Old 07-07-2002, 11:59 AM   #1
rotary
Member#: 21014
Default Pipe interchange?
Last I knew you could use the legacy pipes as longa s you had the crossmember to. What about the wrx pipes? Has anyone tried? What about crossmember use?
Lastly this is for a 2.5
rotary is offline   Reply With Quote
Old 07-07-2002, 12:48 PM   #2
TaiChih
Member#: 3467
1998 Dinan3
Bleck
the legacy crossmember can be used with the WRX uppipe. You can get the crossmember from Sugar
TaiChih is offline   Reply With Quote
Old 07-07-2002, 01:43 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I'm not sure if this has been addressed, but everyone knows that the Legacy turbos over here were SOHC, right? So does that crossmember and header just drop right in, or do you need spacers like I've heard a few places before?
Old 07-07-2002, 02:00 PM   #4
TaiChih
Member#: 3467
1998 Dinan3
Bleck
actually, now I'm confused. What pipes are you talking about? a complete swap? partial?uppipe downpipe?exhaust? Are you worried about fitment?
Old 07-07-2002, 02:03 PM   #5
rotary
Member#: 21014
All pipes really. The two manifolds the cross pipe that connects em uh the intake pipe....wheres the fiche when i need it. Anyone wanna list out the proper names of all needed?
Old 07-07-2002, 02:04 PM   #6
rotary
Member#: 21014
I searched that username with no luck. Do you ahve a link? Does she buy junkyard pieces and mark them up?
Old 07-07-2002, 02:10 PM   #7
TaiChih
Member#: 3467
1998 Dinan3
Bleck
sorry, Lisa is her name. She's a vendor. Look under Troncalli Subaru
Old 07-07-2002, 02:13 PM   #8
TaiChih
Member#: 3467
1998 Dinan3
Bleck
ok, there is the uppipe, downpipe, intake piping, Header(depends on what kind you get, but there is the RS one piece and WRX three piece cast iron) midpipe, and rear muffler section. Please explain and be more specific as what you want to do and then I may be able to help you out with fitment issues.i.e. use a legacy turbo on an RS motor, or swap the entire motor, etc.
Old 07-07-2002, 02:16 PM   #9
rotary
Member#: 21014
I am gonna use the turbo and pipes from a legacy to a 2.5 impreza. I am trying to build full list of parts I will need as this is my daily driver and want to do it over the weekend or so I hope
Old 07-07-2002, 02:22 PM   #10
rotary
Member#: 21014
Also any examples on MAf cars? Any links of buildups? I figure the older legacy turbos are MAFs? Just starting the research so for the basic questions
Interchangeable parts? 04-07/08-10 WRX mista jc Newbies & FAQs 7 08-23-2010 12:29 AM
down pipe and mid pipes mikEimpreza07 MWSOC Private Classifieds 7 06-02-2010 09:38 PM
down pipe and mid pipes IL mikEimpreza07 Engine/Power/Exhaust 5 06-02-2010 09:34 PM
What bolts/Nuts for Up pipe? subaru_steve Newbies & FAQs 0 06-01-2010 11:17 AM
Are turbo inlet pipe interchangeable between 02-05 WRX/STI? gopsu Newbies & FAQs 2 07-10-2006 12:01 AM
