12-29-2010, 11:01 PM   #23
DutchOven
Member#: 220629
getting those tires only solved a fraction of the problem. now just roll and/or pull your fenders
Old 12-29-2010, 11:15 PM   #24
jdmboy
Member#: 240161
87 bmw e30
^ assuming he has a sedan he shouldnt have to pull and with -1 degree of camber in the back i would expect for him to only need a slight roll.
Old 12-29-2010, 11:18 PM   #25
DutchOven
Member#: 220629
just to be safe
F/S Rota DPT 17x9 +42 with tires bucklidl SCIC Private Classifieds 31 02-13-2012 07:01 PM
FS Rota DPT 17x9 +42 with tires bucklidl Wheels/Tires 4 07-09-2009 07:27 PM
F/T: FL Rota DPT 17x9 42+ rt615 235/40/17 frem Wheels/Tires 13 03-19-2009 12:19 PM
Rota DPT 17x9 +42 off Pics BLACK-OUT Tire & Wheel 3 03-17-2009 08:41 AM
