Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 12-25-2010, 06:26 AM   #1
SlowImport
Member#: 123720
2003 WRX Wagon
Platinum Silver Metallic
Default AEM UEGO and RomRaider
I can't seem to get the AEM wideband to log on RomRaider. The gauge is reading just fine and I am using the Busted Finger cable to connect to the AEM wideband to my laptop. All I get are 0 across the entire board for the AEM wideband while everything else logs just fine from my tactrix cable.
please help me,
Josh
SlowImport is offline   Reply With Quote
Old 12-25-2010, 10:45 AM   #2
quazimoto
Member#: 70395
Select plug in
Select external sensor
Then in the main logging parameter window select the AEM Ugo along with whatever you want to log. What do you mean your using the BFM cable to connect your AEM?
quazimoto is offline   Reply With Quote
Old 12-25-2010, 12:53 PM   #3
SlowImport
Member#: 123720
2003 WRX Wagon
I did exactly what you have listed. So then it pulls up the AEM logging table on the right side along with everything else I have selected for the RomRaider to log. But instead of giving me an A/F reading like the gauge is reading, all the values just say 0(zero).
What I mean by using the BFM cable to connect my AEM, is that I am using the BFM cable to connect the AEM wideband to my laptop so the RomRaider can log it. Here is the BFM cable I am using.
http://www.bustedfingermotorsports.com/aem.html
Thanks for your help so far quazimoto, Phatron and I are trying to get to where I can get this wideband to log so we can start tuning.
Also when I plug in the BFM cable that is connected to the AEM wideband to my laptop its not finding the drivers. You think its just the cable not talking to my laptop?
this is frustrating,
Josh
Old 12-25-2010, 04:37 PM   #4
quazimoto
Member#: 70395
What version of Romraider are you using and what operating system do you use? I usually have to manually install the drivers for my Tactrix. You will probably have to do the same for that cable. Just use " install drivers from specified location" from the install wizard and then browse to where the drivers are located from the installed software.
Old 12-26-2010, 01:01 AM   #5
SlowImport
Member#: 123720
2003 WRX Wagon
v0.5.2 Beta is the version of RomRaider I am running.
hmm,
Josh
Old 12-26-2010, 01:42 AM   #6
arghx7
Member#: 232940
This isn't the AEM wideband with the analog needle display is it? If it is, that one won't work.
arghx7 is offline   Reply With Quote
Old 12-26-2010, 12:48 PM   #7
SlowImport
Member#: 123720
2003 WRX Wagon
No its the one with the digital numbers in the ceneter with the lights all around the edge.
Thank you for the help though,
Josh
Old 12-30-2010, 05:31 PM   #8
subysportSTI
Member#: 207923
2006 STI paperweight
did you ever figure out the problem? I'll be running an aem as well, just curious in case I have the same trouble
subysportSTI is offline   Reply With Quote
Old 12-31-2010, 06:24 AM   #9
pacificnorthwest
Member#: 257995
2004 wrx
wr
Blue wire out of uego is a serial output.. go to radio shack buy a 9pin db9 connector.. then buy a serial to USB adapter
pacificnorthwest is offline   Reply With Quote
Old 12-31-2010, 03:38 PM   #10
subysportSTI
Member#: 207923
i've heard good things about the bfm logging cable. Any reason I shouldn't get one?
Old 01-11-2011, 08:23 PM   #11
SlowImport
Member#: 123720
2003 WRX Wagon
I just got mine to work. I was having a connection issue with the connectors I was using to connect the AEM blue wire to the BFM wire that goes into the serial port. The cable now works perfectly!
User error FTL,
Josh
Old 04-06-2011, 11:04 PM   #12
jockeygolfs
Member#: 260868
2011 STI
Did you load all the files from BFM? I'm having the same issue you had but I checked the wire connections and they are fine. Romraider tries to connect but it cannot. I'm using windows 7. How about the sim programs that come with the BFM files? Did you use those?
jockeygolfs is offline   Reply With Quote
Old 04-07-2011, 08:07 PM   #13
jockeygolfs
Member#: 260868
2011 STI
Ok, so I have the wideband communicating w the computer. The hyperterminal can log the wideband. But I'm still not able to log on Romraider.
