Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 12-30-2010, 05:28 AM   #1
kirbykirb
Member#: 183596
2005 WRX/9-2x
Obsedian Black Pearl
Default Going catless in a 96' Outback? Any direct replacement part?
So my cats are acting up, I don't have emissions where I am and I don't exactly just want to run headers....
Is there something product out there that makes a direct mid pipe for my two cats? Just looking for something to connect headers to muffler and that's it
Does such an item exist? I hope so..
And golly gee that means I also need to do something about the O2 sensors too
kirbykirb is offline   Reply With Quote
Old 12-30-2010, 11:07 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
TWE and Stromung both made track pipes. I don't know if they still do, nor how much they cost. You might be able to find one in the Classifieds here or on RS25.com - I've seen them advertised periodically.
Or you might be able to convince a local shop to just make you one. It's not like it's all that complex a shape.
Old 12-30-2010, 04:07 PM   #3
PA-Outback2000
Member#: 161832
2000 Outback Limited
check boxer4racing.com for the stromung
PA-Outback2000 is offline   Reply With Quote
Old 01-24-2011, 10:19 PM   #4
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
O2 sensors are easy (I did mine). Spark anti-foulers! Drill them out and install. Clear codes and you're good to go. I'm still on the fence as to wether or not it was worth it though, the cars not running great but I don't really know if it's because of the exhaust. I doubt it though.
Frogsthatmoo is offline   Reply With Quote
Old 01-26-2011, 12:11 AM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Grab yourself a borla replica from ebay, and have an exhuast shop make a 2.25" exhaust from the header back. Just make sure to have a high flow cat converter between the two oxygen sensors and your good.
You might have to get a spark plug anti-fouler for the rear ox. sensor, that's what I did, and I haven't had a po420 code in a long time. You can run catless if you want but your car and Captain Planet will b*tch at you if you do.
Captain Planet... earth, wind, fire, water, and the lamest power ever, heart...
~Josh~
Old 02-01-2011, 08:34 PM   #6
surfskater2003
Member#: 267991
2001 legacy b4 rsk
white
Default weld
if you find someone who can weld, they can cut your cat off and weld a pipe where the cat used to be. Then get a O2 sensor bung that is longer so it wont throw codes.
surfskater2003 is offline   Reply With Quote
Old 02-02-2011, 12:24 AM   #7
subiman2005
Member#: 151686
2004 GTP Comp G
99 Legacy Sold
Supers on rs25.com sells catless track pipes for like 240 shipped include all hardware and gaskets....its complete stainless and complete bolt in fits just like oem cat section
subiman2005 is offline   Reply With Quote
Old 03-03-2011, 10:25 AM   #8
loose Subie
Member#: 262067
Took my primary cat out and went single 2 1/4" high flow cat, made a huge difference. Likely due to the fact that original cats with super high milage
loose Subie is offline   Reply With Quote
Old 03-27-2011, 12:50 PM   #9
grzydj
Member#: 84984
2006 Impreza 2.5i 5D
'04 Toyota Tacoma TRD
What size did you use for yours?
grzydj is offline   Reply With Quote
for sale 96' outback w/ 54K miles m5mel Private Vehicle 'For Sale' Classifieds 4 04-25-2006 04:57 PM
for sale 96' outback w/ 54K m5mel Private 'For Sale' Classifieds 1 04-24-2006 10:57 AM
going catless in NNJ Focus4 Tri-State Area Forum 9 05-20-2005 09:07 PM
Going catless in Cali j-wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-15-2004 10:14 PM
Lost the bolt in my MRT endlink - car driveable? Replacement parts? sonicblue Brakes, Steering & Suspension 15 12-05-2003 05:28 PM
