Old 12-23-2010, 08:25 PM   #26
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Originally Posted by Blue_Rex View Post
So...since I have those I probably won't notice?
Yeah, you probably won't notice it.
Fierysun is offline   Reply With Quote
Old 01-08-2011, 11:20 PM   #27
Blue_Rex
Member#: 236954
2010 WRX Base
Parts ordered. More to follow once I get them installed in the next week or so.
Blue_Rex is offline   Reply With Quote
Old 01-13-2011, 10:15 PM   #28
Blue_Rex
Member#: 236954
2010 WRX Base
Ok, somebody throw me a bone here. I am trying to get the old bushing separated, and it just isn't happening.
Old 01-13-2011, 10:23 PM   #29
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
Very interesting, mine just kind of fell off once the bolts were removed. Try some wd40 soaking and then prying with a flat head screwdriver between the mount and the bottom bushings. Maybe some hammering on the flathead screwdriver to wedge it in between if it comes to that.
kenliu84 is offline   Reply With Quote
Old 01-14-2011, 12:17 AM   #30
Blue_Rex
Member#: 236954
2010 WRX Base
I'll try it tomorrow. I was seriously prying, but I didn't try the WD40 yet.
Old 01-14-2011, 02:37 AM   #31
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
PB Blaster or Liquid Wrench will do better penetrating than WD40.
OrbitalEllipses is offline   Reply With Quote
Old 01-14-2011, 06:09 AM   #32
kenliu84
Member#: 107618
2006 OBP WRX Wagon
I need to try that stuff when I finish this can of wd40.
Old 01-15-2011, 02:27 PM   #33
Blue_Rex
Member#: 236954
2010 WRX Base
WD40 is not working; do I just need to cut off the ring that attaches the center bushing? I've pried that thing with everything short of a crowbar after a complete soaking of WD40.
Old 01-16-2011, 06:55 PM   #34
Blue_Rex
Member#: 236954
2010 WRX Base
I put a cut into the end of each and they popped right off. Mine were acting like they were pressed on. I wish I had just cut them off in the first place.
I'll post my results after I get the car out of the garage for a drive.
Old 01-30-2011, 11:36 PM   #35
joe r
Member#: 53412
2003 Outback
Black and Gold.
Any new updates?
joe r
joe r is offline   Reply With Quote
Old 01-31-2011, 10:38 AM   #36
VuickB6
Member#: 193568
These are on my 1GA Talon and I used them to get rid of the "wub-wub" sound these cars make when your factory bushings are shot and greatly reduced a clunking sound I was getting while shifting. Can't comment on any added NVH since my car is pretty damn noisy as it is.
kpluiten - Your bushings may not be worn enough to notice the difference these make but add another 10 years and MANY more miles to your car like a typical DSM has and you'll know why these are made.
It's laughable that you think a stack of washers is going to do what these bushings do...
VuickB6 is offline   Reply With Quote
Old 01-31-2011, 11:03 AM   #37
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
it's laughable that you paid $35 for these. But then again, it's not hard to separate an idiot from his money.
Also, a DSM is a pile of ****. Plain and simple. Subaru's aren't much better, but the point is they are very different platforms with different weaknesses and failure modes. Because these works on your POS does not mean they will do a damn thing for my POS.
A stack of washers might have been an bit of an exaggeration, but not by much. There is NOTHING to these parts and you are getting raped on the price. Straight up raped. I promise you these do not cost more than $2 -$2.50 to manufacture. I could have a set done in under 30 minutes.
Also, that driveshaft in the picture is from a bugeye with over 150k miles in Arizona. That's a lot of drive time.
Old 01-31-2011, 04:44 PM   #38
Blue_Rex
Member#: 236954
2010 WRX Base
That raping feels pretty good everytime I hit the throttle.
Old 01-31-2011, 05:10 PM   #39
kpluiten
Member#: 120273
06 WRBWRXWGN
Enjoy it. I'll enjoy the extra $35 in my pocket.
Old 01-31-2011, 11:56 PM   #40
VuickB6
Member#: 193568
Let me know how those washers turn out for you...
Old 02-01-2011, 12:00 AM   #41
VuickB6
Member#: 193568
Grasping for straws there huh toots?
You can keep spewing bull**** around and I'll enjoy my quieter ride and money well spent. $35 may be a lot to you but not to everyone else...
Old 02-01-2011, 02:00 AM   #42
kpluiten
Member#: 120273
06 WRBWRXWGN
Right on dude. You nailed it.
Old 02-06-2011, 11:21 PM   #43
Torque solution
Member#: 218615
Torque solution is offline   Reply With Quote
Old 02-07-2011, 05:02 PM   #44
Blue_Rex
Member#: 236954
2010 WRX Base
Hey, 2 things; the first is that I pried and pried and pried with very large screwdrivers and other implements of destruction and had to lay a cut into each so they would come apart. The second...I put the tapered piece on top. Is that going to be a problem? That is what I get for listening to the internet for the install how-to.
Old 04-13-2011, 04:17 AM   #45
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
I have them and the shifting is smoother and great at fast shifting.
To Torque Solutions
In the video at the 1:00 mark i installed the bushings the other way. The flat on the bottom and the rounded off to the frame. Is that bad? When i asked the seller, TIC i think, they said it shouldn't matter, is that true?
BlackFighter is offline   Reply With Quote
Old 04-16-2011, 03:37 AM   #46
kay95
Member#: 45494
95 impreza L awd
green
You know the best solution is to remove the driveshaft. Take to a driveshaft shop. Have them remove the middle CV and weld solid to make a single piece. Reinstall and enjoy the weight reduction plus the reduced slop.
Sorry had to make a smart ass answer.
kay95 is offline   Reply With Quote
Old 04-16-2011, 12:48 PM   #47
kpluiten
Member#: 120273
06 WRBWRXWGN
^^^This^^^.
I had a one piece shaft made and it's 100 times better than these stupid pieces of ****. And most shops can make you one for well under 300 dollars. If you want a real improvement in feel, that is what you'll do. It also cut over 7 lbs of rotational mass from my drive train. The car doesn't surge or kick when decelerating or transitioning on and off the gas.
Old 04-16-2011, 10:54 PM   #48
WgnBlk
Member#: 216884
06 WRX wagon & M3
Black wgn, sil. bmw
have you ever stood under your car and done the push pull on the shaft? there is a TON of movement from that rubber donut thing...if you do that, and still want to spend some money on these, PM me. I gots some stuffs for to to buy!
WgnBlk is offline   Reply With Quote
Old 04-16-2011, 11:15 PM   #49
kpluiten
Member#: 120273
06 WRBWRXWGN
Exactly.
Old 02-18-2013, 04:08 PM   #50
kenjsylvia
Member#: 318342
2009 Impreza
Dark Grey
How did you end up getting them off, what was your process? Everyone says they just fall apart and I tried prying for over 45 mins with no success. Amy help or advice is appreciated!!!
kenjsylvia is offline   Reply With Quote
Torque Solution Drive Shaft Bushings boogieboogz Car Part Reviews 50 11-12-2013 07:55 AM
Torque Solution Drive Shaft Bushings... talsnic Transmission (AT/MT) & Driveline 16 02-22-2010 03:33 PM
Torque Solution Drive Shaft Bushings INSANE group buy. under $20!? yep! IMPORTIMAGE Vendor 'Group Buy' Classifieds 385 02-22-2010 01:53 PM
FS: Torque solutions drive shaft bushing - NEW txl146 Drivetrain 2 02-05-2010 09:58 PM
