Old 07-06-2002, 02:25 AM   #1
PadreWRX
Member#: 5311
2004 GTO 11.2 @ 123
Was 4EAT '02 WRX [email protected]
Talking Automatic record falls at 4100ft
Beautiful night for dragging here in El Paso. Track conditions: 4100ft altitude, 80F, 40% humidity, barometer 30.00 and rising.
My mods: Cobb RT-spec w/ TMIC, Vishnu fuel rails and uppipe, STi Injectors, Supra fuel pump, Pro Torque Street/Strip 4100rpm stall TC, all synthetic, tranny cooler.
Special tricks tonight:
- The TC-lock-up mod which I engaged on most of my runs at 5500rpm (disengaging for shifts). This seemed to work best.
- 2.5 gallons of 104 octane unleaded mixed with 5 gallons of the crappy West Texas pump gas (91).
- the 3/16" restrictor mod, which brought my tuned boost from 17.5 psi to 18.5psi.
So my first runs were the best ever, here: 14.1 then 14.0 then 13.9. Awesome for my altitude. Best prior was 14.2 on pump gas. The ECU seemed to learn with each run.
Then, towards the end of the night, I decided to try the "new twist" on the 3/16" restrictor mod - I had drilled a 1/16" hole in a 3/16" connector.
Tried this out against a friend in an LS1 Vette on street tires that usually runs 13.6's. I happened to catch him a bit heat-soaked on this run, and my reaction time sucked, but here's what happened:
r/t: 1.038 (I know, I usually do better)
60': 1.839
1/8th et: 8.531
1/8th mph: 79.278
1/4 et: 13.451
1/4 mph: 101.755
The slip is attached. I checked my peak boost following the run: 22.1psi (with that "new twist" mod). I don't intend to do this often and I wouldn't have done it without race gas, but I had to do one more run to make sure it wasn't a fluke: 13.576 @ 101.854.
Props to Jorge, Rob, Andrew, and all the other 4EAT guys. I know this record won't last long but it sure feels good.
Padre
PadreWRX is offline   Reply With Quote
Old 07-06-2002, 03:08 AM   #2
JenisonWRX
Member#: 6049
02 WRX & 99 RS
Nice...esp on 4EAT
JenisonWRX is offline   Reply With Quote
Old 07-06-2002, 04:43 AM   #3
hotrod
Member#: 14141
2002 Impreza WRX
Default Great run
Great run, especially at altitude.
Larry
hotrod is offline   Reply With Quote
Old 07-06-2002, 11:11 AM   #4
dazz1
Member#: 10363
5.9 Turbo Cummins
Great job Padre!
Your trap speed & 60ft looks good for some low 13's run.
dazz1 is offline   Reply With Quote
Old 07-06-2002, 12:38 PM   #5
Torch
Member#: 10172
Nice run's padre!! I just cannot believe that you were at that altitude and ran such great times. It is nice to hear good things about the 4EAT, gives me something to shoot for.
Torch
Torch is offline   Reply With Quote
Old 07-06-2002, 12:50 PM   #6
Silver_SportTrac
Member#: 15052
Do u have to ask?
Padre,
i can't imagine what you'll run here in DFW sometime in the fall/winter!
nice job d00d!
sst
Silver_SportTrac is offline   Reply With Quote
Old 07-06-2002, 03:05 PM   #7
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Nice time!
Congrats!
Kevin Thomas is offline   Reply With Quote
Old 07-07-2002, 10:23 AM   #8
PadreWRX
Member#: 5311
2004 GTO 11.2 @ 123
Thanks for all the compliments gang. It sure was an eye-opener pulling 100+ traps for the first time.
Looking at my gauges and OBD the next day, I found that I had spiked to 22psi on the first run, but the second run held between 18-20 (my VF-29 is tuned for 17.5 at sea level). IOW, this is something I don't want to do at lower altitudes, as I imagine something will blow up. The spike also triggered a P0103 (MAF sensor high input), which I assume means overboost.
Anyway, I do plan on running at lower altitudes in August. With a little race gas, I imagine I can run 13.4's all day on my regular boost. If I can find a safe way to effectively crank the boost, I may do better.
Oh, and Kevin, my apologies: you're still the fastest automatic Subaru. Mine's just the fastest automatic WRX. Go wagons!
I don't expect the record to last long. I believe Rifts is going racing this weekend with his new goodies, including valve body, so we may be seeing an automatic in the high-12's by next week.
Padre
Old 07-07-2002, 10:37 AM   #9
gossamer_monster
Member#: 3574
Blase' Yellow----R.I.P.
Very nice.
Bill
gossamer_monster is offline   Reply With Quote
Old 07-07-2002, 05:37 PM   #10
RobPA
Guest
Member#:
Congrats PAdre!!!!!!! Ohh man this is really really awesome!!
