Old 01-01-2011, 04:28 PM   #1
Dknits782
Member#: 153302
Default hood scoop?
Hey I have an 07 2.5i had someone egg and rock it the other night now I need to bondo and paint it thinking about doing a custom hood scoop while I have it all sanded. I have read a couple post on it seems pretty easy but thought I would see what u guys thought and any input u might have.
Dknits782 is offline   Reply With Quote
Old 01-01-2011, 04:40 PM   #2
chazly413
Member#: 151079
2005 2.5RS RBP
s-techs mad tyte yo
Probably better off asking this in Interior & Exterior Modification.
chazly413 is offline   Reply With Quote
Old 01-01-2011, 04:43 PM   #3
Wrencher86
Member#: 250463
2010 Impreza 2.5i
N/A's with hood scoops= really, really lame.
IMHO.
Wrencher86 is offline   Reply With Quote
Old 01-02-2011, 10:31 PM   #4
Audi20Tdriver
Member#: 206040
2009 Audi A4 2.0T
APR Stage 1
honestly you are better off just throwing a wrx hood on there then fabricating yours. not sure on the 07 but I did that on my 05.. the hood was much lighter, alum. vs steel
Audi20Tdriver is offline   Reply With Quote
Old 01-02-2011, 10:40 PM   #5
chazly413
Member#: 151079
2005 2.5RS RBP
s-techs mad tyte yo
^ This would be the best option. AFAIK, 06+ hoods are aluminum, too.
Old 01-02-2011, 10:47 PM   #6
watchdoc
Member#: 104821
2002 2.5 RS
IMHO.
Actually, i would disagree. The bugeye RS hood is steel while the WRX hood is aluminum. It's a huge weights savings off the front end of the car where is makes the most difference.
watchdoc is online now   Reply With Quote
Old 01-02-2011, 11:25 PM   #7
Wrencher86
Member#: 250463
2010 Impreza 2.5i
I can appreciate the weight savings. It's just that non-functioning hood scoops are a pet peeve of mine. Like excessive chrome or performance stickers for mods the car doesn't have.
Again, just my personal taste.
Old 01-03-2011, 12:24 AM   #8
royalnewjersey
Member#: 250954
2013 WRX Hatch
WRB - On Order
Yeah it's totally a personal thing. I really like the hood scoop sticking up into view a bit while driving. Seems stupid I know, but it really improves the bland look of the stock Impreza hood. More-so on the 2008+.
Most people think it's "ricer" or whatever, but who cares. If you like it, do it.
Anybody know if the newer Impreza / WRX hoods are steel vs aluminum like they were on the older models?
royalnewjersey is offline   Reply With Quote
Old 01-03-2011, 12:43 AM   #9
chazly413
Member#: 151079
2005 2.5RS RBP
s-techs mad tyte yo
The easiest way to tell is if your hood is light as ****. My hood is steel and it's so heavy compared to aluminum hoods.
Also, aluminum is not magnetic.
Old 01-03-2011, 08:31 AM   #10
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
If it's any concern, a hood swap will put you straight into SM in autocross.
LetItSnow is offline   Reply With Quote
Old 01-03-2011, 01:14 PM   #11
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
I have a wrx hood for weight savings but the 2 times that i have tracked my car since then i have ran a hot. I think the extra air coming in is limiting the air that comes in through the radiator so it looks like i will be replacing it for a scoop less carbon fiber one now even thought I'm not a fan of carbon fiber. The hood did save 21 lbs over my stock one but if i have to have cool down laps every 10 to 15 mins, it's not worth it. In mid 06 aluminum price almost doubled so they went back to steel for a bit then back to aluminum part way through 07 I'm not sure on the dates. I say dont' do a scoop, it's not worth it unless you need it.
aclver1 is offline   Reply With Quote
Old 01-03-2011, 08:22 PM   #12
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
^This is correct. I have an 06 and I was poking around under the hood one day using a magnetic flashlight and it wouldn't stick to a damn thing other than the hood propping rod.
Rudgers73 is offline   Reply With Quote
Old 01-04-2011, 12:55 AM   #13
Audi20Tdriver
Member#: 206040
2009 Audi A4 2.0T
APR Stage 1
the WRX hood helped keep my in hood temps down in the hot phoenix summers. but for DD not for tracking. Two things you could have done for tracking.. 1) turn the scoop around.. 2) pick up a reverse hood scoop. if you do a WRX hood with a reverse hood scoop.. they sold them everywhere for the 05 year.. im sure for 06-07 too.. that is 100% functional and will keep you very cool. thats what they use on the EVO with the front mount. turning the wrx scoop around is a ghetto but functional way of doing that too. I have seen ESX STi's run like that at the track. I did it on a road trip too and could see the heat pouring out the whole time.
if you did a reverse scoop no one can say rice at all.
Old 01-04-2011, 07:38 PM   #14
Wrencher86
Member#: 250463
2010 Impreza 2.5i
They could say "Poser cowl". If they wanted to be jerks.
Sounds like a good solution, though.
Old 01-05-2011, 01:12 AM   #15
Audi20Tdriver
Member#: 206040
2009 Audi A4 2.0T
APR Stage 1
nothing poser about fully functional heat ventilation while cutting weight.
does oem 02-03 wrx hood scoop fit on a cf hood w/ 04-05 scoop soobieajax325 Interior & Exterior Modification 1 08-02-2005 11:22 PM
WTT:2004 silver STi hood scoop for a 2004 silver WRX hood scoop Hummer Private 'Wanted' Classifieds 4 07-26-2005 12:15 AM
Wtt Wrx Hood Scoop 4 Sti Hood Scoop gingertooth Private 'Wanted' Classifieds 0 07-25-2005 07:54 AM
STI Hood Scoop vs. WRX Hood Scoop Extra300 Factory 2.0L Turbo Powertrain 8 01-02-2005 09:42 AM
WTT: WR Blue 04 hood scoop for 04 STI hood scoop ;) dannygo Private 'Wanted' Classifieds 0 01-21-2004 05:15 PM
Message Board Statistics All times are GMT -4. The time now is 02:20 PM.
