Old 01-02-2011, 12:06 AM   #1
minhha2006
Member#: 154914
2005 WRX
UGM
Unhappy Uh Oh
I just noticed that I have a wierd noise coming from my engine bay. I am unsure what it is though.
It is a light knocking/tapping noise at idle. When I start driving it, first gear has a lot of the noise, especially around 3k rpms. The rest of the gears make the noise too, once again near the 3k rpm range. Here is the strange part, the noise only comes when I accellerate, if my foot stays on the gas, but not giving it any additional gas, the noise is not there (as far as I can tell from within the car)
Any suggestions? I have a 98 impreza so is it even worth fixing? I may have seen my oil light come on, but I am not positive. Could that have anything to do with this issue?
minhha2006 is offline   Reply With Quote
Old 01-02-2011, 12:37 AM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Drain oil, inspect in bright light. Copper shavings are bad mojo. How is the oil level?
On the other hand, it could be crappy gas that's pre-igniting. Start her up, hold a long screwdriver to your ear, and try to pinpoint the noise. Could be a myriad of things. Get a recording - post it. It's unpossible to diagnose such things through text alone.
I had a bearing die on me in a similar fashion, it would only make noise at certain RPM and light throttle....in the beginning.
Old 01-02-2011, 12:19 PM   #3
un4tun8
Member#: 268823
2005 impreza 2.5rs
black
Just to clarify, put the handle against your ear not the sharp end. Put the metal end at various points on the motor, obviously non moving parts.
un4tun8 is offline   Reply With Quote
Old 01-02-2011, 08:48 PM   #4
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
You better check your timing set. Could be an idler with a bad bearing. Put your long screwdriver on the timing cover, heads, and oil pan. The noise will be obviously louder in one of these places. You could also do what I did and buy a cheap automotive stethoscope.
Good Luck
geronimo81 is offline   Reply With Quote
Old 01-02-2011, 09:59 PM   #5
jeisen
Member#: 27258
who dat be dat was?
bang on the heatshields for the exhaust to see if they are loose. I recently had to cut most of them off my L.
jeisen is offline   Reply With Quote
Old 01-02-2011, 10:26 PM   #6
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Sound clips?
sense of nature is offline   Reply With Quote
Old 01-02-2011, 10:42 PM   #7
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
sorry you have thrown a rod bearing, I have heard the sound not so long ago
note the clacking sound after going through finish
http://forums.nasioc.com/forums/newr...e=1&p=32894127
dstan is offline   Reply With Quote
Old 01-02-2011, 10:49 PM   #8
minhha2006
Member#: 154914
2005 WRX
UGM
I will get clips as soon as possible. Sorry for the delay.
Old 01-02-2011, 10:50 PM   #9
minhha2006
Member#: 154914
2005 WRX
UGM
Link doesn't work! Oh man...would it be smarter to invest in another car at this point?
Old 01-03-2011, 01:44 PM   #10
JerseyDubbin
Member#: 260054
2004 AW WRX Wagon
VF43, Opensource Tune
Hard to say, depends on what the cause is. A hairline crack between cylinder walls, leaky head gasket, etc. I had the same issue with another car and I did decide it would be cheaper to just incest in a new car. Turned out for the best as there was a crack in the cylinder wall.
Sorry
JerseyDubbin is offline   Reply With Quote
Old 01-04-2011, 06:59 AM   #11
BUTTWARTOUCH
Member#: 243629
2007 STI
Rally blue/Black
is it a 2 door or 4 door?
BUTTWARTOUCH is offline   Reply With Quote
Old 01-04-2011, 11:12 AM   #12
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
What does that have to do with an engine noise?
Anyways it might just be a bit of piston slap or valve lifter noise, which is pretty common for a Subaru with some miles on it. I've had that noise for years now. Just had the entire engine apart for head gaskets and everything internally is mechanically sound. 192k miles on the engine so far and except for it being a bit noiseier it runs like new.
Samirr76 is offline   Reply With Quote
Old 01-04-2011, 04:58 PM   #13
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
OP, try adjusting the valve lash on your car, it's easy to do, and could help.
Oh yeah, and it's free.
I'm pretty sure your 2.2 is phase II, so all you'd need is some sockets, feeler gauges, a screwdriver, and some time.
T Wrex--OH is offline   Reply With Quote
('93-'01) New Model RS Update: Uh oh... Kostamojen Impreza Forum 20 04-27-2001 11:47 PM
Uh oh.. it's tax time. CosmoTheCat North West Impreza Club Forum -- NWIC 12 03-01-2001 08:51 AM
Saturday BAM - Uh oh, SpeedRing full? bluesaint Bay Area Impreza Club Forum -- BAIC 4 01-25-2001 03:21 PM
Uh Oh! Party Lights! Reflex-Arc North West Impreza Club Forum -- NWIC 1 07-03-2000 09:39 AM
uh-oh ... selling my RS? (Black 99 5-spd) Greg I North West Impreza Club Forum -- NWIC 7 03-01-2000 12:35 AM