Been away the whole week so i missed the thread. Congrats bro! Your TC better hold up for when i get to the track
Rob
Old 07-07-2002, 06:31 PM   #11
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Way to go !
alfriedesq is offline   Reply With Quote
Old 07-08-2002, 10:13 AM   #12
PadreWRX
Member#: 5311
2004 GTO 11.2 @ 123
Ha, it's not the TC holding up you should be worried about... just be careful with the juice, eh?
Oh, and get thee to the track.
Padre
Old 07-08-2002, 10:09 PM   #13
portablevcb
Member#: 7979
Default Tranny temps
Padre,
Was experimenting with my new tranny gage (installed in the return line, my sensor did not fit in the pressure tap locations). Also was thinking of what happens during a drag run and after.
I still think the problem is having a cooler integral with the radiator. You heat the fluid during the stall launch. System is running at high rpm during run and a lot of airflow through radiator keeping everything "normal".
After run in the return lane the rpms go very low, resulting in very little cooling effect on the engine and tranny fluids. Engine heat soaks radiator and tranny fluid. That is probably why you see an increase in temps on the return lane.
I still think a separate tranny cooler (bypass the stock one altogether) is the answer. For effective cooling after a run you would want both a separate cooling fan for the cooler and run the engine in neutral to keep the fluid circulating (if no fan, then get another bag of ice to put on the tranny cooler, or, run some of the water spray to it from the one cooling your IC with a separate pump). BTW, this should also help cool off the engine since it would still be circulating a little water through the engine and radiator.
I don't think your cooler location will be a problem. Just don't run the AC and let the new fan circulate the air. The cooler will be seeing cool night air (as cool as it gets in El Paso :-)
I will be "experimenting" with road course type stuff soon, ie, high torque repeatedly at high rpms. I will report on that separately.
Have not seen Jorge in here for a while. He might want to take note of this and offer his opinion as well.
Charlie
portablevcb is offline   Reply With Quote
Old 07-08-2002, 11:01 PM   #14
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
Yeah Kevin! Old skoool!!
-Chav
Kevin is my hero!
Chav is offline   Reply With Quote
Old 07-08-2002, 11:30 PM   #15
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Knight Rally Team is using HUGE autotranny coolers on their cars...
ImprezaRS dot com is offline   Reply With Quote
Old 07-09-2002, 12:25 AM   #16
PadreWRX
Member#: 5311
2004 GTO 11.2 @ 123
Where do they put it? In-line with the stocker in the radiator or not? Extra cooling fan or not?
The one I have is about 5 times bigger than the stocker. The question Charlie and I have is where to place it: should it be hooked up in-line with the stocker (that goes through the radiator), or can we move it to some other location that doesn't get heated up by the engine/radiator between runs? And since it's 5 times bigger, why not bypass the stocker/radiator altogether?
From the end of a run and the time I get back to the staging lanes, I watch temps rise 20F+. We're mainly concerned about drag-racing, but I wonder if it would help for road racing as well. If I want a good run, I have to wait 15+ minutes.
My problem may simply be placement. It was not installed in front of the AC, but between the AC compressor(?) and radiator. Too close to the radiator and drawing heat when the AC is on. Rifts, IIRC, installed his in front.
Am I making any sense here? (Not an expert.)
Padre
Old 07-09-2002, 03:10 AM   #17
IgotWRXed
Member#: 14868
2002 wrx
AAAAAHHHHHHH thats some good schwag. congrats bro, u brought a tear to my eye *sniff sniff* take THAT 4eat haters.
and i know no one likes these, but i felt like doing the corrected times, and at sea level thats a 12.774 @ 107.198, give or take, and no one give me any crap for posting this
congrats again
IgotWRXed is offline   Reply With Quote
Old 07-09-2002, 09:35 AM   #18
PadreWRX
Member#: 5311
2004 GTO 11.2 @ 123
Default Re: Tranny temps
Well, I think we have two other options as well:
1) Pull the AC fuse. This should turn off the compressor while allowing the radiator fans to run.
2) Wire up a switch to activate the radiator fans without turning on the AC (or disconnecting it's fuse).
Option 2 is what I'd like to do, but 1 may be a good temporary track solution.
Padre
Old 07-09-2002, 10:12 AM   #19
Torch
Member#: 10172
Default Re: Automatic record falls at 4100ft
Padre,
I might be a bit confused on your times -vs- when you had your mods but, didn't you run a 13.8 in Ennis with your RT-spec? For you to run a 13.9 at that level indicates that you have done more mods since you were here.
That must mean that the TC-lock-up mod and the 3/16" restrictor mod along with some race gas helped out quite a bit.
If everything goes well I should have the RT-Spec W/SR-30 turbo by mid August. I will have to give the restrictor and lock up mod a try soon, as they look like they will help out a lot.
