Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 12-24-2010, 12:47 AM   #1
Special
Member#: 145585
2002 S202 11.9@120
Yellow
Default Reverse lights stay on while driving
Hi all, I have a S202 which is a 2002 JDM STi. I went away for 3 months and since I have come back the reverse lights come on after a while of driving and stay on. They don't do it right away but after a while, they come on and stay on. I have disconnected them for now but any suggestions? Should I just change the switch as it keeps sticking or maybe spray it with something?
Thanks
Mike
Special is offline   Reply With Quote
Old 12-24-2010, 06:37 AM   #2
Uncle Buck
Member#: 140062
2005 STI ATP3076r
95' Eclipse gs
I would definitely check the switch before anything.
Uncle Buck is offline   Reply With Quote
Old 04-12-2011, 01:11 PM   #3
Special
Member#: 145585
2002 S202 11.9@120
Yellow
Hi, I assume it is the switch and I have another one but it is impossible to get to it to change it. Anyone have any suggestions? Is there a fabricated tool that I will need?
Old 04-12-2011, 01:48 PM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
its not impossible to get to. just awkward since you have to be able to
access the sensors on the tranny..a lfit would mae things more doable..
Old 04-12-2011, 01:49 PM   #5
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
A closed-end metric wrench would work.
Old 11-26-2014, 04:06 PM   #6
Special
Member#: 145585
2002 S202 11.9@120
Yellow
i decided to try and change the reverse switch today after years of having the reverse lights disconnected. I took the brace that holds the gearbox up and it did lower a bit but I just can't seem to get a wrench on to it?? Any help would be much appreciated. Is there any special tool I need to get this done?
Old 11-26-2014, 05:13 PM   #7
Big-E
Member#: 123843
2006 WRX Sedan SGM
A socket with a long extension from the back of the transmission <or> remove the shifter lever assembly and then access from the opening in the center-floor of the vehicle?
Old 11-26-2014, 08:42 PM   #8
Special
Member#: 145585
2002 S202 11.9@120
Yellow
Thanks I will try that in the morning.
Old 11-27-2014, 06:04 PM   #9
Special
Member#: 145585
2002 S202 11.9@120
Yellow
Thanks a lot for your info on getting the reverse switch out from the back with a long extension. With pure will, I managed to get it out and also put the new one in, but the issue is getting it tight without damaging the wires. What socket did you use?
Thanks Much
Mike
Old 11-29-2014, 08:46 AM   #10
STARSCR33M
Member#: 197163
2002 Impreza WRX
Midnight Black Pearl
It doesn't have to be too tight, just tight enough. The reason why it was hard to remove it was because that reverse switch was on the transmission for a long time. I recently changed my neutral safety switch and it is right near the reverse switch.
STARSCR33M is offline   Reply With Quote
Sti reverse lights staying on in every gear stoner Electrical & Lighting 9 06-17-2009 12:50 AM
E-brake light staying on while driving? jcbluescooby Service & Maintenance 7 12-19-2008 01:47 PM
AT "power" light turned on while driving nosajh9 Transmission (AT/MT) & Driveline 3 09-20-2005 09:16 AM
Reverse lights stay on...? dalemcc Electrical & Lighting 8 11-28-2004 06:13 PM
Brake Light Comes on While Driving BLCK DVL Service & Maintenance 3 10-02-2002 01:58 PM
