Old 12-29-2010, 03:36 PM   #1
G_REX
Member#: 266384
2011 WRX Limited
Spark Silver Metalic
Default Is this a good size? 18x8.5 et35
2011 WRX Limited and I'm thinking of picking up a set of wheels. They are:
Miro 111 18x8.5 et35
255/35/18 tires
Is this a good offset? Will I rub on the fender?
My other options are:
Rota SVN 18x9 et40
Rota Gravel 18x8.5 et44
I just want to go different route than rota!
G_REX is offline   Reply With Quote
Old 12-29-2010, 03:43 PM   #2
G_REX
Member#: 266384
2011 WRX Limited
Pics of 18x8.5 et35 on a GR Sti are welcome!
Old 12-29-2010, 04:13 PM   #3
wtwwholesaletire
Vendor
Member#: 98066
2003 forester
white
IMO the 18-8.5 +35 will require a fender roll
wtwwholesaletire is offline   Reply With Quote
Old 12-29-2010, 04:36 PM   #4
wtwwholesaletire
Vendor
Member#: 98066
2003 forester
white
Have You seen the new TSW Nurburgring?18-8.5 +45mm 19.5 lbs
Rotary Forged the rim of the wheel is forged at high pressure while the wheel is spun at high speed.This alters the molecular structure and enhances the strenght of the alloy.The benefit is a much lighter weight than a regular cast wheel.Most importantly,the weight saving is in the outer rim of the wheel which dramatically reduces rotational mass and enhances vehicle performance.
we have a deal on them [email protected]
Old 12-29-2010, 07:51 PM   #5
G_REX
Member#: 266384
2011 WRX Limited
pm me a price!
Old 12-29-2010, 09:26 PM   #6
sc00by4life
Member#: 97135
Miro is on the same level as rota, quality wise at least they seem pretty good. 18x8.5 +35 is not even close to needing a roll on a 2011. Pics when you get them installed!
Old 12-30-2010, 09:37 AM   #7
wtwwholesaletire
Vendor
Member#: 98066
2003 forester
white
Does the 2011 have a diferent off set than the 2010?
Old 12-30-2010, 10:38 AM   #8
G_REX
Member#: 266384
2011 WRX Limited
idk... the 2011 offset is 53
Old 12-30-2010, 12:05 PM   #9
mosc
Member#: 177401
2015 STi White
Yes, the 2010 and 2011 have a different offset, no it's not significant. The WRX is as follows:
02-05: +53
06-10: +55
11: +53
mosc is offline   Reply With Quote
Old 12-30-2010, 12:37 PM   #10
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
+35 is too low of an offset.
Byzantium is offline   Reply With Quote
Old 12-30-2010, 02:56 PM   #11
sc00by4life
Member#: 97135
yes slightly difference offsets (and I believe different wheel widths), but the '11s all have the wider sti-style fenders. there are guys running 18x9.5 with 265's and no rolling.
Old 12-30-2010, 03:04 PM   #12
.clipse
Member#: 212265
2013 Legacy
pics of the nurburgrings on a subie?
.clipse is offline   Reply With Quote
Old 12-30-2010, 09:44 PM   #13
FilthyFlushWRX
Member#: 259798
2001 Ridin Dirty
I agree that +35 should be fine on a 8.5", you might need a slight slight roll if not any. You will be fine. By the way i was looking into those Miro111 myself, that BMW is 19s in that picture and the rears are for sure their 9.5" and the fronts are 8.5", don't have that much concavity. If had your car, I would do the 9.5" all around.
FilthyFlushWRX is offline   Reply With Quote
Old 12-31-2010, 09:44 AM   #14
wtwwholesaletire
Vendor
Member#: 98066
2003 forester
white
18-9.5 with what off sett?
on a 09 sti the wheel hung outside the fender on a 18-8.5 +35 enough to groove the tire, right rear.
Old 12-31-2010, 12:50 PM   #15
sc00by4life
Member#: 97135
You HAVE to add camber. 0 camber is not only DANGEROUS but is not how you properly set up a car for an "aggressive" fitment.
read this thread: http://forums.nasioc.com/forums/show...t=rota+d+force .18x9.5 +40 on a (2010?) sti with 265's. No roll required (that car has the rears rolled to fit 275's on another set of wheels). One of my buddies has an 09 with 17x10 +20 w/ 255's rolled front and rear fenders.
Old 12-31-2010, 03:02 PM   #16
DrDanimalSize
Member#: 254097
2010 2014 Impreza
Who makes a 17x10 5x100 wheel? Or are we talking STi so 5x114?
DrDanimalSize is offline   Reply With Quote
Old 12-31-2010, 03:17 PM   #17
sc00by4life
Member#: 97135
Yea, 5x114.3.
Old 01-03-2011, 09:58 AM   #18
wtwwholesaletire
Vendor
Member#: 98066
2003 forester
white
Good tip Thanks.
How is it done properly? roll or no roll? in terms of keeping it track ready
Old 01-03-2011, 10:06 AM   #19
wtwwholesaletire
Vendor
Member#: 98066
2003 forester
white
Originally Posted by G_REX View Post
pm me a price!
did you recieve?
Old 01-03-2011, 10:11 AM   #20
wtwwholesaletire
Vendor
Member#: 98066
2003 forester
white
[no picks but we just put a set on a Audi A8 20-9 and all i can say is BOSS
Old 01-03-2011, 11:18 AM   #21
G_REX
Member#: 266384
2011 WRX Limited
did you recieve?
I did. Still deciding on wheels tho... Thank you!
Old 01-03-2011, 11:21 AM   #22
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Huh, that's weird. I know I've seen people running +35mm offset and even less than that. What makes it too low?
Old 01-04-2011, 09:16 PM   #23
G_REX
Member#: 266384
2011 WRX Limited
nothing! It's perfect!
Old 01-04-2011, 10:36 PM   #24
Byzantium
Member#: 207826
85k 2002 WRX
Don't bother with that game. You already know the answers. I can run 22"s on the car and they will fit, does the fact that it can be done make it a good idea?
Perfect if you don't know anything about or care about your car.
Old 01-04-2011, 10:41 PM   #25
G_REX
Member#: 266384
2011 WRX Limited
so, will will you explain what make it a bad fit?
18x8.5 ET35 Enkei Wheels for sale. ej257gd Wheels/Tires 38 04-28-2008 06:16 PM
FS: BBS RGR 18X8.5 et35 5X100 tatarin Wheels/Tires 21 03-14-2008 10:27 AM
Help on tire size 18x8.5 wheel BlackSnake Tire & Wheel 18 08-10-2006 05:19 AM
Is this a good deal - 2.5 RS 2004? ehsfriend Newbies & FAQs 11 10-19-2003 05:24 PM
Is this a good hose kit? Size, quantity, etc? ezatnova Interior & Exterior Modification 4 03-21-2002 10:05 AM
