Old 12-24-2010, 10:39 PM   #1
irish44j
Member#: 191290
09 OPB SM WRXsedan
85 BMW E30 M2 Rallycrossr
Default My Christmas Mod: UKDM Evo rear fog light on an 09 WRX
Had a bit of downtime today on Christmas Eve after getting home so figured I'd get around to this install that I've been meaning to do for a while now. And please, let's not argue about whether people should or shouldn't have rear fog lights....it's personal opinion. I spend alot of time up in the mountains where it actually is foggy or snowing, so I consider it a worthwhile safety mod.
The UKDM WRX's also have these in a similar location, but using the '11+ and 08+ STi lower bumper, which I obviously don't have. So wanted to make it work with the bumper I do have
As to the work itself: This is the OEM rear fog light from the UKDM Mitsubishi Evo VIII/IX, which I ordered from England (and which took forever to get here). I got it because unlike aftermarket lights, the faceplace actually has some curvature to it, so to sit more flush with the slightly curved part of the bumper I wanted to install it on. All in all I think it came out good. I still need to get a bulb (will be using LED bulb since these lights are known to overheat and melt with high-power incandescent bulbs), and the wiring and dash switch is mostly setup already, since I used a rear fog mounted on the back deck last year.
Anyhow, no lit pics yet, and the pics kind of suck, but I can't open the garage door right now because my daughter is asleep right above it, lol.
So will post beter shots later once I finish the wiring and get the bulb, but a few teasers...
The bumper hole. Made sure to measure precisely (using a caliper) to get it perfectly centered and level. Note the top edge cut is just a hair below the lower seam of the rear sheet metal. This was by design.
What look like scratches above the hole are actually just pencil marks, don't worry
With the bracket test-fitted
Installed.
You can see there is a little tiny gap at the bottom edge due to the "double curve" of the lower bumper piece, but you can't see it at all from standing height, only when you get down and look from the level of the exhaust. Not worried about it. Also there is room to slightly tilt the flat lens upward to be more or less perpendicular to the ground, as it should be for maximum light output to trailing drivers.
Note that the gray looks a bit different color from the lower bumper, but that's mostly because of the flash. In regular light they are VERY close. I may paint to match perfectly eventually, once it warms up around here!
EDIT: here are some farther away shots
here's the switch
irish44j is offline   Reply With Quote
Old 12-24-2010, 10:44 PM   #2
cabikejumper
Member#: 226604
2000 Mustang GT
Will you blend the paint?
Looks nice.
cabikejumper is offline   Reply With Quote
Old 12-24-2010, 10:47 PM   #3
irish44j
Member#: 191290
09 OPB SM WRXsedan
Looks nice.
Yeah, once it warms up enough here to paint anything! Expecting snow tomorrow, and my garage is NOT heated! That said, in person the grays are much closer color. The camera flash is making them look alot different, which isn't the case in regular light.
Old 12-24-2010, 11:51 PM   #4
army medic
Member#: 200236
05 STi
Aspen
If possible can you take pics from further away so you can see the entire rear...?
army medic is offline   Reply With Quote
Old 12-25-2010, 10:34 AM   #5
irish44j
Member#: 191290
09 OPB SM WRXsedan
yeah, I will. Couldn't open the garage door last night b/c the kid was asleep!
Old 12-25-2010, 02:37 PM   #6
irish44j
Member#: 191290
09 OPB SM WRXsedan
added some shots from farther away. Merry Christmas everyone.
here's the switch...stolen from an old set of Hella fog lights
Old 12-25-2010, 03:01 PM   #7
cartwheels4amile
Member#: 190405
2002 Impreza WRX
Clean install... Merry Christmas! Keep us updated when you add the lighting.
cartwheels4amile is offline   Reply With Quote
Old 12-27-2010, 05:33 PM   #8
irish44j
Member#: 191290
09 OPB SM WRXsedan
btw, somebody on another forum mentioned it looked off-center, but that's just because I can't take a straight-on picture, apparently.
Here's one with a visual alignment!
Old 12-27-2010, 05:50 PM   #9
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
That's actually really cool, nice idea! Any body have pics of the OEM rear fog light that's built in on Non-domestic cars?
