Old 12-30-2010, 08:45 AM   #1
CBXJ
Member#: 265789
2006 LGTx2,WRX,OBS
Default sreering rack, crossmember tie rods?
Hi, so I'm in the middle of swapping a turbo into my 97 leggy o/b. I'm using a 05 sti crossmember and my leggy rack won't bolt up. I can get the 05 rack BUT are the tie rods the same dia? Will the p steering hoses fit? Someone please give me a thumbs up or thumbs down I would like to get the old wagon on the road again. Thanks
CBXJ is offline   Reply With Quote
Old 12-31-2010, 01:44 AM   #2
FLUBYUx2
Member#: 3856
2001 Impreza 2.5RS
sedona red pearl
I thought I read that you're supposed to use the tie rod ends off the donor car. But doesn't the stock steering shaft not mate up to the gd sti rack?
FLUBYUx2 is offline   Reply With Quote
Old 12-31-2010, 07:56 AM   #3
CBXJ
Member#: 265789
2006 LGTx2,WRX,OBS
I only have the sti crossmember. The leggy Rack is close to fitting but the shape of the rack Is more square on the drivers side. The Sti rack appears to be round at both mounting locations.(going by the shape of the mounting locatios in the sti crossmember) I'm wondering IF I buy the sti rack will I be able to bolt up to the steering shaft and attach my ps hoses?
Old 01-01-2011, 07:07 AM   #4
FLUBYUx2
Member#: 3856
2001 Impreza 2.5RS
sedona red pearl
I def remember Mach v doing a full sti swap and the sti rack wouldn't bolt up to the steering shaft of the gc. It had to be cut down and rewelded together. But that was on a gc. Maybe a leggo is diff?
Old 01-01-2011, 04:46 PM   #5
TheLordChesterfield
Member#: 234539
Hate to be the bearer of bad new, but this happened to me. The rack you're using has differently shaped mounts - if you look at the '05 STI crossmember the rack's mounts are round. You have to get a new rack or crossmember.
Kinda sucks, but oh well did you expect it to be easy?
Let me know if I can help more - I've got some crossmembers laying around.
TheLordChesterfield is offline   Reply With Quote
Old 01-01-2011, 05:51 PM   #6
CBXJ
Member#: 265789
2006 LGTx2,WRX,OBS
Ok by the looks of the last two posts, here is what I know. My orig leggy crossmember won't work with my EJ20(t),so it must go. The sti crossmember I bought won't play nice with my leggy rack. The matching sti rack (that I was about to buy) won't play nice with my leggy steering shaft. Given that I don't really desire the quick rato of the STI rack I should just sell the Sti crossmember (or trade if I find the right person) so I can keep my leggy rack and shaft. So yes. Do you have a turbo crossmember that takes the "non round" rack?
Old 01-01-2011, 05:54 PM   #7
MannyMohawk#5
Member#: 98807
1999 RSTi
RHD BF5 & BJ6
You either need the STi rack, or an 04 or older STi/WRX crossmember (I'm not sure when or if the rack design changed on the regular WRX). The best thing you could do is get an older turbo legacy crossmember.
With the WRX/STi crossmember, you'll have to modify the knuckle between the rack and column, you'll need different lines, and you'll need to shim the control arms where they bolt into the rack.
MannyMohawk#5 is online now   Reply With Quote
Old 01-01-2011, 06:15 PM   #8
TheLordChesterfield
Member#: 234539
Yes, I do have 2 crossmembers that will work. Shoot me a PM if you want one. I can take some pictures to verify.
Incorrect - I tried every way possible to mount the square forester rack into the STI crossmember and it is definitely not possible without major modification and would be unsafe. Especially if you're asking this question on the internet in the first place.
Old 01-01-2011, 09:54 PM   #9
MannyMohawk#5
Member#: 98807
1999 RSTi
RHD BF5 & BJ6
What did I say that was incorrect? I NEVER said his old rack would bolt into the 05 STi crossmember, we already established that. If he uses the 04 STi crossmember it will, but he will still need to do the things I mentioned. This is the exact set-up I have used on a swap car. If you don't know what you're talking about, don't discount others that have actually done it.
Old 01-01-2011, 11:22 PM   #10
CBXJ
Member#: 265789
2006 LGTx2,WRX,OBS
I think I see where the confusion is. If I use a PRE 05 sti wrx crossmember I can use my old ( square) rack , right? So if I'm using my old rack I don't need to modify the steering shaft, I just have to shim the lower arms. Did I get that right? And mostly, thanks. It's great to have some people with experience to bounce things off.
Old 01-01-2011, 11:31 PM   #11
69subaru360
Member#: 159682
1995 WRX
2015 F150
Use a jdm 93-01 wrx or usdm 91-94 turbo legacy crossmember and your existing rack and control arms will bolt in.
Use an 02-04 usdm wrx crossmember and your existing rack and control arms will bolt in but you need to shim the control arms with a couple washers, no big deal.
It's that easy.
Old 01-02-2011, 01:34 AM   #12
MannyMohawk#5
Member#: 98807
1999 RSTi
RHD BF5 & BJ6
I think I see where the confusion is. If I use a PRE 05 sti wrx crossmember I can use my old ( square) rack , right? Yes So if I'm using my old rack I don't need to modify the steering shaft (you shouldn't have to, but it may be different because it's a Legacy), I just have to shim the lower arms. Yes Did I get that right? And mostly, thanks. It's great to have some people with experience to bounce things off.
This is your best option.
It's that easy.
There you go.
Old 01-02-2011, 09:51 AM   #13
CBXJ
Member#: 265789
2006 LGTx2,WRX,OBS
MOST EXCELLENT!, thanks everybody, I've got the info, I've PM'd TheLordChesterfield about a rack, and now back out to the chilly garage to do all the thngs that DON't involve the crossmember/steering for a few days..
and your right.. it's not soooo easy.. the devil is, (as usual), in the details.
Old 01-02-2011, 09:33 PM   #14
TheLordChesterfield
Member#: 234539
Must have misunderstood what you meant - just want to make sure he has correct info. I'll snap some pictures of the differences between the 2 and email them to you.
Old 01-02-2011, 09:35 PM   #15
CBXJ
Member#: 265789
2006 LGTx2,WRX,OBS
My brain farrrt above should read crossmember not rack arrg
FS: (PA) 02 WRX Steering Rack w/ Tie Rods LuckyStar Suspension/Brakes/Handling 6 05-28-2010 11:33 AM
FS- NY 2006 STi steering rack w/tie rods 4k miles turbotoyzz Suspension/Brakes/Handling 0 11-30-2007 06:39 PM
Steering rack and tie rod trouble roofis Brakes, Steering & Suspension 4 11-03-2005 11:21 PM
Tie rod boot/steering rack grease? Replacing torn boot. Sean Service & Maintenance 2 12-30-2004 09:18 PM
Tie rod boot/steering rack grease? Replacing torn boot. Sean Brakes, Steering & Suspension 2 12-30-2004 05:42 PM
