Old 12-31-2010, 12:29 PM   #1
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Default muffler/cat bypass
has anyone ever run a seperate exhaust pipe by the cat and muffler (straight-pipe) but have it run off an electronically controlled butterfly valve? i was thinking about this and how much work it would take. it seems like it wouldn't be too difficult, with the exception of the butterfly valve (i can't quite imagine if it would work or not). this would be street legal...as long as you were using the stock exhaust...how ungodly loud would this end up being? and would it even sound good or just noise?
drewvdw is offline   Reply With Quote
Old 12-31-2010, 01:12 PM   #2
Web Foot STi
Member#: 39086
2004 STi
Something like this?
http://www.xcceleration.com/itemdeta...83.htm#stealth
Getting a second pipe ahead of the cat could be a little tough...
Web Foot STi is offline   Reply With Quote
Old 12-31-2010, 03:34 PM   #3
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
bingo, we have a winner, thats exactly what i was looking for! but instead of keeping the catted dp, i would swap in a catless dp and cut the oem cat off the flanges and bends (so its just a straight piece), weld the flanges back on to the "new" cat, place that somewhere between the dp and muffler. i wouldn't forget to move any sensors as well. that way you could bypass it easier...would it be better to bypass them seperately or with one straightpipe? it seems like it could be more difficult to do it all at once, but cheaper and higher flowing as well...i gotta get under my car to see for sure...
Old 01-01-2011, 01:47 AM   #4
sorrowfulkiller
Member#: 170439
I <3 Lamp
Interesting idea to say the least, make sure you post pics if you follow through
sorrowfulkiller is offline   Reply With Quote
Old 01-01-2011, 02:35 PM   #5
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
i definately will if i end up doing it.
off topic, but you're from sioux falls? i'm from orange city, ia. if i end up doin it, you might have to listen to it.
Old 01-01-2011, 07:01 PM   #6
sorrowfulkiller
Member#: 170439
I <3 Lamp
Sure, I'm also one of the owners of fastflat4.com we're planning on coming down to Iowa this summer for a couple things so I'm sure I'll see you around sometime
Old 01-01-2011, 07:56 PM   #7
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
great to know! i took a look at the website and noticed you are partners with speed techniques, thats where i had my car tuned. if you happen to be available May 19-21, it would be awesome if you and some other subie owners could show up for the car show, theres never any imports there. i'll talk to jared and dan about it as well. ps, i bought my car at sioux falls subaru through dan, showed up at speed techniques and thought he was stalking me, hahaha
Old 01-02-2011, 10:26 PM   #8
sorrowfulkiller
Member#: 170439
I <3 Lamp
Sound like a good plan to me, and yeah ha ha that's how it is up here. You see anyone with a subie and more than likely they have close ties with the people that either sell or tune them. PM me and I'll talk to my partner and see if we'll be able to make it.
Old 01-14-2011, 06:56 PM   #9
xDRAN0x
Member#: 163085
2009 3.0R Legacy
'15 FXT
I was thinking of putting this on my 07 WRX, not sure I want to deal with the possibility of cops hanging out in front of my tailpipe
http://www.quicktimeperformance.com/QTEC/index.php
xDRAN0x is offline   Reply With Quote
Old 01-15-2011, 05:55 AM   #10
Kfly04
Member#: 252005
2004 STI
Java Black
wouldn't a butterfly valve sound like a external wastegate when it functions? Loud!?
Kfly04 is offline   Reply With Quote
Old 01-15-2011, 08:42 AM   #11
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
well, it would just change where the exhaust is flowing, instead of flowing through the cat and muffler, it would go straight-pipe at the flip of a switch, so yes, it would be very loud
Old 01-15-2011, 06:22 PM   #12
mxracer88
Member#: 265839
A friend of mine build an exhaust for my evo with somewhat the same concept, but still passes through the muffler. When you are off the turbo and just cruising the butterfly valve is closed, but as soon stomp on the throttle and want to go it diverts the gas follow through the 3" pipe passing the cat.
mxracer88 is offline   Reply With Quote
Old 01-15-2011, 06:49 PM   #13
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
So you had it hooked up to the tps sensor? I personally wouldn't do that because it would be a bitch to try to tune that, id just go with a toggle switch, but that's just me. Looks good though!
Old 01-15-2011, 11:41 PM   #14
P4radigm
Member#: 267134
2011 STI Sedan
Spark Silver
Your friend has some awesome welding and fab skills.
P4radigm is offline   Reply With Quote
Old 01-26-2011, 01:23 PM   #15
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
This part made me laugh. A straight pipe is not street legal in any way shape or form. You will probably meet emissions and exhaust db restrictions while closed but any modifications before a cat is technically illegal, hence the 'off-road use only' disclaimer on downpipes and exhaust manifolds.
When you open it up your car will sound like any other catless subie with similar mods.
Not trying to discourage you but this is misleading info that might get someone else in trouble if they cite NASIOC to authorities
imma_stocker is offline   Reply With Quote
Old 01-26-2011, 01:31 PM   #16
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
well yeah, i know that catless is illegal, but i was wondering if the bypass itself would be illegal if you said it was used as a track day car and i would hook it up to a manual switch rather than the tps sensor
Old 01-27-2011, 03:41 PM   #17
mxracer88
Member#: 265839
No the TPS sensor is not hooked up to the exhaust. The butterfly valves open and closes by a spring. When you are out of the turbo there isnt enough pressure with in the exhaust system to direct the flow through straight pipe, when you you throttle on the spring is compressed allowing the exhaust fumes through the straight pipe.
Old 01-27-2011, 05:42 PM   #18
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
ahhh, i see
Old 01-27-2011, 05:47 PM   #19
mikeydrives1
Member#: 262117
2001 Forester
STi II type M
I have a friend i used to work with who has an electric cutout just after his DP on a 2003 WRX. It sounds pretty nasty when he opens it ( has stock axleback system on)
mikeydrives1 is offline   Reply With Quote
Old 01-27-2011, 05:59 PM   #20
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
nasty as in good nasty or bad nasty?
FS : TurboXS Front Mount IC KIT for 06 - 07 WRX STI sean18337 Engine/Power/Exhaust 33 09-06-2011 10:54 PM
Stock wrx muffler/cat back riderd247 Private 'Wanted' Classifieds 0 05-19-2010 09:03 PM
Other mufflers/cat backs with TurboXS DP roybfr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-13-2003 12:41 AM
H-6 3.0 Muffler Bypass mikeberg Normally Aspirated Powertrain 3 11-18-2002 02:06 PM
cat bypass piping/ 4into 1 header [email protected] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-21-2001 03:02 PM
