Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 12-26-2010, 12:07 AM   #1
borlarex88
Member#: 192628
2004 Subaru WRX
Java Black Pearl
Default Stock wheel for spare?
I have a set of 18x7.5, 5x100 48 offset, if I bought a stock 04 wrx tire/wheel would that work as a spare? Not sure since its 16", although thicker tire...
I wouldn't drive with it on much, just til I got a new tire on.
Andrew
borlarex88 is offline   Reply With Quote
Old 12-26-2010, 12:16 AM   #2
DreadScourge
Member#: 201184
2001 WRX
So long as the diameter of the spare wheel+tire is equivalent I'd think it should work.
DreadScourge is offline   Reply With Quote
Old 12-26-2010, 12:55 AM   #3
borlarex88
Member#: 192628
2004 Subaru WRX
Java Black Pearl
thanks, so the closest i can get is with a 215/40/16 tire, only 3mm difference
Old 12-26-2010, 12:56 AM   #4
borlarex88
Member#: 192628
2004 Subaru WRX
Java Black Pearl
or 55 rather not 40
Old 12-26-2010, 01:09 AM   #5
DreadScourge
Member#: 201184
2001 WRX
So long as you aren't driving long distances 3mm would be negligible.
Old 12-28-2010, 06:05 PM   #6
borlarex88
Member#: 192628
2004 Subaru WRX
Java Black Pearl
How about a 16mm difference would that be too much?
Old 12-29-2010, 07:43 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
What's the diameter of the tires on your 18x7.5" wheels? If it's roughly the same as the stock diameter, why not just use the stock spare?
Old 12-29-2010, 08:17 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Andrew
This tells us NOTHING
THIS tells us EVERYTHING
Old 12-30-2010, 01:14 AM   #9
borlarex88
Member#: 192628
2004 Subaru WRX
Java Black Pearl
Assuming you mean the donut:
1. I don't have a choice of tire size with the donut in my car; with an extra spare I could choose 205/215/225 (215 is the closest w/16" wheel) so that the diameter difference is minimal.
2. I couldn't even get the donut (which could be inches different in diameter from my current setup) out because of the subwoofer position in my trunk.
3. I'd rather have something more durable than the donut if I need to have it on for a few days.
I have 225/40R18s on, so the total diameter is 637.3mm, closest to a 215/55/16 setup at 642.9mm
Old 12-30-2010, 10:16 AM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Why would you need a choice of size?
... with an extra spare I could choose 205/215/225 (215 is the closest w/16" wheel) so that the diameter difference is minimal.
Which shouldn't matter for a temporary spare.
So are you going to rock a roof rack for a full-size spare? If the donut doesn't fit with your subwoofer I'm not sure how a full-size spare is going to be any better.
And the spare is inches different in diameter from the stock setup, too, so that shouldn't be a concern.
Old 12-30-2010, 05:55 PM   #11
borlarex88
Member#: 192628
2004 Subaru WRX
Java Black Pearl
To minimize the discrepancy between the spare and the other 3 wheels instead of driving around with a donut that could be hovering above the ground.
If anything happens to one of my wheels (I have 4 only, extra one cracked) then I will need to buy a full new set since Tarmac 2s are no longer made. So i'll need to shop around for a little while, then have them mounted, so this spare may not be so temporary if a situation arises.
I'll keep it at home and have a friend bring it to me if I can't get the donut out, but that's really my concern more than anyone else's.
Old 01-02-2011, 01:32 AM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
there is a serious lack of something, here.....not quite sure what...but serious lack
WTB: 06/07 Stock Wheel & Spare Tire PrettyRexx MWSOC Private Classifieds 0 10-03-2008 06:02 PM
WTB '1' 00-01 RS Wheel for Spare CA sekretskwirl Private 'Wanted' Classifieds 0 11-14-2006 10:49 PM
WANTED: single P1 wheel for spare nismo240 Private 'Wanted' Classifieds 0 05-21-2004 02:50 PM
Stock wheel as Spare Tire noggin Brakes, Steering & Suspension 6 04-07-2002 09:04 AM
cheap/steel wheel for spare tire? everbruin Brakes, Steering & Suspension 2 02-12-2002 09:52 AM
