Old 12-31-2010, 08:10 PM   #1
flightwatch
Member#: 231058
2013 Genesis Coupe
Default valve lash question.
As some of you know, I recently installed cams...and, of course, relashed the valves. We set the lash to .008 intake and .010 exhaust. The problem is that I have quite a bit of valvetrain noise and more importantly, valve tap. The car runs great. Smooth idle, smooth acceleration/deceleration, no misfires...just noise. I don't think there is a loss in power, but I can't really say yes or no to that since it has been this way since we installed the cams. I know that factory specs say to set the lash at .007/.009, but I can't believe 1/1000th of an inch could make that much difference in noise factor.
My question is: Is it normal for a cammed car to have excessive valvetrain noise? The valves need to be relashed anyways, but I don't want to damage my car and the 1,000mi mark is still a ways off. Should I have them relashed sooner than that? I just don't want to hurt my car.
Thanks in advance.
flightwatch is offline   Reply With Quote
Old 12-31-2010, 11:43 PM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
A thousandth of valve lash is a BIG change.
Cams with more lift that stock will be noisier because they have to seat the valve more abruptly. A little noise is ok, a lot of noise is too loose.
I'd relash a thousandth tighter at a time until you have a CEL or drivability problems, then back off a thousandth. For instance, my car runs like a top at 8 and 10 but won't idle and throws misfire codes at 7 and 9.
Old 01-01-2011, 01:20 PM   #3
flightwatch
Member#: 231058
2013 Genesis Coupe
Thanks Ty, I'll try that out. Should I do it sooner than later, or am I ok with waiting another 500mi?
Old 01-01-2011, 01:32 PM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Loose is generally safe. Too tight can burn up the valves.
Quick Hybrid Valve Lash Question STI_KLR Built Motor Discussion 2 04-17-2009 12:12 PM
Stage 3 cam valve lash question Twiztidunreal Built Motor Discussion 2 02-25-2009 02:22 PM
valve lash question nkx Normally Aspirated Powertrain 10 08-04-2008 08:18 PM
Valve lash question. LiquidForce Built Motor Discussion 5 07-30-2007 07:58 PM
Valve lash questions Acostafan Built Motor Discussion 12 07-01-2007 01:16 PM
