Old 07-07-2002, 01:20 AM   #1
Ryan23
Member#: 15116
2000 Ver6 STi Type-R
EJ257/GT35R
Default TurboXs Unichip harness without unichip?
Will this work? I am taking out my unichip tomorrow for troubleshooting purposes and would like to keep the harness in place for the voltage "clamps" (I'm assuming this is done at the harness). I have a terminated connector from Vishnu to bypass his chip, will this work if the above won't by itself? Thanks in advance!
Ryan
Ryan23 is offline   Reply With Quote
Old 07-07-2002, 01:38 AM   #2
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
That is a big nope. I asked this question to Phil a while back and he said if the unichip is removed the factory harness needs to be plugged back into the ECU. When I have had remaps done, I leave the harness in place and just up plug it from the ECU and plug the factory harness back into the ECU.
Troy
roybfr is offline   Reply With Quote
TurboXS Unichip Harness TPS Threshold Mod Rocky WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 149 11-14-2002 11:35 PM
FS: TurboXS Unichip, harness, ABC and hardware Rich10 Tri-State Area Forum 6 11-14-2002 11:14 AM
adjusting revision 4 turboxs unichip harness ezatnova Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 09-09-2002 11:46 PM
TurboXS Unichip Harness TPS threshold Mod Dave_MacKinnon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-07-2002 04:22 PM
turboxs stage 2 without the txs unichip? imprezive one Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-27-2002 12:12 PM
