Old 05-23-2011, 02:56 PM   #26
fenix-silver
Member#: 231700
2004 WRX Wagon
Everyone can send me money to my paypal
Sorry I didn't update this thread. The change was implemented into the latest RR release candidate: http://www.romraider.com/forum/viewt...hp?f=14&t=7221
fenix-silver is offline   Reply With Quote
Old 05-23-2011, 03:13 PM   #27
jockeygolfs
Member#: 260868
2011 STI
We are not worthy!!!!!!!! Awesome!!
jockeygolfs is offline   Reply With Quote
Old 05-26-2011, 10:18 AM   #28
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Just wanted to post and update. I got my AEM digital UEGO installed and hardwired on a serial cable.
I messed around with it a bunch on my laptop and couldn't get anything to work. Installed everything on my brother's laptop and it works fine! Appears mine works on the 9600 data rate setting. Logged half a dozen pulls last night. Works great!
xluben is offline   Reply With Quote
Old 05-26-2011, 10:31 AM   #29
Uncle Tattoo
Member#: 139542
2007 Civic Sedan
Daily driver status son
i was having a problem last night getting romraider to log the Uego and the tactrix at the same time. i got completely lost when trying to install everything and have no idea what i need to do. i got the Uego to show up in hyperterminal though so i know its connecting. i did update to the new romraider release, is there something i need to do after updating or any special drivers i need? im using the bustedfingermotorsports logging cable.
Uncle Tattoo is offline   Reply With Quote
Old 05-26-2011, 10:32 AM   #30
fenix-silver
Member#: 231700
2004 WRX Wagon
The non inline versions of the Uego are probably not using the higher baud and different data format yet.
Old 05-26-2011, 06:47 PM   #31
jockeygolfs
Member#: 260868
2011 STI
Ok, do you need to have the tactrix cable and the aem cable connected to log the aem? Or can I just connect the aem alone? I do not have a tactrix cable so hopefully that is why I can't log my aem. I'm about to give up!
Old 05-26-2011, 08:23 PM   #32
fenix-silver
Member#: 231700
2004 WRX Wagon
You can log the WB alone using this utility from AEM http://forum.aempower.com/forum/index.php?topic=26370.0
Old 05-26-2011, 09:49 PM   #33
jockeygolfs
Member#: 260868
2011 STI
I f$&king give up!!!!!!!!! I loaded this program and it still did not get it to see the wb. I went into device manager and set it up to match what I set it up for in hyperterminal and it still does not work.
Old 05-26-2011, 10:18 PM   #34
fenix-silver
Member#: 231700
2004 WRX Wagon
So you are successully able to get data in hyperterminal, right? And what baud rate are you using? Also, make sure only one application is connected to the COM port at a time. For instance, if you have hyperterminal open and it is connected to the port, other apps won't be able to read the port too. In the AEM utility, does the COM port of your UEGO show up? If so, what happens when you click 'Connect'?
Old 05-26-2011, 10:33 PM   #35
jockeygolfs
Member#: 260868
2011 STI
Yes I only use one app at a time and make sure to close the other app. I'm using 9600 on hyperterminal. Yes, AEM sees my COM port that I also use on hyperterminal. I hit connect but it does not say connected below the button. Is CNG on the aem program AFR? I see lambda but nothing that says afr. If I do lambda do I need to increase the baud rate?
Old 05-26-2011, 10:42 PM   #36
fenix-silver
Member#: 231700
2004 WRX Wagon
So then you have the older version of the Uego. I'm not positive if that one will work with the AEM utility. I didn't look that closely at the code when I decompiled it. If it doesn't say that it is getting connected in the utility then it might not work with your Uego. The dropdown list is just to pick what units you want the AFR displayed in. For instance 14.7 AFR Gasoline = 1 lambda. In RR what Uego plugin are you using?
Copy and paste some output from the hyperterminal here for me to see.
Old 05-26-2011, 10:52 PM   #37
jockeygolfs
Member#: 260868
2011 STI
Ah so gasoline is what I want to be on which is what I'm used to. In RR I tried both AEM options. I will have to try to post my hyperterminal readings later. I'll pm them to you rather than post here. They are fine since I'm tuned etc. I just want to get this damn thing to work when I do my next tune.
Old 05-27-2011, 08:44 AM   #38
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Update from me.
Works fine on my brother's laptop (RomRaider, Hyperterminal, viewing, logging, etc). Windows 7 64 bit. Beta build of RomRaider. Installed proper driver's for the OBD cable and serial cable. Baud rate set to 9600. Works with or without logging ECU data (can log AEM UEGO by itself).
Does not work with RomRaider on my laptop. Just reads 0. Works fine with Hyperterminal. Windows XP. Beta build of RomRaider. Same drivers for ODB cable and serial cable. Baud rate set to 9600. COM port does show up in RomRaider, and is not being used by anything else (Hyperterminal is closed).
Basically it should be set up identically between the two computers, but it will only work with RomRaider on one of them. But it will work with Hyperterminal on both. I'm just not sure why RomRaider won't pick up on it. Any ideas?
Old 05-27-2011, 08:54 AM   #39
fenix-silver
Member#: 231700
2004 WRX Wagon
I'm not sure why it would be working in one case but not the other. Try enabling trace logging in RR. To do so, open up the log4j.properties file in the RR directory and edit the first line to read:
log4j.rootLogger=trace, file
This should create a log file in the RR directory when you run RR. Try to connect to the Uego in RR and then see if anything shows up in the log file that might point to the problem.
Old 05-27-2011, 09:05 AM   #40
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks. I'll have to give that a shot sometime.
