Old 01-04-2011, 09:54 PM   #1
bluemk3
Member#: 263694
World Rally Blue
Default speedo cable removal and replacement help on 97 L
ok i have come to the conclution that i need a new speedo cable. however before i break it how does the lower section come out of the tranny case. is it threaded or does it have some sort of snap ring mechanism. i may be over thinking it but i just want to know before i break anything. i have already established the workings of the upper. thanks to everyone in advance
bluemk3 is offline   Reply With Quote
Old 01-04-2011, 10:24 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Typically, they get ruined trying to remove them. Those stupid plastic threaded collars are notorious for becoming one with the case and deforming when you try to remove them.
I dunno if CLR would help any.....but I've ended up using a torch on the case to soften the plastic and just tearing it out.
Jay
Old 01-04-2011, 10:44 PM   #3
grafton
Member#: 187936
07 WRB STi
My 97 has a cable speedo? I thought it was electronic like in my legacy...
grafton is offline   Reply With Quote
Old 01-05-2011, 03:57 PM   #4
bluemk3
Member#: 263694
World Rally Blue
the first several months of the impreza in 97 had them. something i found out the hard way ha. so what everyone is saying is its threaded but plastic that will be ruined aye. ha fair enough thanks everyone
Old 01-07-2011, 12:24 PM   #5
ZapBrannigan
Member#: 251356
I managed to remove the electronic one from my donor car, and then I managed to get the slightly different mechanical one to fit in. Having said that, I hope to never touch it again
ZapBrannigan is offline   Reply With Quote
Removing and Replacing Rear Emblem on 07 Coop1103 Interior & Exterior Modification 10 05-01-2010 10:57 AM
How to Remove and Replace a Door Handle on a 99 pasty64 Impreza Forum 1 11-18-2008 10:14 PM
wastegate flapper removal and replacement derck_mullin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-28-2004 10:17 PM
No speedo, CE light and stalling - Help? BoomerRS New England Impreza Club Forum -- NESIC 20 12-06-2000 08:55 AM
Remove and Replace, or Repair? deepbeep General Forum Archive 6 09-19-2000 12:46 AM
