Old 12-26-2010, 03:32 PM   #1
STI223
Member#: 242514
Default What is the thinnest tire I can fit on an 8 inch wide wheel?
I am buying a set of wedsport wheels for my 04 STI. They are 18x8. I just wanted to know what the thinnest tire I can put on them for winter is. Thanks
STI223 is offline   Reply With Quote
Old 12-26-2010, 03:35 PM   #2
STI223
Member#: 242514
And now that I think about it he car is lowered in the front 1 5/8 and the rear 1 3/8. What size tire should i go with?
Old 12-26-2010, 03:38 PM   #3
STI223
Member#: 242514
And the fenders are rolled because I have 255's on the car s summer tires.
Old 12-26-2010, 03:53 PM   #4
gsrcrxsi
Member#: 236952
2010 WRX
Spark Silver
225/40/18 is what i would go with
gsrcrxsi is online now   Reply With Quote
Old 12-26-2010, 04:57 PM   #5
STI223
Member#: 242514
The michelin x-ice has a 215/45/18. Am I better off with that tire or a 225/45/17 continental Extremewintercontact? I know a thinner tire is better. But the continental came in first in their comparison test over the blizzak and the michelin.
Old 12-26-2010, 07:02 PM   #6
Pinned
Member#: 152707
2000 Impreza
BRP
If you're looking for winter tires you can probably find them significantly cheaper for the stock wheels (and you wouldn't risk damaging expensive wedsports).
Also, tirerack.com has options for "minus sized" tires when you select your car, perfecting for getting a narrower winter tire.
Pinned is offline   Reply With Quote
Old 12-26-2010, 07:44 PM   #7
STI223
Member#: 242514
The problem is I have rota's on the car now. I dont have the stock wheels. So its either use the 8.5 inch wide rotas or get these wedsports. Except they are 18x8. But the blizzaks and continentals dont have a 215 tire that would fit. The ones they do have, have too high of a sidewall, I think the shortest is a 55.
Old 12-26-2010, 10:42 PM   #8
LGT+WRX
Member#: 91119
05/9 LGT-me/FXT-wife
ABP-me/SSM-wifey
Between a 215 and a 225, you'd be hard pressed to tell the difference, particularly in winter driving. If you're really worried about not getting enough traction in the nasty winter stuff, jump to the next more aggressively winterized sub-genre (i.e. go from a "Performance Winter" to a "Studless Ice & Snow") - but honestly, my rule-of-thumb is to jump by "20," to see any true difference.
Also, remember, "narrower is better," but that's only really in terms of "cutting through" fresh-powder and slush. On hardpack or ice - as well as clear pavement (wet or dry) - the question again becomes one of contact patch, and having too little is never enough. So as with many things tire-related, it's a give-and-take, a compromise of one or the other. But even exclusive of that, honestly, in the real world, the difference between a 215 and a 225, for this kind of stuff, is really more academic.
So yes, you can probably stretch a tire to get on there, but that'll probably impact the contact patch itself - and on a more practical level, in terms of winter driving, that'll significantly decrease your wheel-face/rim protection. For me, personally, I wouldn't want to go less than a 225-width, on an 8-inch wide rim, especially for the winter.....
LGT+WRX is offline   Reply With Quote
Old 12-26-2010, 11:38 PM   #9
STI223
Member#: 242514
Thanks a lot. I think im gona stay with the rotas and put a set of continentals on them.
What is the biggest tire i can fit on my rims? dewmudgeon Newbies & FAQs 15 10-26-2008 10:40 PM
What is the biggest tire that will fit on STI BBS 17" wheels? pdxwrxsti Tire & Wheel 1 03-11-2005 12:53 AM
17x7.5 rim, what is the widest tire i can fit on these wrxracer55 Tire & Wheel 11 11-02-2003 10:10 AM
what is the biggest tire I can get on a 18 x 7.5 48+ rim? jinxproof99 Brakes, Steering & Suspension 0 03-21-2003 03:44 PM
What is the widest rim that can fit on a WRX pio!pio! Brakes, Steering & Suspension 10 01-18-2002 06:59 PM
Message Board Statistics All times are GMT -4. The time now is 10:40 AM.