Old 04-07-2011, 09:39 PM   #14
sidewayz
Member#: 5810
2001 S366 2.5RS
You have to click open plugins on romraider and open the proper com port. Then open the aem uego option to display it
sidewayz is offline   Reply With Quote
Old 04-07-2011, 10:03 PM   #15
jockeygolfs
Member#: 260868
2011 STI
Did all of that. The com port at the top left should not be the same as the AEM uego right? that one is for the OBDII connection right?
Old 04-07-2011, 11:41 PM   #16
sidewayz
Member#: 5810
2001 S366 2.5RS
No the obd com port is a different number than the port for the uego.
Old 04-08-2011, 06:20 AM   #17
jockeygolfs
Member#: 260868
2011 STI
Ok thanks for the confirmation. Do I need to have a tactrix cable for the ecu in order to log the wideband? The program says it cannot communicate so maybe it is searching for the ecu and since it cannot find it, it won't log the wideband? The wideband is the only thing I have connected.
Old 04-09-2011, 11:11 AM   #18
sidewayz
Member#: 5810
2001 S366 2.5RS
You just need your own db9 connector to usb for the aem. Thats all you need to log afrs
Old 04-09-2011, 02:24 PM   #19
jockeygolfs
Member#: 260868
2011 STI
Yes, I have the bustedfinger motorsports cable. That is how I'm logging through hyperterminal on the laptop. My tuner says that will work so I guess I don't need the Romraider.
Old 04-11-2011, 06:18 PM   #20
Harley2390
Member#: 275378
All my Paremeters are all saying 0.00 and it says there reading data but there not doing anything..i have the $19.99 BfM cable as well hooked into my lappy and i also have my Tactrix running into my lappy im not logging anything on Romraider cause i was tryin to get a my stock map reading using Ecu Flash. well what i got i guess is my stock an it saved as "Read Image.hex" but when i go to open it under Romraider Or Ecu Flash.. it gives me an Error.. an wont open... can you help me?
Harley2390 is offline   Reply With Quote
Old 05-09-2011, 02:27 PM   #21
fenix-silver
Member#: 231700
2004 WRX Wagon
See this post: http://forums.nasioc.com/forums/show....php?t=2171742
It looks like the newer AEM Uego's (at least my inline one) are using a different baud rate and data format, which would explain why they won't work w/ RR.
fenix-silver is online now   Reply With Quote
Old 05-09-2011, 08:38 PM   #22
jockeygolfs
Member#: 260868
2011 STI
Thanks for the info!! I can now sleep at night!! Hope someone comes up with a solution.
Old 05-10-2011, 09:12 AM   #23
fenix-silver
Member#: 231700
2004 WRX Wagon
I modified the AEM pluging for RR last night and my first test worked. It was getting late so I need to run a longer log just to make sure no issues come up, but suffice it to say that I have a solution for RR.
Old 05-10-2011, 09:54 AM   #24
jockeygolfs
Member#: 260868
2011 STI
I hear angels in the back ground and see a beam of light fromthe heavens.
Old 05-23-2011, 02:58 PM   #25
jockeygolfs
Member#: 260868
2011 STI
So did you fix romraider? Will you be providing everyone with your fix?
AEM UEGO and AEM Analog Wideband gauges 199.80 w/Free Overnight Shipping maperformance Gauges & Electronics 93 06-15-2010 12:02 PM
AEM UEGO and AEM Analog Wideband gauges 218.11 w/Free Overnight Shipping maperformance Gauges & Electronics 106 02-04-2010 01:09 PM
AEM Uego and AEM Analog Wideband gauges now just 207.21 w/Free Overnight!!!! maperformance Gauges & Electronics 13 09-01-2009 11:39 AM
AEM Uego install/ RomRaider lagodcm Interior & Exterior Modification 1 02-10-2009 05:21 AM
