Old 01-03-2011, 08:27 PM   #1
SubyDoinWork
Member#: 236325
Exclamation 2008 Impreza Sticky Throttle
My Mom just got a very standard 2008 Impreza Sedan with 5 speed Manual and 20k miles on it.
I noticed when I drive the car that the throttle seems to stick for roughly 2 seconds after I let off the gas pedal completely weather its in gear or not.
So when I go to shift into the next gear, the RPMs will be hanging and I know its just eating up the clutch disc when I engage it back.
Sometimes with the clutch disengaged and me just coasting, it will idle up to about 2000 RPM!!!
I know for a fact this is not right and I'm an 80s Toyota guy so I'm looking for expert advice on this matter.
She thinks I'm crazy and wont take it in to the Dealer.
Thanks in advance.
SubyDoinWork is offline   Reply With Quote
Old 01-04-2011, 11:00 PM   #2
SubyDoinWork
Member#: 236325
No replies yet? Abnormal compared to the other forums I frequent.
Old 01-04-2011, 11:05 PM   #3
Wrencher86
Member#: 250463
2010 Impreza 2.5i
The flare in between shifting is normal. They keep the throttle open for emissions reasons. It's annoying but you get used to it. Not sure about the 2k while costing. Does it just stay at 2k RPM? Or does it go down to a normal idle then back up?
Wrencher86 is offline   Reply With Quote
Old 01-04-2011, 11:09 PM   #4
SubyDoinWork
Member#: 236325
It did it a few times only. Perhaps my foot was touching the throttle slightly.
What a stupid design IMO.
It's a good way for them to make money on replacing clutches on the otherhand.
I know I'll never own one for that reason.
Old 01-04-2011, 11:36 PM   #5
Wagonguy98
Member#: 183763
2009 WRX
SSM
I believe there's an ecu reflash/patch for that.
Wagonguy98 is offline   Reply With Quote
Old 01-04-2011, 11:37 PM   #6
Wrencher86
Member#: 250463
2010 Impreza 2.5i
It's a good way for them to keep the converter working the way it needs to so they meet emissions. If you are driving normally just slow down the shift by a half second, let out the clutch a little faster and it will be fine. If you're driving aggressively then it doesn't matter. The clutch would be engaging at a higher RPM anyway.
Old 01-04-2011, 11:40 PM   #7
SubyDoinWork
Member#: 236325
I'll give the dealer a call and see.
Idle revs throttling on 2008 Impreza richardchoi Newbies & FAQs 12 05-27-2011 12:21 PM
Sticky Throttle/Throttle Body Cleaning - Warrenty? 85258 Normally Aspirated Powertrain 7 10-17-2003 08:45 AM
Sticky throttle? Chi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-24-2003 11:21 AM
Sticky throttle cable? BYBYV8 Service & Maintenance 3 03-13-2002 01:00 PM
