Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Closed Thread
Old 12-30-2010, 01:58 PM   #1
PREracing
Vendor Sales Rating: (5)
Member#: 134615
02 WRX TIME ATTACK
CARBON
Default Defi, Turbosmart, Innovate, AEM - In stock ready to ship!
All orders over $99 receive free domestic shipping.
Defi Racer Gauges in Blue, White, and Red
  • Stepping motor "STEP MASTER VS-2" provides smooth operation.
  • Ignition ON initiates self-luminescence gauge.
  • Illumination using high-brightness LEDs
  • Lightning-like Opening / Closing mode
  • Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup.
  • Full 270 degrees sweep dial provides ultimate visibility.
  • A mounting bracket and instrument case is provided with the product.
  • The red triangle of the regular position bezel can be used as a warning indicator and others.
  • Does not require the Defi-Link Control Unit for use.
Gauges Available in Red Racer, White Racer, and Blue Racer. FREE SHIPPING!
Exhaust Gas Temperature EGT (52mm) - MSRP $266.00 Our Price $252.70
Pressure (52mm) - MSRP $266.00 Our Price $252.70
Oil/Water Temperature (52mm) - MSRP $182.00 Our Price $172.90
Turbo/Boost 30psi (52mm) - MSRP $217.00 Our Price $206.15
Volt (52mm) - MSRP $145.00 Our Price $137.75
PREracing is offline
Old 12-30-2010, 02:15 PM   #2
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
All Innovate Wide-bands qualify for FREE SHIPPING!
Innovate DB Gauge / LC-1 Kit Wideband Gauge & Controller
Available in Red and Blue
This kit comes complete with the patented award-winning LC-1 Wideband Controller, DB-Red Gauge, Bosch 5-wire Wideband 02 Sensor, Bung/Plug Kit, Software CD, and quick start guide. Easily interfaced to any laptop with included serial cable for full datalogging capability.
MSRP $289.00 Our Price $229.00
Innovate LM-2 Kit (Single Wideband O2) - Digital Air/Fuel Ratio Meter and Datalogger
MSRP $479.00 Our Price $419.00
The LM-2 Kit (Single Wideband O2) includes the LM-2 meter, Bosch wide-band oxygen sensor, 8 ft sensor cable, cigarette-lighter power adapter, analog in/out cable, ODB-II/CAN interface cable, SD memory card, USB cable for PC connection, weld-in bung and plug, LogWorks software CD, and quick-start guide. Carrying Case also included!
The LM-2 combines an air/fuel ratio meter, a full-function 32-channel datalogger, and powerful software to deliver a complete tuning workshop for less than the cost of one dyno day. Whether you have a piggy-back fuel controller, race carb, aftermarket ECU, ODB-II tuning software, or a flash/chip programmer, an LM-2 is the tool you need to dial in maximum HP. The meter’s award-winning digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-2’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
Patented “Direct Digital” Wideband Technology
Wideband O2 Compatible with ALL fuel types
Single or Dual Channel Version Available
OBD-II Scan tool- read/clear DTCs and log up to 16 channels of CAN OBD-II Data
  • Log directly to SD card (included)
  • Playback log data on screen and/or with powerful LogWorks software (included)
  • Large high-contrast graphics LCD
  • Built-in RPM converter (direct frequency or with optional inductive clamp)
  • 4 fully-differential analog inputs
  • 2 configurable linear analog outputs
  • Positive lock connectors for all connections
  • Innovate MTS serial IN and OUT
  • USB connection to your PC
The LM-2 also features two fully programmable linear analog outputs to connect to analog gauges, dyno computers, ECUs, piggyback controllers, and other devices with analog inputs. Analog output 1 comes setup from the factory ready for narrowband simulation; analog output 2 is configured as 0 volt = 7.35 AFR and 5 volts = 22.39 AFR. With the provided LM Programmer software these analog outputs may also be configured by the user.
Old 12-30-2010, 02:19 PM   #3
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
Turbosmart e-Boost2
This is one of the most advanced electronic boost controllers on the market today. More than just a boost controller, e-Boost2 puts you in total control of your turbocharger. With a host of features and state-of-the-art software, e-Boost2 is the one accessory all owners of turbocharged cars should have! Easy to use, yet technologically advanced, e-Boost2 is equally at home in a street-going vehicle as it is in a top-level race car.
e-Boost2 Features:
  • NEW - Boost On Demand feature allows the user to select a boost group for a preset amount of time. An instant overtaking power at a touch of a button!
  • NEW - redesigned User Interface helps in navigating through the menus.
  • NEW - bezel and face design featuring larger, easier to use function buttons.
  • Factory Preset Mode provides beginners with an easy start-up option.
  • Advanced User Mode unlocks up to 6 alternate boost mapping functions. Presets for FWD, RWD, AWD, Bike and Drag racing needs.
  • Gear-based Boost Mapping lets you set a different boost for each gear!
  • Adjustable Boost Levels can also be mapped against TIME or RPM.
  • Fully programmable auxilary output controls water spray, methanol or nitrous injection
  • RPM Compensation Feature eliminates boost drop-off at high RPM
  • Peak Hold/Max Boost Recall function monitors boost and RPM.
  • Programmable Display can be configured to KPA, Bar or PSI
  • Gate Pressure function eliminates wastegate creep
  • Accurate Display to within +/-0.5% of full scale making it an ideal Boost Gauge!
