Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 12-31-2010, 07:13 PM   #1
ohemgeeitsNiko
Member#: 239620
2003 WRX Wagon
Default DDM Tuning HID kit, need some extra HID parts, anything local?
So I ordered a new HID kit for my JDM projectors since i lost one bulb and ballast. I didn't realize that all i had ordered from DDM tuning was the D2S bulb itself and the ballast, none of the wires in between. are there any stores local that would have some accessories that could help?
thanks guys,
- Nick
ohemgeeitsNiko is offline   Reply With Quote
Old 01-01-2011, 09:47 AM   #2
AZP Installs
Member#: 40160
The DDM Tuning kits are plug and play. You should be able to go:
OEM Wiring -> DDM Tuning Bulb connection 1 -> Ballast -> DDM Tuning Bulb Connection 2
The only other wiring available would be if you wanted to have the current drawn directly from the battery, then they offer a relay harness.
-mike
AZP Installs is offline   Reply With Quote
Old 01-03-2011, 12:49 PM   #3
ohemgeeitsNiko
Member#: 239620
2003 WRX Wagon
incorrect. the Apexcone Raptor V2 HID kit includes what is below. They have extra "optional" accessories. This kit has the ballast and ignitor in one unit.
Old 01-03-2011, 01:10 PM   #4
Jive Turkey
Member#: 219492
YOU are incorrect. i have ordered 3 kits from ddm and about to order my 4th and none of them looked like what you have since you are missing the wiring from the bulb. i would give them a call and ask for a new bulb because you can't do anything with this current set up.
you can see here what comes with the kit and as you can see you are missing wiring, and mike is correct the only other thing you can get is the wiring for a straight draw from the battery. http://www.ddmtuning.com/Products/Ap...Raptor-HID-Kit
Jive Turkey is offline   Reply With Quote
Old 01-03-2011, 01:49 PM   #5
AZP Installs
Member#: 40160
I think the raptor kit is for motorcycles or ATVs. That kit may be correct the way it is but I have no idea how to hook it up. Most of their kits and all the ones sold for car-replacements come with the wiring built into the bulb itself.
-mike
Old 01-03-2011, 01:54 PM   #6
AZP Installs
Member#: 40160
Reading on their site, I'm not sure what the raptor kits are for. They do look similar to the old style ballasts that were common from Hella.
As for the wiring, as I said, I've never seen an HID bulb without the wiring hard-wired into it.
-mike
Old 01-03-2011, 04:16 PM   #7
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
Go check your OEM wiring... what you are missing should be in your headlight housing. You will have to replace bulb, and there should be a positive and ground on the bulb. Use that for your new setup if all the voltages match up.
This is why I love Caesar from Lightwerkz... he knows his shiz and honors lifetime warranties! I had a bulb go out after 2 yrs and he got me two new bulbs and 1 new ballast at no charge.
You may have to rig up a positive to ground or female to spade if the connections don't match... go with 16 or 18G wire
I think I have a splice kit with some extra hardware if you really can't figure something out.
GL!!
JavaBot is offline   Reply With Quote
Old 01-03-2011, 07:40 PM   #8
Paisan
Tri-State Track Instructor
Member#: 197
'14 Touareg TDI '14
BRZ http://48hrs.info
The part he is missing though is from the OEM car-side connector to the Ballast and the ballast to the HID bulb. The connectors on the end of the Ballast in the picture (black and red wires) should have their counterpart connectors hard wired into the HID bulb in the picture. There should also be a connector that goes into the recepticle on the Ballast which gets power from the oem wiring harness.
-mike
Paisan is offline   Reply With Quote
Old 01-03-2011, 07:53 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
He is trying to put D2S bulbs into non-HID JDM's, can't be done.
The ballast shown has a connector for an aftermarket rebased bulb and will not work with a D2S bulb anyway. There is no adapter to make it work and it's dangerous to try screwing around with the bulb side of HIDs due to the extremely high voltage present.
Old 01-03-2011, 08:21 PM   #10
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
I see what you're saying. I had mismatching spade connectors so I had to do a little extra re-wiring when I got my second round of warrantied bulbs back.
Old 01-03-2011, 08:22 PM   #11
FkVtech
Member#: 198968
2008 WRX
RIP Soccerkid52688
Don't be a smart ass to people who are trying to help you, ****head. That won't get you very far here.
FkVtech is offline   Reply With Quote
Old 01-03-2011, 08:23 PM   #12
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
D2S are for reflector housings, not projector, correct?
WTB: HID Kit,STI seats,LOTS OF PARTS ND will trade for ALASKA AIR ROUND TRIP TICKETS ImprezaRS05 NWIC Private Classifieds 9 10-04-2010 10:55 AM
got some extra audio parts kickin around... IllNastyImpreza NESIC Private Classifieds 2 09-11-2008 10:43 AM
WTB: HID Kit,STI seats,LOTS OF PARTS ND will trade for ALASKA AIR ROUND TRIP TICKETS ImprezaRS05 Private 'Wanted' Classifieds 4 07-20-2006 02:03 PM
STi for MY00 Legacy, need some extra parts. Solomon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-22-2003 01:13 AM
