Old 12-23-2010, 07:06 PM   #1
Red_Wrx
Member#: 158658
I have an N/A manifold going on some jdm big port heads and my avcs hits the top feed injectors fuel rails. I've managed to cut and lower the avcs bracket but now the connector is not clearing. I already have 8mm phenolic gaskets with oem gaskets top and button. Easy fix get thicker gaskets but I don't know anyone that has any thicker them 8mm phenolic gaskets. I was thinking a making a extention and mount them sideways or perhaps a little cambered however the style solenoid I'm unsure will transfer fluid since inside it a small hole that it comes out and the solenoid might not make a complete transfer of flow. If you've seen and examined you'll know what I'm talking about. Also tossing the idea of turning just the plastic part and rotating the connector but unsure if possible. It's just the connecting head that doesn't clear, perhaps cut and create another extended connection. Scarey but it would work I just don't got another set to toy with. Thicker spacers would really be the easy way anyone know where to but some. Thanks for listening to me gripe.
Red_Wrx is offline   Reply With Quote
Old 12-23-2010, 10:41 PM   #2
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
id hate to recommend another spacer set with gaskets in between them all but.... you pics are to close up.
Alaskan EJ20 is offline   Reply With Quote
Old 12-23-2010, 11:00 PM   #3
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
those are the usdm avcs solenoids, the jdm make 90's, i have one of each, if you had a jdm one it would clear perfectly
seanathanq83 is offline   Reply With Quote
Old 12-23-2010, 11:55 PM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
good thing I choose to just have the NA upper manifold; '05-'06 Legacy. This way I run everything WRX fuel rails, TGVs, etc below. Phenolic spacers would be a good way to go about it. That's pushing an already pretty tall manifold up further.
FuJi K is offline   Reply With Quote
Old 12-24-2010, 12:18 AM   #5
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
I'm using the 2.5i n/a manifold from modded from outfrontmotorsports.com. They have an aluminum spacer that I'm using that is as I can recall 13mm. With the spacer it barely clears the avcs solenoids. Btw outfront made custom spacers for the aeromotive top feed fuel rails to fit the Fuel Injector Clinic 1300cc injectors. You can also have kstechnology make a custom set of phenolic spacers for you. You just have to be sure how thick you need them to be to clear. Just contact either one of them.
Pics of clearance after the spacers:
methaddict is offline   Reply With Quote
Old 12-24-2010, 12:26 AM   #6
Red_Wrx
Member#: 158658
Yea, but I don't know anyone selling taller phenolic gaskets then 8mm. I'll have to look into the jdm slenoids. Anyone have a picture of one. Thanks
Old 12-24-2010, 12:31 AM   #7
methaddict
Member#: 159738
2004 WRB STi
I just said above kstechnology can make them for you. They make a 9.5 and a 16mm. Or you can have them make a custom set.
Phenolic Thermal Intake Spacers
Old 12-24-2010, 12:32 AM   #8
Red_Wrx
Member#: 158658
Originally Posted by methaddict
I'm using the 2.5i n/a manifold from modded from outfrontmotorsports.com. They have an aluminum spacer that I'm using that is as I can recall 13mm. With the spacer it barely clears the avcs solenoids. You can also have kstechnology make a custom set of phenolic spacers for you. You just have to be sure how thick you need them to be to clear. Just contact either one of them.
Really! dang, I'm gonna have to bug jeremy tomorrow at outfront. I'm suprised he never mentioned it that's also where I got my manifold. I told him I had this problem yesterday. Cool I'll hit him up tomorrow. Thanks
Old 12-24-2010, 12:37 AM   #9
methaddict
Member#: 159738
2004 WRB STi
He probably has the jdm solenoids too.
Old 12-24-2010, 10:35 AM   #10
seanathanq83
Member#: 173241
well after relooking i dont think they will work, they make a 90 degree, straight up
Old 12-24-2010, 11:26 AM   #11
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Are you using the avcs? If not remove them plug up the hole and the two holes inside the case under the cover. Keep oil lines attached as they feed oil to the front cam cap.
mick_the_ginge is offline   Reply With Quote
Old 12-24-2010, 12:29 PM   #12
Red_Wrx
Member#: 158658
Yes Im using avcs, no an option. I'm gonna look into the thicker spacers. Thanks
Strut Tower Issues. any suggestions? slim617 Brakes, Steering & Suspension 28 05-04-2009 03:44 PM
Lets talk AVCS clearance on a stroker 3barboost Built Motor Discussion 2 08-25-2008 10:24 AM
Crusie Control Issues, Any Suggestions? HamrTym Electrical & Lighting 3 01-23-2008 01:44 PM
Any clearance issues with a Perrin cbe and hitch? DoesItReallyMatter? Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-28-2006 02:05 PM
Any clearance issue with Perrin RSB & COBB TBE? Need Speed Brakes, Steering & Suspension 2 02-02-2005 11:58 AM