  • Programmable, audible warning alarm
  • Integrated input for optional shift/warning lights
Starting at $539.10, in stock ready to ship!
*dashmount pod available here
Turbosmart e-Boost Street
A brand new electronic boost controller aimed at the street performance market. It features many boost control capabilities found on its big brother the e-Boost2, continuing the e-Boost tradition of providing class leading boost control, value for money and no nonsense features.
Features of the Turbosmart e-Boost Street:
  • 2 boost settings - easily selected via the turn-and-push button. An external switch can also be used to change between boost groups if required.
  • Boost correction factor eliminates a problem many street cars with standard turbo systems suffer from boost drop off at high RPM.
  • An easy-to-read 3-segment display with adjustable brightness can be configured for PSI, KPa, or BAR and will flash when warning of over boost shutdown or rev limit, allowing the unit to be used as a boost gauge, tachometer, or a shift light.
  • Housed in a black anodized aluminum case 80mm wide x 25mm high x 95mm deep allowing the unit to be mounted within a _ DIN size opening.
  • Maximum boost level: 40PSI
  • Display mode: Live display of Boost or RPM
Our Price: $355.50, in stock ready to ship!
Old 12-30-2010, 02:58 PM   #4
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
AEM TRU-BOOST - Boost Controller Gauge
MSRP $318.80 Our Price $275.00
  • No external interface required for programming!
  • Complete system includes harness, boost hose, on-board 29 PSIg pressure sensor (external 75 PSIa optional), boost solenoid, gauge display and all necessary fittings
  • Quick connect technology eases the installation process
  • Two user selectable boost settings with peak boost memory
  • Scramble boost setting allows user to momentarily change boost levels
  • User selectable Overboost alarm includes two timed shutdown levels at 10% and 20% Overboost
  • User configurable gauge includes 24 scalable LEDs, and interchangeable bezel, pin guide and faceplate to customize look of display
  • One (1) low-side output included for warning lights
Old 01-03-2011, 01:34 PM   #5
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
Bump for January! Tax season is on it's way!
Old 01-04-2011, 04:38 PM   #6
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
bumppp
Old 01-06-2011, 08:44 PM   #7
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
bump!
__________________
[CENTER][B]
| 13339 NE Airport Way STE500. Portland, OR 97230 | 503-619-0055
Have a group buy request? PM US![/B][/CENTER]
Old 01-07-2011, 07:27 PM   #8
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
bumP!
__________________
[CENTER][B]
Old 01-09-2011, 10:30 PM   #9
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
bump!
__________________
[CENTER][B]
Old 01-13-2011, 05:38 PM   #10
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
bump!
For the best deal on Turbosmart products please PM me. I am very willing to work with you to get you what you need!
__________________
[CENTER][B]
Old 01-18-2011, 01:13 PM   #11
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
bump!
__________________
[CENTER][B]
Old 01-20-2011, 02:09 PM   #12
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
bump!
__________________
[CENTER][B]
Old 01-22-2011, 04:59 PM   #13
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
weekend bump!
__________________
[CENTER][B]
Old 01-23-2011, 05:23 PM   #14
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
Sunday Football BUMP!
__________________
[CENTER][B]
Old 01-26-2011, 09:19 PM   #15
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
Humpday Bumpday!
__________________
[CENTER][B]
Old 01-27-2011, 09:04 PM   #16
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
bump^_^
__________________
[CENTER][B]
Old 01-28-2011, 08:29 PM   #17
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
Tgif!
__________________
[CENTER][B]
Old 01-29-2011, 07:29 PM   #18
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
Just got a big stocking order of the eBoost street 40psi's in! These things rock!
__________________
[CENTER][B]
Old 01-30-2011, 07:41 PM   #19
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
probowl bump!
__________________
[CENTER][B]
Old 02-03-2011, 08:59 PM   #20
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
bump!
__________________
[CENTER][B]
Old 02-04-2011, 11:03 PM   #21
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
Friday night bump
__________________
[CENTER][B]
Old 02-07-2011, 12:12 AM   #22
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
bump!
__________________
[CENTER][B]
Old 02-10-2011, 12:28 AM   #23
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
Less than a month before the racetrack opens up here in Portland!
__________________
[CENTER][B]
Old 02-10-2011, 11:54 PM   #24
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
If you find a lower shipped price let me know and I will see what I can do to beat it!
__________________
[CENTER][B]
Old 02-12-2011, 10:23 PM   #25
PREracing
Member#: 134615
02 WRX TIME ATTACK
CARBON
Working late on a Saturday night...
bump for the weekend!
__________________
[CENTER][B]
Closed Thread
Defi BF gauges in stock ready to ship today! Also, ATI gauge pods. Special prices. GNV Motorsports Interior/Dressup/Audio & Security 32 11-16-2006 01:26 PM
Defi BF gauges in stock ready to ship today! Also, ATI GAUGE PODS! 10% off! GNV Motorsports Interior/Dressup/Audio & Security 2 08-01-2006 11:45 AM
KPH to MPH convertors are finally in stock ready to ship IA Performance Drivetrain 6 11-01-2004 02:14 PM
All Defi products in stock ready to ship (BF, Imperial, VSD and D Gauge) RavSpec Interior/Dressup/Audio & Security 25 04-30-2004 01:07 PM
