Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 10-04-2014, 08:42 AM   #1
Member#: 135188
12 Subaru Sti
white
Default 1st 9 sec 2015 Subaru Sti / The Shop Ct runs [email protected]
The Shop Ct 15 Subaru Sti goes [email protected] with 143 mph being the best trap speed of the night and with 2 psi left on the table to fully utilize the 680 whp that we made with new set up .
Event: Dyno tune
Ambient Temp: 85
Elevation: 1290ft
Weather: Clear
Car: 2015 STI
Tuner: The Shop CT
Dyno Info: Mustang Dyno
Transmission: 15 STI 6spd
Gear: 4th
Target Boost: 32-33 psi
Target AFR: 11.7
Fuel: E70
Wiseco Pistons 8:9:1
Manley I-beams
ARP L 19 Head Studs
ACL Main and Rod Bearings
NGK Iridium IKH 24 Spark Plugs
GSC S2 Cam Shafts
Head games race prepped cylinder heads
Ferrara Spring/ Retainer Kit
ID 1300cc Injectors
Buschur Racing - Modded twin in tank Walbro fuel pumps - Hard wired
ETS FMIC
ETS Header
ETS Turbo Kit with Precision 6466 BB
Cosworth Intake Manifold
TGV Deletes
AP Fuel Rail Kit
Turbo Smart FPR
Perrin - Oil / air seperator
Clutch Masters - Twin disc clutch / flywheel kit
COBB AP V3
Grimspeed EBCS
Ark cat back exhaust
JK@THESHOPCT is offline   Reply With Quote
Old 10-04-2014, 09:15 AM   #2
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Is this the new 6266 or possibly the 6466? Still on a single in-tank fuel pump? Lots of power or the basic fuel setup that's listed. I like it!
Old 10-04-2014, 11:47 AM   #3
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
thats alot of WHP for 1300cc injectors....whats base fuel pressure and IDCs?
Old 10-04-2014, 02:43 PM   #4
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
I'm at 90 with id2000 stock lines tank to bay with twin 416lph pumps.
Old 10-04-2014, 03:26 PM   #5
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
Those 1300cc are flowing like 2000cc somehow.
wil06STI is offline   Reply With Quote
Old 10-04-2014, 03:28 PM   #6
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
Is this a closed deck block? Any plans to run more than 30 psi?
Old 10-04-2014, 03:46 PM   #7
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Injector dynamics are good for 100psi. Who knows depends on his fuel pressure relief valve I would think.
Old 10-04-2014, 06:29 PM   #8
PowerTrip
Member#: 158674
'15 STi Limited
Such a KILLER build .
PowerTrip is offline   Reply With Quote
Old 10-04-2014, 09:10 PM   #9
Member#: 135188
12 Subaru Sti
white
PT 6466 , BR ( Buschur Racing ) - twin in tank pump set up .
- Jimmy
Old 10-04-2014, 09:11 PM   #10
Member#: 135188
12 Subaru Sti
white
They indeed are
- Jimmy
Old 10-04-2014, 09:12 PM   #11
Member#: 135188
12 Subaru Sti
white
Stock open deck block running 32 ish psi .
- Jimmy
Old 10-04-2014, 09:13 PM   #12
Member#: 135188
12 Subaru Sti
white
The BR modded Walboro twin pumps are doing work for sure !
- Jimmy
Old 10-04-2014, 09:14 PM   #13
Member#: 135188
12 Subaru Sti
white
60 psi base fp .
- Jimmy
Old 10-04-2014, 09:14 PM   #14
Member#: 135188
12 Subaru Sti
white
Thank you for the kind words !
- Jimmy
Old 10-04-2014, 11:59 PM   #15
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Originally Posted by [email protected] View Post
The BR modded Walboro twin pumps are doing work for sure ! - Jimmy
Nice! Just didn't update?
Old 10-06-2014, 08:54 AM   #16
Usch
Member#: 383559
2015 STI
Absolutely beautiful
Usch is offline   Reply With Quote
Old 10-06-2014, 08:39 PM   #17
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
you just have a bottleneck somewhere. Most likely the stock fuel lines. Sure I agree they are making tons of power on small injectors but they may have aftermarket fuel lines. ( i didnt read)
Often when someone runs out of fuel they assume its an injector maxxed out issue when its almost always a fuel pump volume issue.
Im showing 24% duty cycle at 40 psi with id2000s and -12 feed line/weldon pump (stock fuel pressure at idle)
Old 10-06-2014, 09:28 PM   #18
vexed rex
Member#: 403323
Nice car. That was a wicked launch, it was gone in a blink of an eye. Reppin' CT too!
vexed rex is offline   Reply With Quote
Old 10-06-2014, 09:58 PM   #19
Member#: 135188
12 Subaru Sti
white
Video of the 10.1 and 10.2 passes !
Old 10-06-2014, 11:50 PM   #20
user1029
Member#: 57064
2008 STi IAG built
HTA86, Meth, 272s, Cos IM
^^^legit
user1029 is offline   Reply With Quote
Old 10-07-2014, 01:10 AM   #21
montanasuby
Member#: 204866
2004 Forester XT
Nice car
montanasuby is offline   Reply With Quote
Old 10-08-2014, 07:35 AM   #22
jacks-GTB
Member#: 303949
2007 Liberty GTB
Wicked build
jacks-GTB is offline   Reply With Quote
Old 10-08-2014, 11:22 AM   #23
SubeySTi2011
Member#: 303722
2015 WRX STi
Congrats. Can't wait to get mine going
SubeySTi2011 is offline   Reply With Quote
Old 10-08-2014, 01:34 PM   #24
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Any more details available on the Buschur racing twin pump setup? I'd like to see how its setup.
Is the rest of the fuel supply setup stock in this car or are there bigger lines run from the pumps to the rails?
WRXt4cy is offline   Reply With Quote
Old 10-12-2014, 10:21 PM   #25
Member#: 135188
12 Subaru Sti
white
Please feel free to contact David @ BR with any and all questions you may have regarding his modified STI twin pump fp hanger as this was the first twin pump fp assembly that has been modded for the Sti , he would be better suited to answer any and all questions regading this .
The fuel system is still stock retaining all the factory fuel lines for the exception of the Ap fuel rails .
- Jimmy
