Old 07-07-2002, 05:22 PM   #1
25GTGuy
Member#: 15085
1998 2.5 Legacy GT
Silver Bling
Question Engine kill
Hopefully someone can help me out. When I decide to whip my car around real fast(Like, more than 180 degrees), why does the enginge kill, or almost kill? Is there anyway to disable this? I, for one, can't stand this.
Kareen
25GTGuy is offline   Reply With Quote
Old 07-07-2002, 05:45 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
You need more gas.......
Id be willing to bet that you are low enough on gas that when you corner hard like this the pump goes dry for a second. Ive pushed my legacy pretty hard and that is the only time it does it.
One time I came out of a dirt road sideways onto pavement so fast that if I didnt have worn tires I probably would have gone up on two wheels, and with a tank just over full I had no problems.
Old 07-07-2002, 06:04 PM   #3
Jarvis
Member#: 8267
2010 MB E63
Black on Silver
Note to self: Steer clear of California and Alaska.
Jim
Jarvis is offline   Reply With Quote
Old 07-07-2002, 06:05 PM   #4
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
I experianced the same thing at my last auto-x. It was the last run so I decided to go all out. I also tried left foot braking for the first time. Well I got through the saloms and into the first big sweeping left. Well I pushed the clutch in instead of the brake . As soon as the AWD was was gone I went spinning. I did a huge 360 and took out about 6 cones. The whole time I had the clutch in. Well the car died and I was scared for a second. But she turned over with no problems. I finished the course with 3 cones crammed under my car. I always have very little fuel at meets so it must be the fuel pump running dry. Like ciper said.
HIHO is offline   Reply With Quote
Old 07-08-2002, 09:11 AM   #5
2002 GT LTD
Member#: 19144
2002 Legacy GT Sedan
Titanium
There is a fuel shutoff switch located (usually in the trunk) that senses when the vehicle is going to be flipped over so that it can cut off fuel to the vehicle in case of a rollover.
I beleive it is a mercury metronome type switch.
So if you do go too fast into a corner and the g forces pull the lever too far you will loose fuel to the engine.
I always thought that they trip and had to be reset manually by pushing a button, maybe you should talk to a service Tech about that though.
Or, of course, you could be low on fuel, but I would tend to think that if it was a short time without fuel in the fuel sender you would still have to use up what is in the line and that you probably would not feel it as soon as you hit the corner and more if you have been cornering for a while.
2 c.
2002 GT LTD is offline   Reply With Quote
utec engine-kill map yeager Engine Management & Tuning 11 11-01-2004 04:26 PM
Wiring TT and keeping engine kill feature sssp Electrical & Lighting 2 08-15-2004 11:58 PM
DaimlerChrysler test engineer kills 2 in Germany Sephro Off-Topic 24 11-04-2003 04:35 AM
warming engine kills torque pulling away scott baxter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-21-2003 11:17 PM
hidden engine kill switch? pull a fuse? Sideways Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-19-2002 04:16 AM