Old 12-20-2011, 01:43 PM   #41
biodude
Member#: 271720
Originally Posted by arghx7 View Post
This isn't the AEM wideband with the analog needle display is it? If it is, that one won't work.
Bumping this for some help. I have an AEM Analog Face Wideband and want to sort this out, It seems the analog version does not have the blue serial data feed for some dumb-ass reason.
I'd like to be able to log with RR anyone figure this out in a relatively easy fashion.
I know I can probably buy the tactrix 2.0 but I'd rather not since I already have a 1.3 cable and I'd like to stay with the analog gauge since I just prefer how it looks.
biodude is offline   Reply With Quote
Old 03-23-2012, 02:48 PM   #42
03WRXer
Member#: 142905
Default Question about AEM UEGO Wideband o2 sensor.
Hey, whats up with all the problems with AEM uego wideband o2 sensors and RR? I have been reading about a bunch of problems people are having with logging the wideband with RomRaider. Some people are saying the newer digital ones don't work?
From what I have read on these forums, only the AEM uego with the digital display will work to log in RR? Why? The analog face AEM uego uses the same o2 sensor, and look like they are the same?
Any info you guys have would be great. I am about to buy a wideband O2 sensor for the sole purpose of data logging, and tuning my v8 JDM STI swap with RR, and I'm gonna be pissed if I get it and it doesnt work....
03WRXer is offline   Reply With Quote
Old 03-23-2012, 02:52 PM   #43
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
The digital ones work, but can be kind of picky with drivers and compatibility with certain computers. As far as I know the analog ones don't work. Not sure why.
Old 03-23-2012, 11:37 PM   #44
03WRXer
Member#: 142905
Thanks. Maybe someone who knows will chime in. Good thing I found this out before I bought the analog one. I figured a AEM uego wideband, was a AEM uego wideband.....
Looks like I'll be getting a digital one even though I think it looks a bit like rice......
Old 03-23-2012, 11:53 PM   #45
alpine9000
Member#: 261505
I have an AEM inline uego (one of the new ones) and it works fine in romraider (and also standalone logging with the openport 2.0). I just wired up a USB adapter and set the baud rate to 19200 and its works great. The newest romraider has a 19200 AEM device you can select.
alpine9000 is offline   Reply With Quote
Old 03-24-2012, 12:35 PM   #46
quazimoto
Member#: 70395
Make sure you install the drivers as admin.
quazimoto is offline   Reply With Quote
Old 03-24-2012, 08:16 PM   #47
03WRXer
Member#: 142905
Hey, can you point me in the right direction? I can't find the info on how to make the serial USB adapter. I know BFM has one for sale for $20, but I'd like to make my own.
I know I need a db9 connector, and a serial to usb adapter. My question is how do I hook the wires up to the db9 connector? Is there just one wire for the blue wire coming from the wideband? The pictures of the BFM one looks like two wires. What pins do the hook up to?
Thank you.
Old 03-24-2012, 09:02 PM   #48
03WRXer
Member#: 142905
Thank you.
Never mind. I found it!!!!
http://forums.nasioc.com/forums/show....php?t=2069248
Post # 14
I got this out of the manual from my wideband,this explains what todo::
Serial Output
The serial output can be used for data logging when an EFI system is not accessible. To run the data stream, a RS-232 (DB-9) Female Receptacle shall be purchased.
1 2 3 4 5
6 7 8 9
Figure 5
Wire View of RS-232 (DB-9) Male Plug Two wires need to be connected to a RS-232 serial port. The BLUE wire from the AEM UEGO Gauge shall be connected to Pin #2 (RX) on the serial port for receiving data. Page 7 Pin # 5 (GND) on the serial port shall be grounded. If a standard 9-pin serial cable is to be cut instead, the (RX) wire is typically RED and the (GND) wire is typically GREEN. However, this should be confirmed with a continuity tester before attempting.
(Figure 5)
Use HyperTerminal for testing the data stream. This software is found on most PCs. To find HyperTerminal go to: Start | All Programs | Accessories | Communications | HyperTerminal. Name the New Connection and click OK. Set the COM port to the one being used and click OK.
Bits Per Second = 9600
Data Bits = 8
Parity = None
Stop Bits = 1
Flow Control = Hardware
Verify the settings above and click OK. When power is supplied to the AEM UEGO Gauge, AFR (or Lambda) data will be displayed, as shown below. (Figure 6)
Figure 6
Data logging with Hyper Terminal UEGO Sensor
If attempting to route the UEGO Sensor through a tight space, AEM recommends temporally removing the light grey latch from the Bosch connector, as shown below, or, routing the smaller six pin connector through the hole.
Old 06-26-2012, 02:46 PM   #49
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
been trying to search on answers to make my uego work with RR. for the wiring part aem says use the white wire for data logging which is what im connected too. am i suppose to be hooked up to the blue wire?
nevermind got it to work
achavez is offline   Reply With Quote
Old 06-30-2012, 10:43 PM   #50
Dadowhip
Member#: 212195
2007 WRX STI
Im having the saving issue trying to work it out using bustedfinger cable and windows 7
Dadowhip is offline   Reply With Quote
AEM UEGO and AEM Analog Wideband gauges 199.80 w/Free Overnight Shipping maperformance Gauges & Electronics 93 06-15-2010 11:02 AM
AEM UEGO and AEM Analog Wideband gauges 218.11 w/Free Overnight Shipping maperformance Gauges & Electronics 106 02-04-2010 12:09 PM
AEM Uego and AEM Analog Wideband gauges now just 207.21 w/Free Overnight!!!! maperformance Gauges & Electronics 13 09-01-2009 10:39 AM
AEM Uego install/ RomRaider lagodcm Interior & Exterior Modification 1 02-10-2009 04:21 AM