Torch
Old 07-09-2002, 10:53 AM   #20
PadreWRX
Member#: 5311
2004 GTO 11.2 @ 123
Default Re: Re: Automatic record falls at 4100ft
Torch, good question, here's the break-down:
13.8 @ Ennis (500ft) on 93 pump gas, NO restrictor mod, NO TC-lock-up mod.
14.6 @ El Paso (4100ft) on 91 pump gas, NO restrictor mod, and NO TC-lock-up mod.
14.2 @ El Paso (4100ft) on 91 pump gas, the 3/16" restrictor, and TC-lock-up at 5500rpm.
13.9 @ El Paso (4100ft) on a race gas mix (about 95), the 3/16" restrictor, and TC-lock-up at 5500rpm.
13.4 @ El Paso (4100ft) with same mix (95), the "new twist" restrictor mod (1/16" hole drilled in 3/16" connector), and TC-lock-up at 5500rpm.
Basically, the TC-lock-up mod gains me 2/10ths, the 3/16" mod 2/10ths, the race gas mix another 3/10ths, the "new twist" mod a 1/2 second or more (since it replaces the standard 3/16").
Of course, heat, humidity, and the barometer also factor in, so considering I ran 13.4 when it was 80F and 40% humidity is pretty amazing. A cooler, drier night might gain me another tenth or two.
I'm still researching whether or not running the "new twist" mod at lower altitudes is wise. Cranking the boost here compensates for altitude, but may blow something up at lower altitudes. When I ran at Carlsbad, CA, just the 3/16th mod alone felt way too strong. So I want to be careful.
Padre
Old 07-17-2002, 10:57 AM   #21
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
You still hold it dude! I had suck this saturday.
13.599 @99.8 with a 1.82 60fter
My best MPH was a 13.63 @100.98 but that was a suck ass 2.0 60ft Why couldn't I have had the 1.82 on that run!
This was at 19.4 PSI tapering down to 17 by redline.
Props dude! Your the man... this week
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 07-17-2002, 11:10 AM   #22
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Oh yeah...
http://www.kicksomeass.com/~dr_nick/...ICdragDAYS.mov
Look for the black wagon
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 07-17-2002, 11:12 AM   #23
PadreWRX
Member#: 5311
2004 GTO 11.2 @ 123
Woohoo! I'm going to my dealer today to give them a picture of me drag racing and it's going to say something like, "Thanks for helping me to be the fastest automatic WRX in the USA!*" With small print at the bottom: "* for this week" They're going to post it in the lobby of the service department (cool guys).
Anyways, I ran 13.5-13.6 @ 100+ all night last Friday. I encountered two things that kept me from doing better: the ECU seemed to learn and cut back timing and/or boost; and it was a little hotter.
I heard it was pretty hot when you MWIC guys were running. On a nice cool night you ought to be able to get low 13s easy. Oh, and I saw you on the MWIC Drag Day video already. Total stealth look - stock rims and so on... though you need to tint those windows.
Oh, and when do I get my JorgeMonkey? Whatever it is.
Padre
Old 07-17-2002, 11:25 AM   #24
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
after 9/24
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 07-17-2002, 09:40 PM   #25
RallyKnight
Knight Motorsports, Inc
Member#: 1826
1996 2dr Impreza L
Default Knight Coolers
It is great Padre to see that the 4EAT is catching on. I love them. It has been the best trans I have ever put in the rally cars. The coolers that we run are for MAX continuous duty cycle. On a very long stage it is not uncommon to see trans temps of 300 deg. Stages of over 15 miles and the Motec has shown up to 100 shifts in that space.The cooler we use is 15 inx15 inx2 in and mounted in the rear trunk bulkhead and draws air form the roof and air exits through the rear spoiler. Not applicable to a street car.
The street car we relocate the intercooler to above the radiator (ala WRC). The radiator is sloped down with slimmer fans. The trans cooler 4inx24inx3in (thick) is located in the space vacated by the intercooler and feed by the taller STi scoop. The trans lines for the cooler is right there by the starter for easy hook-up to the new cooler. I built mine to swing out of the way because it attaches to the strut bar. I use a fiberglass ducting from the back of the cooler with an inline tube-style fan for pulling air through the cooler although i may change this with two small fans and no ducting. The new tarmac car will be ready before Aug. See you out there.
RallyKnight is offline   Reply With Quote
AMS EVO at it again. Record falls japslapr Proven Power Bragging 86 06-08-2006 10:28 AM
SWIC&TXIC meet, and automatic record falls PadreWRX Texas Impreza Club Forum -- TXIC 12 07-09-2002 02:29 PM
NEW BYBYV8 record falls post & nitrous discussion VetteVert Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-15-2002 09:57 AM
Any records falling this weekend? mynew02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-06-2002 12:37 AM
record days at NASIOC m750 General Forum Archive 0 09-27-2000 10:48 AM
