Old 06-13-2011, 08:53 PM   #1
TheLordChesterfield
Member#: 234539
Default 06 WRX - Driver side oil feed leak? Cam position sensor?
I'm finishing up a swap with what was supposed to be a 06 wrx engine, trying to get it to run. I have ALMOST everything nailed down but now I'm really confused.
First, what is this? (red cap, top right, metal block, driver head) \/
I'm referring to the metal block towards the front of the driver side head...
It has an oil feed line that comes from the front of the head.
I have a blue connector that is hanging out, not connected to anything and I foolishly thought this block was the spot for the cam position sensor, but now I'm pretty positive they are located towards the back of the heads.
I thought everything was good to go - I have spark, fuel pump was on, continuity to the injectors, and the oil pump was on AND OIL was seeping out of the back of this metal block from (what I thought was) a sensor sized hole.
The connector looks like this:
This is from a 08 STI and my wires are YB and LB (yellow/black and blue/black).
I'm looking through diagrams for what it could be - but all three have no connectors that are specifically blue....
Any ideas??? I'm ready to freak out - after all of the wiring work this should be the least of my worries!
Last edited by TheLordChesterfield; 06-13-2011 at 08:56 PM. Reason: Tried to line up arrow
TheLordChesterfield is offline   Reply With Quote
Old 06-19-2011, 08:28 PM   #2
TheLordChesterfield
Member#: 234539
As usual, no one on this site was helpful in the slightest.
For anyone who has this question in the future - it is the AVCS solenoid aka "Oil control valve" used to monitor pressure and allow activation of variable valve timing.
Decent help is hard to find - especially on this forum
Old 08-09-2011, 01:54 AM   #3
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
Might be too late to answer, but it is your AVCS sensor.
gabedude is offline   Reply With Quote
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor, ex mani jakesurfin Engine/Power/Exhaust 9 06-15-2009 02:28 PM
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor jakesurfin TXIC Private Classifieds 4 06-15-2009 02:28 PM
WTB: 06 WRX front driver side axle ohxietviet TXIC Private Classifieds 3 12-28-2007 04:24 PM
WTB: 06 wrx/sti driver side fender, Crystal Gray Metallic DarkDvr SCIC Private Classifieds 0 04-13-2007 04:29 PM
WRX vs. 2.5L STi crank and cam position sensors - the same? Red Rocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-24-2003 10:35 AM
