![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 231504
Vehicle:2003 WRX Sonic 16G |
i got some Drag Dr 31's and i want to get some tires.
what is the smallest size i can get that would not be stretched? thanks
#2 |
Member#: 114177
RMIC
Vehicle:2004 Impreza 2.5rs 70 Datsun Fairlady |
My 255/40 Nitto NT-05 look a little beefy and my 245/45 blizzaks look a little stretched but each brand of tire will be a little different. I think most 245's will fit pretty good.
#3 |
Member#: 231504
i was thinking of going
235/40/r17 Federal SS 595's or 235/40/r17 Nexen N3000's please post your opinions. thanks |
#4 |
Member#: 231504
or should i get the
245/40/r17 Nexen N3000's |
#5 |
Member#: 114177
RMIC
I'd probably do a 245, a 235 will be stretched on a 9. My Blizzaks are and they are a 245 but i think they run a tiny bit narrower then most street tires. I would bet they are just a little wider then the 235's.
here's my 255's, sorry i didn't have any pictures with my snow tire on. ![]() |
#6 |
Member#: 231504
sick car bro
im gunna go with the 245's thanks alot |
#7 |
Member#: 207826
Vehicle:85k 2002 WRX Correct Fitment Crew #034 |
Absolutely nothing less than 245/40/17. Preferably 255s.
Nexens are trash. |
#8 |
Member#: 114177
RMIC
i never asked but are you lowered? and what's the offset of the wheels? +38?
#9 | |
Member#: 180547
Vehicle:2007 VF39 WRX STi Mikey tuned |
#10 |
Member#: 97135
NWIC
nexens are probably the worst tires i've ever had on my car - they didn't last a week.
what offset of the wheels? that is going to play a major role in how wide of a tire you can go. |
#11 | |
Member#: 180547
#12 |
Member#: 207826
#13 | |
Member#: 180547
#14 | ||
#Belieber
Moderator Member#: 140163
Vehicle:03 STi hellaflunctional |
![]() already told you in a PM. |
#15 | |
Member#: 180547
#16 |
Member#: 114177
RMIC
mine are a 17x9 +38, I'm on coilovers with fenders rolled and 2 degrees of camber front and back. I had some rota p45r's in a 17x9 +25 and they didn't' fit very well and rubbed with 245's. if you are doing +30 you will need to be on coilovers, fender rolled and pulled a little with lots of camber and stretched tires, maybe even 225's. That's a waste of a wide wheel if you ask me.
#17 | |
Member#: 97135
NWIC
(its shocking that people buy "aggressive" wheels with no idea what it actually takes to put them on their car). |
#18 |
Member#: 207826
#19 | |
Member#: 180547
#20 | |
Member#: 180547
#21 | |
Member#: 114177
RMIC
What do you have done to the car? |
#22 | |
Member#: 180547
#23 |
Member#: 114177
RMIC
![]() ![]() ![]() ![]() ![]() Here is his car from a while back, he is into the low and stretched thing. |
#24 |
Member#: 180547
Wow so after calling wheeldude they can't be returned but I found out that the +30 offset I was told it had is a lie and they are +42mm is this better or worse? Sorry for the confusion before. And thank you guys for all your help.
#25 |
Member#: 114177
RMIC
Well if you keep the wheels, plan on a fender roll and pull, and running stretched tires. Also make sure you have camber plates front and rear, you will need to dial in the camber to keep from rubbing.
| Thread Tools | |
| Display Modes | |
| Tire Size on a 17x8 Rim | kato4276 | Tire & Wheel | 1 | 04-02-2008 02:52 PM |
| Which Tires to get for 9" rim | wanalaugh74 | Tire & Wheel | 10 | 03-05-2008 11:10 PM |
| Tire size on stock rims? | deim | Tire & Wheel | 1 | 08-16-2004 04:38 PM |
| Tire sizes on stock rims? | adeck | Brakes, Steering & Suspension | 0 | 09-18-2001 07:50 AM |
| What's correct tire sizing for 18" rims on WRX? | bayWRX | Brakes, Steering & Suspension | 3 | 04-07-2001 12:11 AM |
