Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum > Eastern Canada
Old 01-02-2011, 11:40 AM   #1
satelliteguy
Member#: 184469
2004 WRX
Default best COBB map for Emissions test, ontario canada
Hey,
I have 2004 wrx with catless up and down, and catback, sti pinks, vf39, no flaps on tgv and short ram intake tuned with the cobb AP.
Have to take it for emissions test, just wondering if there is a better tune to use opposed to the regular one?
I will be putting the factory catted down pipe back on for the etest.
I am located in Ontario, canada
(location included, sorry unabomber)
satelliteguy is offline   Reply With Quote
Old 01-02-2011, 02:36 PM   #2
sstaurus
Member#: 251895
2005 Forester XT 5MT
For what it's worth, I posted in the Ontario forum somewhere, and a guy there passed the sniffer here with just a single high-flow cat. Just make sure you give it a nice 20 min drive before you take it and they test it right away... I think the limits are fairly lax. Good luck.
I'm curious what others say as I just got myself an AP (haven't even installed it yet).
sstaurus is offline   Reply With Quote
Old 01-02-2011, 06:48 PM   #3
satelliteguy
Member#: 184469
2004 WRX
yeah hopefully the 2 factory cats cut it
they only have 35k miles on them
Old 01-02-2011, 07:05 PM   #4
arghx7
Member#: 232940
If you have both factory cats you'll be fine as long as the front O2 sensor is good and you don't have other mechanical problems (low compression, vacuum leak, whatever). Cobb vs stock won't matter much because they are both going to be running in closed loop. With a single high flow cat is that you have to be more concerned about keeping the cat warmed up. The stock two cat system works better at lower exhaust temperatures.
arghx7 is offline   Reply With Quote
Old 01-02-2011, 07:47 PM   #5
satelliteguy
Member#: 184469
2004 WRX
yeah engine is in pretty good shape, so i doubt anything mechanical.
i have no idea about the 02 sensor though.
what would be the symptoms of a failing one?
Old 01-03-2011, 11:08 AM   #6
arghx7
Member#: 232940
well it would throw a code...
Old 01-03-2011, 04:57 PM   #7
satelliteguy
Member#: 184469
2004 WRX
I thought so, I have no active or inactive dtcs so it should be good.
Also Ill post results after I get the test done, in case anyone else requires this info.
Old 01-06-2011, 06:06 PM   #8
satelliteguy
Member#: 184469
2004 WRX
ETEST results.
***********LIMIT*******2500rpm******* IDLE
HC PPM--------150-----------11------------------22
CO%-----------.70-----------.00-----------------.00
NO PPM-------NA------------NA------------------NA
DILUTION--------------------15.0---------------11.6
Old 07-21-2011, 11:17 AM   #9
SEBBARU
Member#: 71774
2005 WRX STi
Platinum Silver
So, in reality our cars comply with Ontario's emission standards without Catalytic Converters!! Wow...
The dilution number worries me a bit. My car is stock. I'll have to compare my last test results to yours to see how much of a difference the Converters really make.
Thanks for posting the details.
SEBBARU is offline   Reply With Quote
Which do you think is best for emissions test? shemoves Service & Maintenance 6 01-17-2008 09:48 AM
Census - emissions-testing across Canada Migo Canada Region Forum 20 04-06-2007 09:28 AM
COBB AccessPORT and emission testing keita Engine Management & Tuning 4 09-29-2005 12:40 PM
Cobb Anti-theft map for compression test? 03WREX Engine Management & Tuning 2 08-11-2005 04:46 PM
Does Mass use OBDII port for emissions test? fastburro New England Impreza Club Forum -- NESIC 7 09-10-2002 06:09 PM
Message Board Statistics All times are GMT -4. The time now is 09:16 PM.
