Old 12-24-2010, 02:55 AM   #1
MRF22
Member#: 210516
2005 Sti
AW
Default Tires of course!
Hey I'm currently running Enkei EKM3's with Toyo Proxe 4 tires, 215/45/17. I really like the Proxe 4 but this set didn't last long on a DD car. I was told by Schwab to go with a Toyo Tourivo but they would last just as long as the proxe 4's unless I went with a 50 sidewall. In that case the Tourivos are only rated for 40k in that size. Honestly I will prob go with the Proxe 4's again. I really like them. I think the reason they only lasted 26k is cuz a stupid shop set me up on -2* camber all around for a DD. My question is should I stick with the 45 sidewall or could I go with a 50? I wanna go up a bit but would if work without rubbing? I'm on TiC coilovers. Pretty close to stock height in rear, and maybe 1" lower in front. Also what can I do to decrease inside tire wear? Sway bars? RCA kit?
Thanks!
MRF22 is offline   Reply With Quote
Old 12-24-2010, 04:38 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
d0000000000d
get an alignment
get the toe set to '0' all the way around and go from there
Old 12-24-2010, 07:44 PM   #3
MRF22
Member#: 210516
2005 Sti
AW
I did! A long time ago back to oem. I just did one too! Lol thanks!
Old 12-24-2010, 08:31 PM   #4
MD04WRX
Member#: 72891
2014 Molten ST
98 2.5GT -2014 XV
Inside tire wear is normally a toe issue not camber. Make sure the toe is set to 0 front and rear.
MD04WRX is online now   Reply With Quote
Old 12-24-2010, 09:58 PM   #5
MRF22
Member#: 210516
2005 Sti
AW
Oh ok thanks! Les Schwab did it and they put it at OEM specs. But I'll make sure.
Old 12-24-2010, 11:32 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
oh jesus
another one that thinks 'oem' is good
it is NOT
'OEM' sucks the balls of old dead monkeys
ya NEED to TELL them that you want ZERO TOE or they wont do it
Old 12-24-2010, 11:45 PM   #7
MRF22
Member#: 210516
2005 Sti
AW
Originally Posted by Uncle Scotty
oh jesus
it is NOT
I just checked all of my records from Schwab of 4 alignments over the years and all of them have zero toe. Thanks tho for the advice. In your wisdom what is a good set up? Strictly DD car. Thanks!
Old 12-25-2010, 12:07 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
if you are getting inside tire wear....then it is an almost certainty that your toe is NOT ZERO
I know that if the rack isnt set up right and/or isnt level....the toe reading may SAY it is zero and it really isnt
zero toe and maxed negative camber in front is usually the only adjustement that can be made on a stock suspension for any kind of performance
Old 12-25-2010, 12:31 AM   #9
MRF22
Member#: 210516
2005 Sti
AW
Ok so who so u get to align it that I can trust and not screw it up? How do you tell that it's true ZERO? Also I'm looking for a DD set up that will get me even tread wear. Is zero toe and oem camber not a good set up?
Crash Course! Of course! Asinine Off-Topic 24 08-30-2009 03:25 PM
Should I go with 205 over 195? Tires of course! kirbykirb Legacy Forum 9 05-05-2009 10:20 PM
Of course, a tire size/offset question... geist Tire & Wheel 9 02-21-2007 01:07 PM
Hella tyte pictures of my car with hella's of course on 94 L scobaru Member's Car Gallery 3 02-22-2005 11:11 PM
Flat tire - of course! AWDhottie Tri-State Area Forum 20 09-21-2003 06:43 PM
