Old 07-07-2002, 05:46 PM   #1
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Question Piston Oil Squirter Install Instructions?
Okay after a few hours of searching the net and this forum i am officially empty handed...was wondering if ANYONE had the plans for installing the oil squirters???
Thanks in advance.
jeremy
Old 07-07-2002, 09:19 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I've got a few pics of decks with squirters in the rails, but no idea whether they are phase I/II, where exactly they are, or what size holes are drilled.
Old 07-08-2002, 02:09 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
thank's nick...someone HAS to know?? happy where are you when i need you??
jeremy
Old 07-08-2002, 09:00 AM   #4
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Well... I know my EJ22 Turbo engine is equipped with them. I have yet to start the tear down process to replace a bunch of gaskets and check a few things, but if you want I can try and take some pictures of the set-up or you can drive out here and take a gander at it.
Thanks - Jon
omahasubaru is offline   Reply With Quote
Old 07-08-2002, 01:44 PM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Thanks - Jon
thanks for the offer jon...according to another sourse it looks as if only Phasr 1 engines are compatible with the oil squirters, but we'll have to wait and see.
Jeremy
Old 07-10-2002, 07:08 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I believe Phase I had the locations for them but no squirters. Phase II can be added (Cobb does it?). Imprezer had a thread on this a couple months ago...
-Jon
www.nothingserious.net
Old 07-11-2002, 02:12 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
-Jon
any idea where that thread lies?? i know cobb does it...but i prefer to do my own block work and with the help of more local machine shops.
Jeremy
Old 07-11-2002, 12:53 PM   #8
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
http://forums.nasioc.com/forums/show...&highlight=oil
There's the thread. Unfortunately, there isn't much useful information in it. Alex never really goes into much detail when he does cool stuff...
-Jon
Old 07-11-2002, 01:39 PM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
thanks for the link, it really doesn't say anything, too bad he never took pictures.
jeremy
Old 07-15-2002, 09:42 PM   #10
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
This may help. It's a picture from a EJ22T block though.
seven881 is offline   Reply With Quote
Old 07-15-2002, 09:50 PM   #11
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
It basically looks like a couple small drilled holes. Be careful though. You don;t want them to be to big and not have enough oil for the bearings.
Eric
Eric SS is offline   Reply With Quote
Old 07-15-2002, 10:17 PM   #12
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
That is what I think every time I see a picture of them. Others were under the understanding that there was an actual fitting in there, but personally, I don't see why a small (1-1.5mm) hole can't be drilled and be just as effective.
Old 07-15-2002, 10:54 PM   #13
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
If I did that, I would definetly not even attempt to start the car without an oil pressure gauge hooked up to make sure the bearings are getting oiled.
Eric
Old 07-16-2002, 02:43 AM   #14
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
well it looks to me like all it is would be a 1mm hole in the main cap...but i'd be the first to try it, hmm...looks like it's time for a lil research, see which oil pump is the one to use
jeremy
Old 07-16-2002, 10:52 AM   #15
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
I can't help completely, but I will say that the oil pump on my EJ22T is the same unit as I put on my EJ22 N/A engine. I think almost all the pumps on the EJ engines are the same.. only differences in oil pressure are due to where you read it from and additional items that oil is feed to turbo.
I could be way off, but this is my take on the situation.
Old 07-16-2002, 01:00 PM   #16
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
well that's that'sa good bit of info, i was also thinking that the pressure regulating spring may be heavier in the turbo motors. But i could be wrong, i'll do more research shortly.
jeremy
Old 07-16-2002, 11:55 PM   #17
smacksube
Member#: 4067
01 2.5 rs
ok, if you attain a higher oil pressure than the stock bottom end was built for could result in problem wouldn't you think? Wouldn't it be smarter when adding the oil squirters to get the bearing journals honed just a tiny bit to accomodate for the extra pressure and allow for more oil? Or just get aftermarket bearing? Then if you got to use a looser tolerance then the engine break in period should happen a bit sooner. Of course, all this is just 'textbook' in my head since I have no first hand experience to date.
smacksube is offline   Reply With Quote
Old 07-17-2002, 01:08 AM   #18
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I think you have it reversed. If you put in squirters your pressure will drop, not raise. That's what I'm afraid of. But it appears that someone has put a pressure gauge on and it read fine so I think I'm ok.
Eric
Old 07-17-2002, 01:23 AM   #19
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
Is it worth all the trouble? Do oil squirters make that big of a differance?
LVSUBARU is offline   Reply With Quote
Old 07-17-2002, 02:22 AM   #20
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
yes....want to talk about a difference in piston temperatures...it does make a huge difference.
jeremy
Old 07-17-2002, 11:39 AM   #21
SubaSonic
Member#: 11365
02 N/A, A/T Wagon
Sedona Red Pearl
Default Piston ceramic coating
Woulden't ceramic coating the piston top be easier and safer?
SubaSonic is offline   Reply With Quote
Old 07-17-2002, 12:32 PM   #22
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Default Re: Piston ceramic coating
easier yes, safer no, it's not as reliable as the squirters...as long as you have oil the squiters work. Cermaic coating allows the heat not to be absorbed but does nothing to control piston temperature.
jeremy
Old 07-17-2002, 01:59 PM   #23
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I was curious... how far does the squirters squirt oil up the cylinders? Does it hit the backside of the pistons at TDC? Does it cause any parasitic drag to occour? I'm guessing if it does, it will make it up in lower cylinder temps, though.
Old 07-17-2002, 02:09 PM   #24
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I would think that it supplies a constant stream of oil to the bottom side of the piston because oil pressure pretty much remains a constant at a given rpm. it's like a spicket. you get a certain amount of pressure and water just keeps coming ouot.
I can't imagine it causing any parasitic drag.
Eric
Old 07-17-2002, 02:58 PM   #25
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Eric
exactly
Adding piston Oil Squirters? 93L-RS Built Motor Discussion 11 06-22-2006 06:33 AM
URGENT: Piston Oil Squirters. ImprezaRSX Private 'Wanted' Classifieds 0 09-18-2005 08:21 PM
Are piston oil squirters neccessary ? bugeyes Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-25-2005 11:15 AM
PISTON (oil) Squirters IN YOUR MOUTH Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-06-2002 05:05 PM
Piston oil squirter info? 8Complex Normally Aspirated with bolt-on Forced Induction Powertrain 24 01-21-2002 07:27 PM