Will
GrimmSpeed is offline   Reply With Quote
Old 12-27-2010, 05:54 PM   #10
MattD87
Member#: 126930
2015 Legacy
CGM
I was looking for a reason to dislike, but I think it came out great.
MattD87 is offline   Reply With Quote
Old 12-27-2010, 06:03 PM   #11
irish44j
Member#: 191290
09 OPB SM WRXsedan
in the UK impreza, they take out the right-side reverse light and replace it with a red bulb for the rear fog, at least up until 2011. The 2011+ has it centerline in the little hole that is blank in the US model:
you can see where it "would" go on the US model if one were to order the UKDM housing
Old 12-29-2010, 09:56 PM   #12
irish44j
Member#: 191290
09 OPB SM WRXsedan
Here's a crappy lit pic. Fairly bright, as you can see. Used a 24-LED bulb from autolumination
Old 12-29-2010, 10:13 PM   #13
SnakeFart
Member#: 217632
2009 Impreza WRX
Dark Grey Metalliac
Here's a crappy lit pic. Fairly bright, as you can see. Used a 24-LED bulb from autolumination.
Haha, didn't mean to make you work more for thinking it was "off". I love the brightness. Got a link for the 24 led you used? Mainly because I have no idea how to use their website...
SnakeFart is offline   Reply With Quote
Old 12-29-2010, 10:28 PM   #14
irish44j
Member#: 191290
09 OPB SM WRXsedan
Now that I look it's actually 32 LED
Bayonet
Item# 32led , Color: Red , Type: 1156
$9.99
There are probably some brighter ones, but I didn't want to spend more than that on a bulb, lol...
http://autolumination.com/1156_1157.htm
it's about 1/3 of the way down the page, named "THE MATRIX II LED BULB"
looks like this:
Old 12-29-2010, 10:45 PM   #15
SnakeFart
Member#: 217632
2009 Impreza WRX
Dark Grey Metalliac
Looks like a good bulb. Got any pictures of the housing finished with the electrical socket and cover removed. I might have to mold my own if I cant find a way to make mine work.
Old 12-29-2010, 10:53 PM   #16
irish44j
Member#: 191290
09 OPB SM WRXsedan
maybe some other time. Since I have the inner housing mounted slightly angled up (to compensate for the bumper curve), I can't take the lens off without taking the whole assembly out of the bumper, which I'd rather not do much for fear of stripping th holes.
It's a VERY basic socket and reflector though, and the casing is just a rectangular-shaped box...
Old 12-29-2010, 10:58 PM   #17
SnakeFart
Member#: 217632
2009 Impreza WRX
Dark Grey Metalliac
-1! Haha its all good. Good job again. Looks great.
Old 01-02-2011, 02:29 AM   #18
02Bugeyeworks
Member#: 167459
2002 WRX Wagon
WRB [Under Construction]
Very cool. I've always wanted something similar to the rear fog that all the edm vehicles come standard with.
+1 for craftsmanship and simplicity.
02Bugeyeworks is offline   Reply With Quote
Old 07-22-2014, 03:07 PM   #19
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
Why is this the case here in the US? I want to do one to my 04 but its going to have to be a custom job and Ill need to make some type of bracket.
shamrock 05 is offline   Reply With Quote
Old 07-22-2014, 07:22 PM   #20
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Rear fog-lamp used as a fog-lamp? Yes.
Rear fog-lamp used as a parking or brake lamp? No.
2002-2007 sedans: rewire rear lamps so that the lower outer is the fog-lamp, lower center is the parking-lamp, lower inner is the brake-lamp.
09 sti wheels on an 09 wrx petar7408 Tire & Wheel 9 06-01-2009 10:29 PM
Has anyone installed fog lights on an 04/05 STI mrl859 Interior & Exterior Modification 17 09-20-2004 12:21 AM
re-aiming fog lights on an MY04 LYHTSPD Electrical & Lighting 1 05-05-2003 03:30 PM
Rear fog light on the WRX wagon prelude/2.5rs Interior & Exterior Modification 9 02-28-2003 10:20 PM
('93-'01) Rear fog lights on 2002 WRX US models ?? ginowrx Impreza Forum 15 06-15-2001 06:34 AM
